Making an alloy gear knob, help needed
petro1head01/01/2018 13:25:34
984 forum posts
207 photos
I want to make something like this **LINK**
I know how to up to a point but am struggling once I have made it how to drill the hole and thread it without damaging it.
Any suggestions, looked to YouTube but could not find anything
Tony Pratt 101/01/2018 13:28:07
2319 forum posts
13 photos
I suggest tapered soft jaws or tapered split bush.
Tony
Edited By Tony Pratt 1 on 01/01/2018 13:28:47
Swarf Maker01/01/2018 13:31:43
132 forum posts
7 photos
I would have thought that the hole and thread is the starting point and from which you hold the raw stock to do the shaping operations. i.e threaded onto an arbor.
Malc01/01/2018 13:32:16
113 forum posts
6 photos
I think I would be looking to drill and tap the blank first, mount it on a matching threaded shaft. You could then hold the shaft in the chuck and turn the shape of the knob.
ASF01/01/2018 13:34:03
131 forum posts
12 photos
Yep, drill and tap then turn taper on threaded arbor then use ball turner and shape end over
Neil Wyatt01/01/2018 16:43:09
19226 forum posts
749 photos
86 articles
Damn.
As a teenager and before I ever had a driving licence, let alone a car, (probably 17th birthday) my parents gave me a leather gear knob with a sterling silver insert.
If I could find it, I could fit it to my car, just nearly four decades late
JasonB01/01/2018 17:01:59
As said drill, tap and cut the taper then screw it onto something while you round the end.
They are not the nicest things to use, my Ltd Edition Scooby has one, if it has been sitting in the sun you can't touch it and in winter it is like holding a block of ice.
petro1head01/01/2018 17:50:05
984 forum posts
207 photos
It’s not for a car but a racing sim Ihave in the loft.
Can’t decide if it’s the correct one, or should I make it out of nylon instead of ally
petro1head01/01/2018 17:50:44
984 forum posts
207 photos
Posted by Neil Wyatt on 01/01/2018 16:43:09:
Damn.
Very retro
not done it yet01/01/2018 19:19:09
7517 forum posts
20 photos
So retro that it would likely need a thread on the forum of how to hold it while cutting a metric thread (to replace the imperial one) without damaging it.smiley
JasonB01/01/2018 19:24:39
I bet Neil has also got the crochet backed driving gloves and cravat tucked away somewhere safe toosmile p
petro1head01/01/2018 19:40:03
984 forum posts
207 photos
He probably also has bead seat covers
Neil Wyatt01/01/2018 20:21:40
19226 forum posts
749 photos
86 articles
Posted by JasonB on 01/01/2018 19:24:39:
I think they are under the fluffy dice
I accept no gip from someone with gold alloys!
Ian S C02/01/2018 10:27:03
7468 forum posts
230 photos
I suspect that the nylon / plastic on would be comfortable to the hand, it might be worth making a threaded brass insert with a parallel knurled outside to it, pressed into the nylon knob. Set up the hole first, and screw this on a short bit of thread, hold in the lathe chuck and turn the taper, then rough out the hemisphere and finish with a hand scraper as used in wood turning.
Ian S C
petro1head02/01/2018 12:01:52
984 forum posts
207 photos
Posted by Neil Wyatt on 01/01/2018 20:21:40:
And what is wrong with gold alloys
petro1head02/01/2018 12:02:26
984 forum posts
207 photos
Well have enjoyed making my new knob
not done it yet02/01/2018 12:33:41
7517 forum posts
20 photos
You got your lathe in your bedroom? Or aquick recovery from you sick bed, yesterday!smiley
Old Elan02/01/2018 12:40:25
92 forum posts
34 photos
Absolutely nothing!
petro1head02/01/2018 13:54:11
984 forum posts
207 photos
Posted by not done it yet on 02/01/2018 12:33:41:
Its just man flue so was sick of bed and decided to take my mind off it yt playing in the workshop with the heater full blast
Edited By petro1head on 02/01/2018 13:54:45
Swarf, Mostly!02/01/2018 13:58:42
753 forum posts
80 photos
Posted by petro1head on 01/01/2018 17:50:05:
I'm quite happy with the knob that Citroen provided (234,000-ish miles on the clock).
But, were a replacement ever needed, it would be a choice between fabric-based Tufnol or some off-cuts from an ex London Underground railway sleeper, Jarrah wood, polishes and waxes up nicely to a rich deep red/brown.
Best regards,
Swarf, Mostly!
