sean logie | 03/10/2017 15:42:37 |
![]() 608 forum posts 7 photos | Diemensions are 3"x2"x 15" in steel . This is going to cost an arm and a leg ? Where would be the best place to try . Postage will probably be the deal killer . Sean Edited By sean logie on 03/10/2017 15:43:21 |
Jon Gibbs | 03/10/2017 15:53:59 |
750 forum posts | I'm a very satisfied customer of m-machine metals. Give them a try. Jon |
mark smith 20 | 03/10/2017 16:07:33 |
682 forum posts 337 photos | M metals is £58 + shipping which with Sean living in the HIghlands (if i remember ) will worlk out expensive. These lot on ebay sell 250mm of 3x2" for £29.83 and 500mm of 3x2" for £45.63 or a letre for £59 Shipping included.But being in the highland they do say there may be a charge. there may be cheaper elsewhere or a local steel stockholder etc... Edited By mark smith 20 on 03/10/2017 16:30:38 |
JasonB | 03/10/2017 16:16:41 |
![]() 25215 forum posts 3105 photos 1 articles | Bright or black? |
John Rudd | 03/10/2017 17:41:09 |
1479 forum posts 1 photos | Is this suitable? https://jenkinssteelonlinemetal.co.uk/product/3-x-2-flat-bar-x-500mm-bright-080a15/
Wayne Ward | 03/10/2017 17:53:53 |
12 forum posts | I've used this supplier and I have no complaints |
sean logie | 03/10/2017 18:14:49 |
![]() 608 forum posts 7 photos | Think I might have to go and see my friendly machinist shop .
Sean |
mark smith 20 | 03/10/2017 18:53:21 |
682 forum posts 337 photos | Posted by John Rudd on 03/10/2017 17:41:09:
I didnt know they had a website shop actually £4 cheaper than what i stated above from their ebay shop. Must be adding in paypal/final value fees to their prices on ebay. |
JasonB | 03/10/2017 19:02:21 |
![]() 25215 forum posts 3105 photos 1 articles | Would have thought a side and face cutter in the Horz mill would hog it out better than using an end mill. If you do want to use a milling cutter then try a Roughing one, sometimes called a ripper. |
John Rudd | 03/10/2017 19:12:21 |
1479 forum posts 1 photos | Posted by mark smith 20 on 03/10/2017 18:53:21:
I didnt know they had a website shop actually £4 cheaper than what i stated above from their ebay shop. Must be adding in paypal/final value fees to their prices on ebay. Lucky for me, they are going to be ten mins up the road when I move..( pretty soon..) Sure, I'll pay them a visit and say hi..... |
sean logie | 03/10/2017 19:14:08 |
![]() 608 forum posts 7 photos | Posted by JasonB on 03/10/2017 19:02:21:
Would have thought a side and face cutter in the Horz mill would hog it out better than using an end mill. If you do want to use a milling cutter then try a Roughing one, sometimes called a ripper. End mills are considerably cheaper than horizontal cutters ,there are plenty of used one's out there and they're not easy to resharpen I'm led to believe .
Sean |
Mikelkie | 03/10/2017 21:03:19 |
![]() 135 forum posts 13 photos | Here near my shop is a dealer that buys redundant metals of all sorts and resells them at a price less than a third of the cost of new, isn't there metal mongers that do the same over by you guys? |
peak4 | 03/10/2017 21:18:20 |
![]() 2207 forum posts 210 photos | Sean, have you thought about contacting your local steel stockholders in Inverness? e.g. **LINK** or http://www.inverfab.co.uk/services/ Expensive prices on line, but I guess you could offer to collect and see what they might have in the scrap bin. Bill. Edited By peak4 on 03/10/2017 21:21:32 |
Chris Evans 6 | 03/10/2017 21:23:46 |
![]() 2156 forum posts | All the above prices seem way over the top to me. Luckily living in the Midlands I am close to many steel stockholders and tend to buy from their offcut rack for cash. |
Clive Washington | 03/10/2017 21:28:37 |
26 forum posts | Are you trying to make a raising block for the Centec vertical head? Mine is made of light alloy and its fine, no need for steel. Its a 3 inch square piece or thereabouts. |
Andrew Johnston | 03/10/2017 22:03:37 |
![]() 7061 forum posts 719 photos | Posted by JasonB on 03/10/2017 19:02:21:
Would have thought a side and face cutter in the Horz mill would hog it out better than using an end mill +1 No point in having a horizontal mill if you don't use it to make swarf; 1" wide cutter and ½" DOC: All my S&F cutters and slab mills are secondhand, via Ebay. Many still had the wax coating,so either new or reground. Don't think I've paid more than £10 for a cutter. Of course there are always the dreamers asking silly money, and cutters with teeth missing, but it should be possible to find decent cutters at a sensible price. I have the wherewithal to sharpen S&F cutters, although thus far I haven't needed to. Andrew |
not done it yet | 03/10/2017 22:25:10 |
7517 forum posts 20 photos | If that is a good guess, at 400mm, he would need to have two stabs at it. Table travel is only about 225mm on a 2A. A 40mm riser is neither here nor there, I would say. My ally riser is about 120mm - and that is on a 2B. The work entailed would be considerable and a decent sized riser would only cost extra material. Could bolt on the other dovetail, I suppose.... |
sean logie | 03/10/2017 22:42:15 |
![]() 608 forum posts 7 photos | Posted by Andrew Johnston on 03/10/2017 22:03:37:
Would have thought a side and face cutter in the Horz mill would hog it out better than using an end mill +1 No point in having a horizontal mill if you don't use it to make swarf; 1" wide cutter and ½" DOC: All my S&F cutters and slab mills are secondhand, via Ebay. Many still had the wax coating,so either new or reground. Don't think I've paid more than £10 for a cutter. Of course there are always the dreamers asking silly money, and cutters with teeth missing, but it should be possible to find decent cutters at a sensible price. I have the wherewithal to sharpen S&F cutters, although thus far I haven't needed to. Andrew That's not a Centec your using ,unless I'm mistaken 😋
Sean
JasonB | 04/10/2017 07:34:05 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by sean logie on 03/10/2017 22:42:15:
Sean
But it is also a much bigger slab of metal, it's all proportional. Also the amount of metal that a S&F cutter can remove before it goes blunt would be quite a bit more before an endmill is past its best so figure in the cost of two or 3 milling cutters to one S&F If I'm right going by past posts this is for a run of QCTP tool holders |
sean logie | 04/10/2017 07:48:06 |
![]() 608 forum posts 7 photos | The steel will be for mounting the vertical head, so I need to try and cut full length dovetails which will be a serious challenge for the little Centec2. I've been speaking to a local engineering firm about them cutting the dovetails . Sean Edited By sean logie on 04/10/2017 07:48:28 |
