sean logie | 05/11/2017 16:36:29 |
![]() 608 forum posts 7 photos | Made myself a wee vee block and I'm planning a couple more out of the same piece of material . I also learned how important setting up a work piece up before machining . Also used a carbide end mill for the first time today (very impressive ) . I cut the square channel on the side using a 4 flute ,is this good practice or should I have used a 2/3 flute . Overall I'm happy with the end result . The Centec2 keeps on impressing ,I was taking what I thought were big cuts for this small mill ,the only thing stopping taking bigger cuts was the operator . Getting a tad impatient now to get the vertical up and running . Don't know why my photos are always like this on here .... Sean Edited By Neil Wyatt on 07/11/2017 15:23:54 |
Trevor Drabble | 05/11/2017 16:44:27 |
![]() 339 forum posts 7 photos | Sean , Nice work . May I suggest you now put a nominal 3mm x 3mm slot along the full length of the bottom of the Vee in order to allow dirt and dwarf somewhere to go and also to allow any angular work to sit fully on the sides of the Vee , and so maintain an accurate register . Trevor |
Russell Eberhardt | 05/11/2017 16:44:39 |
![]() 2785 forum posts 87 photos | Posted by sean logie on 05/11/2017 16:36:29:
Don't know why my photos are always like this on here .... See this thread. Russell |
John Haine | 05/11/2017 16:48:04 |
5563 forum posts 322 photos | Good stuff! When you make 2 more try machining as a pair so that they match - useful then for holding longer bars needing support at both ends. |
sean logie | 05/11/2017 17:24:11 |
![]() 608 forum posts 7 photos | Posted by Trevor Drabble on 05/11/2017 16:44:27:
Sean , Nice work . May I suggest you now put a nominal 3mm x 3mm slot along the full length of the bottom of the Vee in order to allow dirt and dwarf somewhere to go and also to allow any angular work to sit fully on the sides of the Vee , and so maintain an accurate register . Trevor Thanks Trevor , That was my next move along with a slitting saw cut along the bottom of the vee .
Sean |
sean logie | 05/11/2017 17:26:36 |
![]() 608 forum posts 7 photos | Posted by John Haine on 05/11/2017 16:48:04:
Good stuff! When you make 2 more try machining as a pair so that they match - useful then for holding longer bars needing support at both ends. Hi John , I've enough material to make another two which as you suggested will be a pair .
Sean |
David George 1 | 06/11/2017 19:48:12 |
![]() 2110 forum posts 565 photos | Hi Sean I would also put a couple of taped holes in the base of the V block as it gives you the option to screw them to a plate or an angle plate and a taped hole in the end face so you can screw a plate to the end as an end stop for a pin or round part. David |
Rainbows | 06/11/2017 20:30:02 |
658 forum posts 236 photos | Speaking of pairs feel free to make two vertical heads and send me one |
sean logie | 06/11/2017 21:25:58 |
![]() 608 forum posts 7 photos | Rainbows no probs ....
Sean |
John Reese | 06/11/2017 22:40:56 |
![]() 1071 forum posts | Posted by Trevor Drabble on 05/11/2017 16:44:27:
Sean , Nice work . May I suggest you now put a nominal 3mm x 3mm slot along the full length of the bottom of the Vee in order to allow dirt and dwarf somewhere to go and also to allow any angular work to sit fully on the sides of the Vee , and so maintain an accurate register . Trevor I believe the slot at the bottom of the V is to allow grinding withe the need for sidewheeling. Unless he intends to grind the blocks there is no advantage to the undercut. |
not done it yet | 07/11/2017 07:35:18 |
7517 forum posts 20 photos | there is no advantage to the undercut. Unless wanting to mount a square item to machine on one corner...
Michael Gilligan | 07/11/2017 08:05:24 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 07/11/2017 07:35:18:
there is no advantage to the undercut. Unless wanting to mount a square item to machine on one corner... . I was so tempted to get all pedantic ... but I shall refrain. Yes; in practical terms that is a very fair point. MichaelG. |
sean logie | 07/11/2017 08:07:42 |
![]() 608 forum posts 7 photos | Please don't refrain 😉 Sean |
Martin King 2 | 07/11/2017 09:39:36 |
![]() 1129 forum posts 1 photos | Posted by sean logie on 07/11/2017 08:07:42:
Please don't refrain 😉 Sean Seconded! Pedantry from a master is so much fun! Martin |
Michael Gilligan | 07/11/2017 13:15:16 |
![]() 23121 forum posts 1360 photos | Apologies for the delayed response, Sean [and Martin], I made that post just before heading to the Hospital for my pacemaker check. ... All is well, so here goes: 'ndiy' has not defined any terms, nor given any tolerances; so we are obliged to make some assumptions: Mine [which I hope are considered reasonable] would be ...
Unfortunately, in this hypothetical 'defining case' ndiy's brief assertion falls down ... because the 'square corners' would match perfectly and the groove would therefore NOT be of any advantage. ^^^ This is, of course, merely gratuious pedantry !! In the real world; ndiy's point is a good one ... because the 'male' square corner may have bruises [or imperfections in its linearity] sufficient to cause it not to seat properly in the 'perfect' female vee. N.B. Many other imperfections are available ... MichaelG. |
David Standing 1 | 07/11/2017 13:25:49 |
1297 forum posts 50 photos | Posted by Michael Gilligan on 07/11/2017 13:15:16:
You didn't disappoint |
sean logie | 07/11/2017 14:16:04 |
![]() 608 forum posts 7 photos | Now that's a reply .... I wonder if there will be any response .... dam I wish I'd stuck in more at school ... you had me chuckling away to myself .... Sean |
Jim Cahill | 07/11/2017 14:43:22 |
![]() 21 forum posts | Hello Sean, In one of his books, Geo. H. Thomas goes to some length to explain why he believes 4 flute cutters (Known as End Mills in the UK) are inclined to break as they emerge from cutting a channel.
sean logie | 07/11/2017 15:07:37 |
![]() 608 forum posts 7 photos | Makes sense Jim , coming out the end of the cut was when the end mill groaned a bit . Should I be using a 2/3 flute for cutting channels . Sean |
MW | 07/11/2017 16:29:45 |
![]() 2052 forum posts 56 photos | Very nice, do you think you'll polish them with emery cloth when you're finished or will you leave them to a machine finish? Michael W |
