lmini lathe electrics
john carruthers | 01/02/2018 08:30:32 |
![]() 617 forum posts 180 photos | My sc3 mini lathe has started trying to creep round when the speed pot is at zero. |
henryb | 01/02/2018 09:21:55 |
![]() 51 forum posts 3 photos | Mine has done that a couple of times i think it may be a bit of dust in the pot switch or wear. |
Martin Connelly | 01/02/2018 09:27:35 |
![]() 2549 forum posts 235 photos | A poor connection can cause this. Check all cables are secure. Martin C |
not done it yet | 01/02/2018 09:38:53 |
7517 forum posts 20 photos | An automatic gearbox in a car tries to creep at idle. Nothing unusual. These speed controllers are not absolute speed indicators and they are set up initially with some bias within the circuitry so that they actually come to rest at a greater reading than zero on the indicating knob. I expect most do that. Yours is on the borderline, I expect. An electronics type would likely easily trim a pot on the circuit to correct this tendency. |
Martin Shaw 1 | 01/02/2018 09:44:42 |
185 forum posts 59 photos | Happens on my SX2P mill occasionally which is of course exactly the same electronics. I find that isolating the supply usually cures it. Martin |
Mike Poole | 01/02/2018 10:10:25 |
![]() 3676 forum posts 82 photos | If you are turning the pot to zero rather than stopping the machine I would have thought this would be a risky practice, taking a measurement or using a chuck key should surely not be done unless the machine is properly stopped, the spindle is live even if the pot is set to zero, any disturbance could cause the spindle to move which could be painful. Mike |
Neil Wyatt | 01/02/2018 17:22:25 |
![]() 19226 forum posts 749 photos 86 articles | The speed pot should have a built in on/off switch. I think there's a preset on the board for minimum speed BUT I would advise a bit of switch cleaner in the pot first. |
colin hawes | 01/02/2018 18:44:37 |
570 forum posts 18 photos | My mini mill spindle occasionally creeps so I stop it with the red emergency stop button to change tools. Colin Edited By colin hawes on 01/02/2018 18:45:51 |
Wout Moerman | 01/02/2018 18:45:21 |
57 forum posts 2 photos | My C2 does the same occasionally. I try to switch the lathe of or set the direction in neutral before I use the chuck key. But I often forget. Never caused a problem though. I think there wouldn't be much power in the creeping chuck. |
john carruthers | 01/02/2018 18:50:37 |
![]() 617 forum posts 180 photos | Thanks everyone, puts my mind at rest. |
John Rudd | 01/02/2018 18:54:44 |
1479 forum posts 1 photos | Can you confirm which version of the C3 you have? The earlier C3 has a brushed motor, the control board of which has a min speed adjustment, the later brushless version doesnt appear to have any 'user' adjustable tweaky things...( I've had both machines...) Maybe Ketan can assist us with any technical adjustments Edited By John Rudd on 01/02/2018 18:56:52 |
Martin 100 | 01/02/2018 19:08:59 |
287 forum posts 6 photos | Posted by colin hawes on 01/02/2018 18:44:37:
My mini mill spindle occasionally creeps so I stop it with the red emergency stop button to change tools. That's a seriously deficient design. Stop should unconditionally mean stop by the removal of supply. A restart should not be possible by the action of just resetting the stop switch. |
Ian P | 01/02/2018 19:25:42 |
![]() 2747 forum posts 123 photos | Posted by Martin 100 on 01/02/2018 19:08:59:
My mini mill spindle occasionally creeps so I stop it with the red emergency stop button to change tools. That's a seriously deficient design. Stop should unconditionally mean stop by the removal of supply. A restart should not be possible by the action of just resetting the stop switch. If the machine had been stopped by the use of a stop button I would agree with you, but turning a speed pot to zero is little different than using a lathe with a mechanical clutch which leaves the motor running and the spindle stopped.
