adhesives for loose bearings
bricky06/12/2017 21:20:08
627 forum posts
72 photos
Hi
I have made an error on boreing a bearing housing of 18 th". I rebored and was successful in getting the new position correct.Now I want to glue them in position but it will require an adhesive to take up the 18th" or another solution.
Frank
fizzy06/12/2017 21:24:36
1860 forum posts
121 photos
You need a small bottle of loctite bearing retainer, yellow guey stuff but made exactly for your application.
Jeff Dayman06/12/2017 21:43:49
2356 forum posts
47 photos
Is Bricky talking about needing 1/8 of an inch clearance takeup? If so I don't think a Loctite product would fill that gap and carry any load. Maybe .010" but not .125". Hope he clears up what he's after. If it's truly a 1/8" gap I would suggest a turned metal sleeve to fill the gap and Loctite brg ret on both surfs of the sleeve maybe.
Clive Brown 106/12/2017 21:51:03
1050 forum posts
56 photos
I interpreted 18 th" as 18 thou, still too much for ordinary loctite AFAIK. They do a "Quickmetal" goop for worn components, but it's expensive. I've never used it.
I think I'd bore bigger and fit a sleeve if possible, as suggested above
websnail06/12/2017 21:52:53
62 forum posts
+0.018" is how I read it.blush
Edited By websnail on 06/12/2017 21:54:02
vintagengineer06/12/2017 21:55:21
469 forum posts
6 photos
Knurling is an old bodge to make things bigger. Make up a boring bar with one wheel on the end.
Mike Poole06/12/2017 23:26:14
3676 forum posts
82 photos
Have a look at tolerance rings, these are made to fit bearings in damaged housings after remachining.
I.M. OUTAHERE07/12/2017 05:57:04
1468 forum posts
Best bodge - do as Mike says or bore the hole out well oversized like 1/8 over then machine up an insert ring that matches the oversize bore and has its bore well undersized, loctite and a light press fit into oversize housing then bore that out to match the bearing .
desperate bodge - use some 0.008 thou feeler gauge strip or some shim material to make an infill ring that sits in the oversize hole then using ample bearing retainer on all surfaces push the bearing into the infill ring / housing assembly , you have to use 0.008 thou as you dont want a press fit as it will drag the shim in with the bearing if you try to press it in - i prefer the first option as it is more reliable and yields a neater repair .
Martin Dowing07/12/2017 08:11:03
356 forum posts
8 photos
@XD
0.008 inch, eg.8 thou?
Martin
Tractor man07/12/2017 08:21:30
426 forum posts
@Martin XD is correct as the gap to be filled is annular 0.008 feeler would work well. Think taking a cut of 0.5mm on the lathe dial and finding the bar 1mm smaller in diameter. Same principle, sorry if this is egg sucking to you but to others it may not seem so clear. Regards
Michael Gilligan07/12/2017 08:21:45
23121 forum posts
1360 photos
Some clarification from Frank [bricky] would be helpful, but ... if we're talking 0.018" on the diameter, then Loctite 641 should do the job easily ... As fizzy mentioned.
http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627649537&msdsLanguage=EN_GB&selectedTab=document
Technical DataSheet here: **LINK**
http://tds.henkel.com/tds5/Studio/ShowPDF/641-EN?pid=641&format=MTR&subformat=REAC&language=EN&plant=WERCS
Clive Hartland07/12/2017 08:28:01
2929 forum posts
41 photos
You could also buy some of those rings with pressed in dimples to fit the gap but you would then have to machine the hole again to the size to fit one. I dont know what they are called but have seen them on motor bearings.
I.M. OUTAHERE07/12/2017 11:31:34
1468 forum posts
Posted by Martin Dowing on 07/12/2017 08:11:03:
@XD
Martin
Hi Martin,
Yes my post was originally meant to read 0.008 in (8 thou ) appologies for rhe typo !
Neil A07/12/2017 12:06:06
160 forum posts
I'm afraid that I am with Clive on this one. Maximum gap fill on diameter for LOCTITE 641 is quoted as 0,2mm   or  0.008" . I don't think you would achieve a satisfactory bond at 0.018" oversize on diameter.
LOCTITE 660 is an alternative, but expensive.
Personally I would be looking to sleeve and rebore if possible.
Have a look at the link to the brochure, see what you think.
Edited By Neil A on 07/12/2017 12:07:09
Edited By Neil A on 07/12/2017 12:07:55
bricky07/12/2017 12:18:47
627 forum posts
72 photos
You are right Michael I have not been clear enough.I was 18/1000" low on the correct position I milled the bearing housing to this amount leaving a gap of 18/1000" below thw fitted bearing.I hope this makes it clearer.
Frank
JasonB07/12/2017 13:16:44
So are you saying you have the original hole and a new one bored 0.018" higher in which case you will not need to fill the top but will have a max gap of 0.018" at the bottom.
In which case I think your best option is to bore alarger hole in the correct position so that all trace of the old hole is removed and then sleeve it or find a bearing with larger OD
Edited By JasonB on 07/12/2017 13:26:45
Ian S C07/12/2017 13:17:26
7468 forum posts
230 photos
Bricky, the one recommended by Loctite is 660, it is a paste in a tube, and it's good to .020" on dia/.010" gap. Its also good for warn splines and things like that.
Ian S C
bricky07/12/2017 15:38:26
627 forum posts
72 photos
Thanks to all for your suggestions I will have a ponder on what to do next.Jason has drawn exactly what I have ended up with.
Frank
Alistair Robertson 107/12/2017 16:44:42
154 forum posts
6 photos
A few years ago I worked for a company that built up very special gearboxes with ratios from 1000 to 1 up to 1 TO 200. These gearboxes were very expensive but several of the sections had designed oversize bearing bores and were assembled with a special Loctite adhesive. Several 100's of £ a bottle as I remember.
This kept all the shafts etc. in alignment and we never had a gearbox returned with any shaft problems.
Alistair.
HOWARDT07/12/2017 16:47:55
1081 forum posts
39 photos
Similar problem on here recently with over sized bore. The concensus then was to rebore the hole, plug and rebore in its correct place. If the bearing is used as a loaded support then it requires a tolerance bore/shaft as per catalogue to achieve the correct fit for the loads being applied. Applying glue of any kind in an oversize hole cannot give positional accuracy or bearing fit if the hole is not a fit in the first place. But if the bearing is non critical, just there as a support of a free shaft, then you would be ok.
