Advice
Stainless steel
Kenneth Deighton13/05/2018 20:35:27
69 forum posts
I have to drill up to 3 dozen 3/16" holes in some 1/16" sheet stainless steel and have been told that to make the work easier I should alter the angle of the drill point, is this correct and if so what should the angle be ?.
Thanks, Ken.
J Hancock13/05/2018 21:12:22
869 forum posts
If you want really nice round holes I would use a (3/16" centre drill.
FMES13/05/2018 21:14:46
608 forum posts
Use a cobalt drill bit.
J Hancock13/05/2018 21:14:48
869 forum posts
Substitute a ) for that emoticon !
John Haine13/05/2018 21:27:17
5563 forum posts
322 photos
+1 for cobalt drill.
Mick B113/05/2018 21:29:13
2444 forum posts
139 photos
I always found that drilling thin material where I had to minimise burring on the far side was best done with a drill ground so that the full diameter was engaged on the entry side before the point exited the far side.
Theoretically the standard 118 degree point angle is *just* OK for 3/16 diameter into 1/16 material, but I'd want to up it to 130 - 140 or so.
This is guesswork, mind you - my experience has been more with hard brass than stainless.
Edited By Mick B1 on 13/05/2018 21:39:14
John Reese13/05/2018 21:53:33
1071 forum posts
Punch it instead of drilling.
Martin Newbold13/05/2018 21:59:13
415 forum posts
240 photos
+1 for cobalt drills, espp Dormer plus keep the drill speed low and lubricate the tip.
Drill smaller hole and build up hole size in steps to a larger final size
M
Ian S C14/05/2018 12:39:48
7468 forum posts
230 photos
Don't centre punch the marking out, use a HSS drill at low speed, and keep the pressure on, don't let it rub. If you are a bit more posh than I am, a cobalt, or carbide drill will do it, but keep it cutting.
Ian S C
Mike Poole14/05/2018 14:34:25
3676 forum posts
82 photos
I would use a stub drill and sharpen as mentioned above, it is very easy when drilling sheet material to end up with a 3 lobed hole but a 3/16 hole should not be too much of a problem. Stainless is notorious for work hardening if you do not keep the drill cutting. A four facet ground drill which should not need a centre pop may also be a good choice.
