soluble
sean logie | 13/10/2017 09:50:41 |
![]() 608 forum posts 7 photos | Where do you guys buy ,and who makes there own . Jeez this stuff is expensive . I've been using really light motor oil up to now . Because I don't have any coolant systems on my machinery I haven't bothered with any because of the mess . Maybe a wee spray mist in the near future now that I have a decent compressor . The thing that concerns about the spray mist is when it gets airborne . Anyways ,I'm looking to buy some cutting/coolant oil .
Sean |
Bob Stevenson | 13/10/2017 10:22:20 |
579 forum posts 7 photos | It depends on what you are making and the size of your set-up.......if you're planning to shift a lot of metal quickly with your Colchester Triumph then it's pumps, pipes, 'pro' quality fluid etc etc.....
......If it's just a small lathe in the shed then get some 'neatcut' from Warco or similar, pour some in a jam jar with small bristle brush pushed thru a hole in the lid and keep it in the lathe tray...'splosh' method of application works well.... |
Brian Wood | 13/10/2017 10:24:43 |
2742 forum posts 39 photos | Sean, Look up Smith and Allan in Darlington, their website lists all manner of oils and it includes soluble oil. They also do mail order which should help you living where you do. Regards Brian |
Jon Gibbs | 13/10/2017 10:46:29 |
750 forum posts | I use neat cutting oil which I know isn't strictly a coolant but check out these folks... **LINK** 5 litres postage free for £20. I use them for my slideway and headstock oil too - similar prices. Usual caveats - just a satisfied customer. Jon |
Jon Cameron | 13/10/2017 11:01:55 |
368 forum posts 122 photos | Brian thanks for the heads ups. Hadnt heard of them Just looked them up....... |
Perko7 | 13/10/2017 11:17:31 |
452 forum posts 35 photos | For the occasions when i need to provide some lubricant while turning in the lathe, i use the spray cans of Trefolex CDT cutting oil for steel (that's a product available in Australia, not sure what the UK equivalent would be), and WD40 for aluminium and associated alloys. Brass and similar soft metals i usually turn dry. |
Hopper | 13/10/2017 11:22:04 |
![]() 7881 forum posts 397 photos | Any old oil will do in a pinch. Gearbox oil has extreme pressure additives that may be helpful for cutting pressures etc. (That's the orrible sulfur smell it has.) Ordinary machine oil can actually work better than conventional cutting oil and water when screwcutting. It lubricates better than coolant. |
David Standing 1 | 13/10/2017 11:43:45 |
1297 forum posts 50 photos | I personally don't like flood coolant because of the staining it leaves on machinery. That isn't a consideration in a commercial environment where the issue is to get parts made as quickly as possible and to budget, and the work itself can dictate there is no other option. There may be occasions where coolant is desirable in the home workshop, but I suspect they will be rare. I also use neatcut, and as per Jon Gibbs's post above, use whoever happens to be cheapest for 5L on eBay. |
Gordon W | 13/10/2017 11:53:17 |
2011 forum posts | I use proper cutting oil only when needed, eg. screwcutting. For general turning on steel and ally I use a jar with a mix of old oil and paraffin, diesel, whatever got in the jar. Just an old brush to put it on. For special aluminium turning WD40 is good, buy in big cans not spray tins. |
I.M. OUTAHERE | 13/10/2017 12:23:55 |
1468 forum posts 3 photos | I use carbide so for steel i mostly run dry unless im cutting something nasty then i use neat cutting fluid applied with an acid brush ( shell dromus i think ) but this is mostly used for drilling and tapping . For alloy i use wd40 to stop it welding to the carbide tip , i have seen a recent video on youtube where denatured alcohol was used and as it flashes off quickly it doesn't leave the oily residue like wd40 does .
