What's the strangest project you've ever seen in an old ME or MEW?
Neil Wyatt18/12/2017 14:01:40
19226 forum posts
749 photos
86 articles
In MEW we occasionally cover 'domestic' repairs as these can involve interesting machining tasks.
Perhaps we should take a leaf out of ME's book and have a series on making a microwave or a nutri-ninja?
John Haine18/12/2017 14:38:42
5563 forum posts
322 photos
Many years ago on Tomorrow's World they had a hot dog maker that applied mains voltage across a frankfurter to heat it up. Definitely a candidate for a project I think.
John Haine18/12/2017 14:40:13
5563 forum posts
322 photos
Oh, and in that issue I see that they also have an article on a "small capacity milling machine" - presumably to make flour for small cakes in the electric mixer?
Edited By John Haine on 18/12/2017 14:40:23
Michael Gilligan18/12/2017 14:40:22
23121 forum posts
1360 photos
Answering to the thread title:
An Edision cylinder phonograph ... cleverly converted into a sander !!
crying 2 MichaelG.
Edited By Michael Gilligan on 18/12/2017 14:41:36
Ady118/12/2017 14:54:43
6137 forum posts
893 photos
I think there was a build your own fridge article at one point
As various home technology came on stream over the decades there were a few Heath Robinson attempts to get ahead of the neighbours
I seem to also recall a motorised lawn mower which could have been used in a Mad Max movie
Edited By Ady1 on 18/12/2017 14:57:17
SillyOldDuffer18/12/2017 15:43:12
10668 forum posts
2415 photos
From 'Model Engineer and Electrician' No 949:
Recommended for unsticking rusty pistons...
Edited By SillyOldDuffer on 18/12/2017 15:45:54
Neil Wyatt18/12/2017 16:46:18
19226 forum posts
749 photos
86 articles
laugh
David George 118/12/2017 18:42:38
2110 forum posts
565 photos
How to start a tractor with a shotgun cartridge ?
David
not done it yet18/12/2017 19:27:19
7517 forum posts
20 photos
Not particularly a project for a Field Marshall. It was an factory alternative to cranking when on your own (if very lightly - or weakly - built) or in the depths of winter when manual cranking was much more difficult. Making you own reloads might have been a project!
Simon Collier18/12/2017 19:53:06
525 forum posts
65 photos
I seriously considered making a dough hook for my mill. Even expensive kitchen mixers aren't really man enough for the job.
duncan webster18/12/2017 20:05:04
5307 forum posts
83 photos
Posted by David George 1 on 18/12/2017 18:42:38:
David
When I worked in gas turbines we put in a proposal for a man portable generator for the army which we proposed to start with cartridges. I left before I found out whether they got the job, but I kept on asking what do you do when you run out of cartridges? A pull cord isn't a lot of use on even a small turbine.
Neil Wyatt18/12/2017 20:07:50
19226 forum posts
749 photos
86 articles
Posted by duncan webster on 18/12/2017 20:05:04:
David
Choose a NATO standard cartridge so that in an emergency you just hoik the bullet out of one?
not done it yet18/12/2017 20:48:11
7517 forum posts
20 photos
They would need wads and a crimper - modern propellants only burn fast and clean under pressure. Not a real problem, I suppose - just use a far bigger case than required?
One problem with starting those Field Marshall engines was if that smouldering insert (of the size he was using) got trapped under the decompression valve. Didn't happen often, but was a bit of a b****r when it did, apparently. The starting handle supplied was long enough for two people to swing it. It is hard work on your own!
Clive Hartland18/12/2017 22:08:05
2929 forum posts
41 photos
I had a 27.5 Kva generator on my sig. Starting was HP air at 600 psi which gave 3 attempts to start and there was a Balastite cartridge start device fitted also. If someone forgot to fill the air bottle again I used to kick them in the rump. Only thing was they would not issue cartridges unless it was a continuous minus 18 C. It also had a starting handle which was big enough for 2 men to use. On a cold morning I could hardly turn the engine over alone.Many a time in the cold on exercise i would leave it ticking over at night, it used to keep the sentries warm.
Ady119/12/2017 00:31:38
6137 forum posts
893 photos
Ships engines always use air
If the old man was stopping/starting too much in port the engine room would let him know
"You've only got three starts left captain!"
duncan webster19/12/2017 01:05:03
5307 forum posts
83 photos
Posted by Neil Wyatt on 18/12/2017 20:07:50:
David
From memory they were a lot bigger than a bullet, more like an overgrown shotgun cartridge.
Jens Eirik Skogstad19/12/2017 02:13:14
400 forum posts
22 photos
Converted from milling machine to mixing machine laugh
See this movie the plane is started up with Coffman combustion starter (cartridge starter with other word). smiley
s
Edited By Jens Eirik Skogstad on 19/12/2017 02:15:14
Geoff Theasby19/12/2017 04:37:27
615 forum posts
21 photos
An x-ray machine, about 1914 in M.E. X-ray your pets!
Geoff
Jens Eirik Skogstad19/12/2017 05:48:28
400 forum posts
22 photos
Atomic energy lab for childrens laugh
not done it yet19/12/2017 07:29:49
7517 forum posts
20 photos
Not 'overgrown' at all. A normal gauge cartridge. Admittedly rather bigger than a .410, but they just used the size for the job. It was an 8 gauge. Some wildfowling shotguns used a 4 gauge cartridge. I suppose most out there only think of the most common shotgun size - the 12 bore.
You can work out the diameter using the standard density for lead and 4/3 Pi r^3. Without checking, a 12 gauge is about 0.718".  More like a cannon shell case than a bullet, I suppose.
Edited By not done it yet on 19/12/2017 07:33:51
