Rotary Table
BOB BLACKSHAW02/04/2018 12:05:20
501 forum posts
132 photos
I have seen a Rotary Table with dividing plates at a good price, what are the advantages of a Dividing Head over the Rotary Table. I know that a chuck can be fitted to the Rotary Table, it seems to me they do the same job.
Bazyle02/04/2018 12:22:33
6956 forum posts
229 photos
Check the rotab can be mounted on its side or you have a big enough angle plate. Sometimes the extra diameter of the rotab gets in the way but otherwise it is just as capable as a dividing head until you get to the more complex 'universal' type that can tilt and do differential indexing for prime numbers, or be driven to make spirals.
john fletcher 102/04/2018 13:00:53
893 forum posts
A rotary table is a very useful but not often used device in most workshops, takes up space as well, I know, as I have one together with the dividing plates. Be careful using the tables for gear cutting as there are some with errors and its very annoying to find that you have a thin tooth for no fault of your own. Recently I made a stepper motor Arduino controller from the article in Model Engineer Workshop issue 249 which I can recommend. No more thin or one tooth short errors, works good. The article used two switches as inputs, where as I and I'm sure others have done, used a 4 x 4 key pad. Not being very well versed in micro electronics I received help from readers on this forum, and from my neighbour Steve, many thanks fella's. John
Muzzer02/04/2018 16:16:36
2904 forum posts
448 photos
Unless you have a CNC machine or stepper driven rotary table, a manual rotary table is one of the few ways to machine cylindrical paths in a way you couldn't otherwise. You'd struggle to do that with a dividing head. I used my rotab to machine internal and external surfaces with success, although nowadays my CNC machine does a much better job in a fraction of the time.
Murray
SillyOldDuffer02/04/2018 16:52:21
10668 forum posts
2415 photos
Posted by BOB BLACKSHAW on 02/04/2018 12:05:20:
They are similar devices with similar functionality. But I'd say a Rotary Table is generally more flexible than a Dividing Head. Often a table can be mounted either flat or vertically, whereas heads are typically one-way. It's occasionally useful to be able to clamp work direct to a table. Heads often only divide while tables usually do angles and divisions.
Much depends on exactly what you buy: there are some jolly nice Dividing Heads out there.
Dave Halford02/04/2018 16:57:40
2536 forum posts
24 photos
Dividing head
better for gear cutting and cutting splined shafts.
will give you angles assuming your machine is big enough.
Rotary table
Best used flat so good for drilling circle plates
some will mill curves if the gear and worm are up to it and some will strip the threads.
OK for any dividing that does not need a tailstock suport
richardandtracy02/04/2018 18:15:08
943 forum posts
10 photos
Rotary table can be used to make dividing plates, not vice versa.
I have a rotary table, and combined with a calculator can divide any number of divisions, not limited by the plates. BUT it's even easier to get wrong if not systematic.
Richard.
Howard Lewis02/04/2018 18:26:46
7227 forum posts
21 photos
I use my Rotary Table in both Horizontal and Vertical mode, which includes cutting gears.
But, as said, BEWARE of errors in the division tables supplied with the table.
My Vertex HV6 is one such. It cost me three scrap items, before realising that the errors were not mine. I made up my own division table, using EXCEL. This showed that the published table had eight errors or omissions!
If you have any doubts about the division tables, take time out and calculate. It may be time well spent!
Neil Wyatt02/04/2018 23:16:00
19226 forum posts
749 photos
86 articles
As I posted recently, PLEASE see Howard's tables:
www.model-engineer.co.uk/news/article/corrected-dividing-tables-for-vertex-hv6-dividing-head/23123
Only today I received a lengthy email prasing them for their accuracy and usefulness.
BOB BLACKSHAW03/04/2018 02:03:34
501 forum posts
132 photos
Thanks for these replies they have been very informative. The reply from Dave Halford about cutting curves on the Rotary Table can be a problem with the worm gear, if not up to it.
I have been given a 4 inch table some time ago unused which was purchased in the mid eighties. It is a import and will cut a curve in steel as I used this to recess a flywheel.
I like the idea of a Rotary Table with plates, the ones I've seen advertised by Warco seem quite a good price, but are they any good,can they cut curves in steel with out stripping the worm gear ? Fed up with buying crap, stuff not fit for purpose until modified.
The reply from Richard suggests that I don't need another table, just use a calculator.
But would still like one with plates, any recommendations please.
Thanks Bob
Paul Lousick03/04/2018 04:18:54
2276 forum posts
801 photos
Hi Bob,
This is what can happen to the gears when cutting a curve if the load is too high. The rotary table was not one of the cheap ones but a quality one, made in Japan.
A rotary table is a handy accessory for your mill for lots of applications.and I would not be without one but would advise that you get the biggest that would fit on your mill table..
Paul.
JasonB03/04/2018 07:39:38
Posted by BOB BLACKSHAW on 03/04/2018 02:03:34:
How long is a piece of string?
I have happily cut curves in mild steel and gauge plate on my Soba 6" but they were within a reasonable expectation of what the table could handle and the depth of cut was also appropriate to my machine and tooling. Take a look back through some of Paul's other photos and see the size of work being done on his similarly made but "quality labled" table and is it any wonder the gears stripped?
I've been using the 6" one from ARC recently and that is quite nice to use as well, not sure if the gears on that are iron or steel.
not done it yet03/04/2018 09:09:03
7517 forum posts
20 photos
Chain drilling followed by light finishing cuts with a keen cutter may be a sensible alternative to trying to make heavy cuts with less than keen cutters (and not climb milling, either), when using a less robustly built rotary table. So, much in agreement with JB, I suppose.
Alan Vos03/04/2018 19:21:42
162 forum posts
7 photos
Posted by Howard Lewis on 02/04/2018 18:26:46:
Apologies to Howard if this is well covered elsewhere, but the calcualation to *check* an entry in a division table is relatively simple. It does involve vulgar fractions. Do schools still teach that?
An example I found is that for a 90:1 reduction and 13 divisions you require 6 and 36/39 turns per tooth.
(Turns * Divisions) = Reduction (teeth on worm wheel). Those need to match exactly. All integers, No tolerance. No rounding.
13 divisions * 6 whole turns = 78. For the partial turns: 13 * (36/39) = 12. 78 + 12 = 90.
larry Phelan04/04/2018 11:16:18
544 forum posts
17 photos
Whatever about the rotary tables themselves being crap and way out,there is no excuse for the charts to be in error. A simple test run would soon show up any blunders which should then be corrected before production.
Too much to hope for ?
Howard Lewis04/04/2018 17:27:35
7227 forum posts
21 photos
Without wishing to be rude, it must take some effort to damage the worm and wheel, unless the design spec calls for putty or plasticene!
If anyone wants to try amending the original spreadsheet for gear ratios other than the original 90:1, the EXCEL spreadsheet is viewable at the top of the thread quoted by Neil. Hopefully, changing the formula from 90:1 to, say, 40:1 will produce sensible answers for Rotary Table or Dividing head with that ratio.
Am wondering if I am clever or brave enough to make two more division plates for my HV6. A "D" plate with 22, 24, 26, 28, 32,34, 38 holes and an "E" plate with 42 and 46 holes. All these should be "doable" with the existing "A", "B" and "C" plates, and would fill a few gaps in the table.
Whether or not I would ever use them, is another matter, but "They would come in handy, one day".
Another project would be to make a small Dividing Head for the mini lathe, (inspired by Stub Mandrel's one, using the division plates from the HV6. Another "Make it up as you go along job"!
Should prevent me getting bored, but not frustrated!
