Ron Laden | 13/06/2018 07:58:50 |
![]() 2320 forum posts 452 photos | Morning, Something I,ve been meaning to ask....does 3 in 1 oil have its uses in the workshop..? I have heard good and bad things about it and just wondered, I have also heard that it is a mix of vegetable oils but dont know if thats true..? Ron Edited By Ron Laden on 13/06/2018 08:05:26 |
Nige | 13/06/2018 08:13:42 |
![]() 370 forum posts 65 photos | Morning Ron Somebody with more knowledge and experience will be along shortly I'm sure but I have realised that for any 'particular' lube application there will be a 'particular' type or class of oil best suited to it BUT if you haven't got any then 3 in 1 will probably get you through until the box arrives in the post. Had exactly this situation when my new machines arrived recently; cleaned off the preservative and wanted something to oil the surfaces and 3 in 1 was there |
Neil Wyatt | 13/06/2018 09:00:10 |
![]() 19226 forum posts 749 photos 86 articles | 3 in 1 contains castor oil, so it has a tendency to go gummy in the long term. It's best for things like squeaky door hinges but not precision mechanisms - mineral-based sewing machine oil is better for these sort of things. |
Adam Mara | 13/06/2018 09:05:09 |
198 forum posts 1 photos | My ancient gallon can of 3 in 1 (priced £3.80) just list ' a blend of refined light oils' and ' a polar rust additive' . Kept in company with my jerrycan of 'Pink Paraffin' and a Buck and Hickman tools catalogue all from my ironmongery days! |
Monoman | 13/06/2018 09:31:05 |
51 forum posts 7 photos | Neil, How do you know 3 in 1 contains castor oil? |
Rik Shaw | 13/06/2018 09:38:34 |
![]() 1494 forum posts 403 photos | I use anything oily as long as its less than three quid a gallon from the beneficent boot. Rik |
Brian G | 13/06/2018 09:49:08 |
912 forum posts 40 photos | Paul Sellers uses it on woodworking tools **LINK** Edit: Forgot to say, it is a quick and easy way to get grease and muck off chrome - I used to use it on motorcycle wheels (probably quite exciting if used on bicycles with rim brakes). Edited By Brian G on 13/06/2018 09:52:30 |
Michael Gilligan | 13/06/2018 09:49:17 |
![]() 23121 forum posts 1360 photos | Posted by Monoman on 13/06/2018 09:31:05:
Neil, How do you know 3 in 1 contains castor oil? . Good question ^^^ Here's one version of the MSDS : **LINK** https://www.technologysupplies.co.uk/downloads/msds/SDS0098.pdf Unfortunately "Pale Spindle Oil" doesn't mean much to me. MichaelG. . ... and this site doesn't exactly narrow things down: https://3-in-one.co.uk/data-sheets/ Multiple products, all called 3-IN-ONE [shades of the Loctite nonsense]
Edited By Michael Gilligan on 13/06/2018 09:56:27 |
Ron Laden | 13/06/2018 09:53:49 |
![]() 2320 forum posts 452 photos | Thanks guys, I am not suggesting I am using it but I noticed I have an old can on the shelf and wondered if it had any merits. Ron |
Jim Nic | 13/06/2018 09:55:29 |
![]() 406 forum posts 235 photos | I used 3 in 1 oil in my first couple of models and found that it does indeed go gummy after a fairly short time. I ended up stripping a couple of engines that were only a year or so old to get rid of all the residue. I only run my engines on compressed air. I have no idea what is in the oil to make it gum up, I only know I don't use it now. Jim |
I.M. OUTAHERE | 13/06/2018 11:14:30 |
1468 forum posts 3 photos | Isn't the 3in 1 brand an offshoot of the WD company (WD40 ) if so it is probably only good for cutting fluid on aluminium 😉
J Hancock | 13/06/2018 12:41:40 |
869 forum posts | Somewhere, I still have the ME article on the best rust prevention 'oil' available. In the trial , 3 in one was far better at keeping rust at bay, for longer, than any other similar product. No idea how good it is as an lubricating oil though. |
Bazyle | 13/06/2018 13:26:28 |
![]() 6956 forum posts 229 photos | I imagine the residue from the caster oil going off left a sort of rust preventing varnish. The thing about WS40 and 3in1 is the packaging makes it super convenient to use so it does get used. Once in the habit it gains a reputation with the used as the go-to product so even when they buy it by the gallon in a non convenient container it still carries its reputation. |
Richard S2 | 13/06/2018 13:46:16 |
![]() 237 forum posts 135 photos | It's lubricated Many thousands of Mowers, Sturmey Archer 3 speed cycle hubs etc and kept them running smoothly for many decades. I still use it around the workshop, albeit the old original maker's (E.R Howard of Hull) Thick Grade of 3 in 1 . Never had any issues with gumming. Spindle Oil was specified for use in Textile Mills. Pale version reduced risk of staining. Being light grade, it drains, so requires regular replenishment, especially where the textile fluff tended to 'Wick' the oil away from the important bits. And an example of the TV commercial in the 70s- Silence is Golden
Edited By Richard S2 on 13/06/2018 13:47:58 |
Michael Gilligan | 13/06/2018 14:20:22 |
![]() 23121 forum posts 1360 photos | Thanks for that Richard S2 MichaelG. . ... I'm still struggling to find any reference to Castor Oil in the product descriptions.
MichaelR | 13/06/2018 14:45:15 |
![]() 528 forum posts 79 photos | Wikipedia description.The formula consists of pale spindle oil with a small amount of corrosion inhibitor[which?] and citronella oil (which gives the product its distinctive sharp odor). Mike. |
Michael Gilligan | 13/06/2018 15:16:06 |
![]() 23121 forum posts 1360 photos | Posted by MichaelR on 13/06/2018 14:45:15:
Wikipedia description. ... . Reassuringly similar to the MSDS MichaelG. |
Keith Long | 13/06/2018 15:30:32 |
883 forum posts 11 photos | Here's a link to a more up-to-date (2014) version of the MSDS, I'm not sure that "Severely hydrotreated heavy naphthenic oil" is castor oil - sounds rather like a distillation product from crude mineral oil. Keith |
Monoman | 13/06/2018 15:35:53 |
51 forum posts 7 photos | I would point out thet the document linked to is an SDS - Safety Data Sheet, as required under EU Regulation. MSDS stands for Material Safety Data Sheet, the similar document used in the US and other countries such as Japan. An MSDS does not necessarily comply with EU Regulation and does not contain much of the specified data to fulfil the SDS Regulation. In the US it is common to hide from the user the detail of a formulation behind a State issued number, the contents of which are only disclosed when an accident or other defined cause permits the authorities to reveal the name of the relevant substance. Thus the MSDS can avoid the disclosure of ingredeints, and for the user this provides no protection uder the prior informed consent whichforms an element of EU chemical regulatioon. For those of an inquisitive nature I suggest reading the relevant EU Regulations can be enlightening. See for a start **LINK** |
Neil Wyatt | 13/06/2018 15:52:55 |
![]() 19226 forum posts 749 photos 86 articles | Interesting, apparently 'spindle oil' doesn't go gummy, yet going gummy (a characteristic of vegetable oils) is something I have associated with 3in1 since I was a teenager. I was once told it had castor oil in it, although it doesn't smell of it. Neil |
