Spotting Drill or Centre drill.
Vic09/02/2018 12:45:27
3453 forum posts
23 photos
I was watching a Clickspring video on YouTube the other day and noticed that like me he used a spotting drill to start off a hole on the lathe and wondered how many others do this. Or do you use a centre drill instead?
Edited By Vic on 09/02/2018 12:46:24
JasonB09/02/2018 13:08:00
Spotting drill for me all the time in lathe and mill unless I particularly need a ctr hole
FLguy09/02/2018 13:10:52
15 forum posts
Spotting drill. I'd like more sizes than I have too.
Mike Crossfield09/02/2018 13:18:18
286 forum posts
36 photos
I switched to using a spotting drill a year or two back, and only now use centre drill when I need a 60 degree centre for between centres turning.
I wish I could find a low cost source however. Spotting drills seem very expensive compared to centre drills.
Hopper09/02/2018 13:25:01
7881 forum posts
397 photos
Five bob each way here. I often use a larger size centre drill but use only the tip of it to put a small divot in the job, as one would do with a spotting drill. This works real well for tiny size drills where if you use the appropriate tiny sized centre drill in wobbly ancient machinery (or is it the wobbly ancient operator?) it is soooo easy to break the tiny tip right off it.
Vic09/02/2018 14:14:58
3453 forum posts
23 photos
Posted by Mike Crossfield on 09/02/2018 13:18:18:
Yes, they do seem a bit expensive don’t they.
Mick B109/02/2018 14:16:43
2444 forum posts
139 photos
I must've led a sheltered life in engineering - I'd never heard of a spot drill before I read this thread.
They're eye-wateringly expensive.
Although I've occasionally broken centre drill pilots, it's always been when I was impatient to drill the 60 degree cone in something difficult, not when I was spotting to guide a standard twist drill.
I think I'll stick with centre drills.
Andrew Johnston09/02/2018 14:44:52
7061 forum posts
719 photos
On the milling machine I rarely use spotting drills and never use centre drills. A 4-facet drill starts accurately enough without needing either. When I do need extra precision, or the surface isn't flat, I use a carbide spot drill to start.
On the main lathe I use centre drills; they're way cheaper than carbide spot drills. On the Britan I use LH centre drills.
larry Phelan09/02/2018 14:48:39
544 forum posts
17 photos
To Mike and Vic,
Look up a place called "Drills UK",They sell spotting drills,double ended,and not at all dear. I bought some MT drills from them a while back and am quite pleased with them. Along the way,I saw those spotting drills in many different sizes.I bought a pack of 10 5mm stub drills for £4 ,95.,are these what you are looking for?
JasonB09/02/2018 14:53:02
I just use 1/8 and 3/16 spotting drills, I like the Americam made Keo brand as they have the smallest "flat" between the webs that I have found. Don't think £2.42 inc vat from MSC is too bad though they are not stocking them anymore so just some left in the clearance except the 1/8" ones as I just bought their last 4 in stockdevil
A lot depends on what I'm drilling like Andrew I will use a split point Dormer straight onto the metal in some cases particularly if I have got the stub length needed and I have most of the common sizes in those.
Michael Horner09/02/2018 15:15:29
229 forum posts
63 photos
Spotting drill .
Usually I'm repairing a shaft by drilling and tapping. Go in deep enough so when I thread it doesn't pull the surface up.
1 less operation!
Cheers Michael.
Vic09/02/2018 15:42:48
3453 forum posts
23 photos
Posted by larry Phelan on 09/02/2018 14:48:39:
To Mike and Vic,
I’m not looking for any at the moment as I have 6, 8 & 10mm spotting drills. They are not the same as stub drills.
MW09/02/2018 15:46:14
2052 forum posts
56 photos
I pretty much use centre drills for everything, but for some very soft materials I don't even bother as there's pretty much no resistance to the point when it goes in, provided it's a split point drill.
I honestly was never shown spotting drills when training and only discovered them through youtube and watching others on the forum, so i'll have to check them out one day.
Michael W
Edited By Michael-w on 09/02/2018 15:46:50
Tony Pratt 109/02/2018 15:51:04
2319 forum posts
13 photos
Spotting drills
Tony
SteveI09/02/2018 15:55:07
248 forum posts
22 photos
For the folks using spotting drills are these 90 degree or 120 degree or another angle? I assume you follow up with a 118 degree or as near as regular twist drill.
Thanks,
Steve
JasonB09/02/2018 16:05:16
I just use the 90deg ones as they can give the hole a chamfer at the same time and as Michael says if tapping that little chamfer stops the area around the hole being raised up particularly if tapping softer metals. Regular angled drill follows OK.
larry Phelan09/02/2018 17:36:11
544 forum posts
17 photos
Sorry about that Vic,my mistake. I still have a lot to learn. I will look into that,I dont think I ever came across spotting drills but I did hear of stub drills,and I thought they were one and the same. I live and learn !
Tomfilery09/02/2018 17:43:02
144 forum posts
4 photos
90 degree spotting drill for me too!
I mostly use a 3mm one, even for tiny holes, and follow up with a normal 118 degree drill.
Tom
Neil Wyatt09/02/2018 18:51:51
19226 forum posts
749 photos
86 articles
All mine (which are in small sizes up to 3mm, came with those rotary tool accessory sets that contain lots of useful consumables and a few weird tips
Mick B109/02/2018 19:31:28
2444 forum posts
139 photos
To Mike and Vic,
Nah, still sticking to centre drills.
Those folk don't seem to be offering spotting drills unless they're the same as 'spot weld' drills - not double-ended either. Cromwell's spot drills seem to be around a tenner each, and they're not double-ended either.
Centre drill don't have cylindrical land and cut on the side as well as the point, so any eccentricity gets taken out. I've sometimes succesfully used the pilot as a tiny slot drill.
I can't see any substantial advantage in the spotting drill that's worth its price differential.
