Layout Blue
Why so expensive and any alternatives?
Chris Taylor 309/12/2017 12:40:15
48 forum posts
21 photos
Layout blue seems very expensive, in one instance £50 for a small tube, I know it goes a long way but it seems a bit excessive. Are there any alternative substances that can be used for marking out?
John MC09/12/2017 12:55:27
464 forum posts
72 photos
I have used, for many years a felt tip pen, one with a big fat tip, usually blue but sometimes red or black, whichever comes to hand. Bought them from Staples years ago for next to nothing. One thing I have found, to work reliably they need to be stored upright tip down.
I assume you mean marking out blue rather than "micrometer blue" for checking fits etc.
Neil Wyatt09/12/2017 12:57:15
19226 forum posts
749 photos
86 articles
I found 8oz spray for £9.50 and 950ml of liquid for £16 online searching 'spray layour blue'.
Mike Poole09/12/2017 13:03:11
3676 forum posts
82 photos
Dykem layout blue is on sale for 16.99 for a 250ml bottle. The tubes on Amazon described as layout blue are not for marking out but for checking fits and scraping type work, as it is non drying using for marking out would be messy and non durable. The £50 price tag is ridiculous as RDG have it for about £12 but Stuart's micrometer is often found around the £5 mark. Be clear that the blue liquid and the blue paste have different uses. I find the Dykem blue liquid to be an excellent product, it takes a clean scribed line and is quite durable even coolant does not wash it off.
Permanent markers as others have said are very useful and can be obtained with very large tips, they are very convenient but I find they are not as durable as the layout blue. Very useful for a quick job that does not need to be handled too much. I would not be without both solutions.
Edited By Mike Poole on 09/12/2017 13:05:02
Edited By Mike Poole on 09/12/2017 13:09:53
Mick B109/12/2017 13:03:29
2444 forum posts
139 photos
Posted by John MC on 09/12/2017 12:55:27:
Yep, just scribble over the surface with a permanent Sharpie, then scribe as normal.
Daniel09/12/2017 13:05:49
338 forum posts
48 photos
I recently bought an 8oz bottle of red marking fluid from RDG.
Works brilliantly and was around £16.
They also have a blue version.
Robin09/12/2017 13:19:22
678 forum posts
I thought layout fluid was French polish with a blue stain added. French polish is cheap as chips but where to get the stain?
JasonB09/12/2017 13:30:48
Posted by Chris Taylor 3 on 09/12/2017 12:40:15:
If it was in a tube then it is not layout fluid but engineers blue. Try this for just over £10
Speedy Builder509/12/2017 14:03:01
2878 forum posts
248 photos
Sometimes the "Keyword search" facility works on this forum :- **LINK**
Brian Wood09/12/2017 14:04:07
2742 forum posts
39 photos
I have used black ink spirit markers for years, they show scribed lines very well and are cheap and cheerful into the bargain, handy pen shape and available everywhere.
Edit.  Sorry, I've said the same as John MacNamara. My experience matches his but I don't store them with any special care, they just get chucked in the drawer along with the bunch of pencils I keep to be sure I always have one somewhere.
Edited By Brian Wood on 09/12/2017 14:09:08
Robbo09/12/2017 14:14:04
1504 forum posts
142 photos
If you get the big felt tips from a tool store or builders merchant they last a lot longer than those from stationer's shops.
Or I last got layout blue (actually black) from JustTheTicket link **LINK** on page 3
Swarf, Mostly!09/12/2017 14:25:39
753 forum posts
80 photos
Don't do as I did!!!
After using layout blue, I used to clean the brush with methylated spirits and then pour the used meths back into the layout blue bottle. (Well, it seemed like a good idea at the time! ) It didn't become unusably thin, BUT ...
Using layout blue from that bottle after a break of some years, I found to my horror that it only partially dried, leaving a nasty sticky surface.
Nowadays, I don't bother to clean the brush - the next use softens it up very quickly. (That particular brush is kept exclusively for use with layout blue. )
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 09/12/2017 14:26:07
Vic09/12/2017 15:36:39
3453 forum posts
23 photos
I use these:
Just as good as layout fluid but more convenient to use. They are also refillable. I do have a bottle of layout fluid somewhere but I’ve never used it since buying the jumbo marker.
Howard Lewis09/12/2017 15:42:27
7227 forum posts
21 photos
Wide felt tip pens, (permanent markers) make a good substitute.
Like Swarf Mostly, my brush dries out and hardens, but softens once dipped into the bottle again.
Tim Stevens09/12/2017 16:30:36
1779 forum posts
I find the best type of marker pens for this use (layout) are those sold to mark OHP transparencies. They are good strong colours, and you can get a range of six colours in a wallet. Useful for marking different stages, or re-thinks.
Also very useful for OHP transparencies, believe it or not ...
Cheers, Tim
Sam Longley 109/12/2017 17:59:16
965 forum posts
34 photos
I have a can of spray on Rocol marking blue. Had it for years & it seems to keep the rust off metal sheet during the build process. Never had any luck with felt pens.
SillyOldDuffer09/12/2017 18:02:01
10668 forum posts
2415 photos
Posted by Robin on 09/12/2017 13:19:22:
French Polish might have too much shellac in it for direct use as a layout fluid but it could easily be diluted with meths. The dye is probably Methylene Blue (25g £7.50 on ebay).
You may have to experiment to get the mix right but I doubt it's critical. Be VERY careful not spill it - 25g is enough to Blue a tribe of Smurfs!
smiley
Sam Longley 109/12/2017 22:37:08
965 forum posts
34 photos
It is obvious that you have not bought any shellac ( french polish) lately !!!!!
Robin09/12/2017 23:33:47
678 forum posts
Posted by Sam Longley 1 on 09/12/2017 22:37:08
No I haven't, a bottle of Rustin's button polish lasts me a long time. However, eBay shellac, £32.99/kg with free shipping.
Chris Trice10/12/2017 01:19:56
1376 forum posts
10 photos
Sharpie Permanent Marker pens almost exclusively, black and blue being the best. Convenient, clean, quick and cheap.