Clive Foster | 13/10/2017 13:46:16 |
3630 forum posts 128 photos | I bought 5 litres of Rocol Ultracut 370 about 20 years back. Use it diluted around 40 to 1 when needed. Maybe little over half way through the bottle, including filling the tank on the 1024. Synthetic means expensive, maybe £100 now £40 then, but it does go a long way and isn't so bad as old style suds for staining et al. Best to wipe when finished tho'. Doesn't go off in the tank either. Worst point is that its so slippy that you need to periodically clean up chuck jaws and collets or things don't hold as well as they should. Clive. |
Sam Longley 1 | 13/10/2017 14:16:18 |
965 forum posts 34 photos | I bought some Rocol cutting oil years ago; not sure what type;that had to be diluted about 40 or 50:1 with water. The lathe in question was only occasionally used & quickly got coated in rust. Hence, I would now stay away from water soluble solutions |
Tim Stevens | 13/10/2017 15:34:38 |
![]() 1779 forum posts 1 photos | I get good results with a spray can of Drilling and Tapping Spray from Beal (UK) Ltd, Leeds. Not expensive, and I guess not super clever, but it can be a good coolant for a tough job (or an elderly cutter) straight from the tin. Not smelly, not staining. It also blows swarf away, and can reach into holes, better than a brush and less fierce than an air-line. They also do a wide range of other aerosols, including belt dressing, chain & cable lube, and one called Service Lube described as a clean and stable lubricant, so good for getting horses into loose boxes, I'm sure. Cheers, Tim Edited By Tim Stevens on 13/10/2017 15:36:07 |
Vic | 13/10/2017 16:51:57 |
3453 forum posts 23 photos | I use soluble oil mixed with water in a hand spray. Works well and not too messy. I also use tapping compound when cutting threads or drilling sometimes. |
Clive Foster | 13/10/2017 17:06:50 |
3630 forum posts 128 photos | Interesting. I use Rocol at 40 - 50 to 1 (ish) dilution. Sam also used Rocol at similar dilution. No rusting or staining problems for me. Mega rust problems for Sam. Pity Sam can't remember what type he used. But I do wipe off and (usually) lightly oil the lathe bed before shutting down for the day. after using coolant. Tedious on the 1024 because the saddle is so close to the flat parts of the bed that it tends to drag coolant underneath needing few back'n forth to get it all out. My experience is that the diluted Rocol Utracut 370 is a lot easier to wipe off properly than old style suds. If I'm going to be doing a lot of coolant work I anoint the bed first with my preferred heavy duty & way oil, Castrol Magna BD68 but anything similar from a decent brand name will do fine. Probably helps that the 1024 has a bed lubrication system driven by saddle movement feeding oil from the apron. Clive. |
Raymond Anderson | 13/10/2017 17:07:48 |
![]() 785 forum posts 152 photos | Castrol Hysol Excel [ now called Alusol A ] No foul odours, no staining/ rusting, leaves a good lubrication film on the machine and Long sump life, works across a wide variety of Ferrous / non ferrous metals. |
Sam Longley 1 | 13/10/2017 17:30:11 |
965 forum posts 34 photos | Posted by Clive Foster on 13/10/2017 17:06:50:
Interesting. I use Rocol at 40 - 50 to 1 (ish) dilution. Sam also used Rocol at similar dilution. No rusting or staining problems for me. Mega rust problems for Sam. Pity Sam can't remember what type he used. Clive. The fluid turned white when mixed but it was years ago (I still have some in a bottle !!) & to be fair we only used the lathe every few months for turning shims for joinery cutters etc & it was just left in a shed after use. I made the comment because some forumites have to keep their equipment in sheds that may be subject to some condensation or temperature differences . If rusting is a problem then this stuff would only exacerbate the issue I am sure. For my money, with a nearly new lathe & mill, I would try to avoid water soluble solutions, although things have changed over 25 years & regular maintenance would help. Plus one does get a lot for one's money Edited By Sam Longley 1 on 13/10/2017 17:32:14 |
Brian H | 13/10/2017 18:17:52 |
![]() 2312 forum posts 112 photos | Posted by Raymond Anderson on 13/10/2017 17:07:48:
Castrol Hysol Excel [ now called Alusol A ] No foul odours, no staining/ rusting, leaves a good lubrication film on the machine and Long sump life, works across a wide variety of Ferrous / non ferrous metals. I can vouch for that, and it makes a noticeable difference to the finish on steel. No problems with rust or smells. I got mine from an ebay supplier in a 1 ltr bottle but the stuff has removed the writing from the label so I can't tell you who supplied it. Brian |
john carruthers | 14/10/2017 09:15:12 |
![]() 617 forum posts 180 photos | I was recently given some pretty red Rotabroach cutting and tapping fluid. It works very well, especially when tapping ally. |
Hopper | 14/10/2017 09:21:31 |
![]() 7881 forum posts 397 photos | Posted by john carruthers on 14/10/2017 09:15:12:
... Wow. How many water fleas does it take to make a litre of water-flea oil? The mind boggles. |
