Alan Gordon 4 | 30/09/2017 20:49:25 |
129 forum posts 13 photos | Hi Chaps, Any advice on a decent milling vice would be appreciated. Make ,Model where to buy etc. Regards |
Speedy Builder5 | 30/09/2017 21:26:13 |
2878 forum posts 248 photos | Look for one that has both vertical and horizontal "V" machined into the jaws for holding small round bar etc. Usually you have to buy the jaws as an extra. |
John Reese | 30/09/2017 22:10:27 |
![]() 1071 forum posts | I am partial to the Kurt style vises. There are some high quality clones of the Kurt vise available. Its most important feature is the "lock down" movable jaw. I have a jaw with horizontal and vertical V's in it. I rarely screw it in place, just set it into the vise loose. That saves unscrewing the regular jaw. A V block can be used in place of grooved jaws. I recently bought a screwless toolmakers vise for my smaller mill. I don't have much experience with it yet. It seems like a good arrangement. I got the idea from Stefan Gotteswinter's YouTube videos. Both styles of vise eliminate the jaw lift that raises work off the parallels. |
David Standing 1 | 30/09/2017 23:50:51 |
1297 forum posts 50 photos | Posted by Alan Gordon 4 on 30/09/2017 20:49:25:
What size do you need? What is your budget? |
Jon | 01/10/2017 02:02:14 |
1001 forum posts 49 photos | Arc do them but are so annoying to use each and every time clamp something up. Limited travel of a bolt with allen key that rounds off, slacken off eccentric cam drops out fist around to retrieve then line up and start screw off repetitively. Need hammer and allen key to tighten up or wont hold job, same with undoing. |
John Reese | 01/10/2017 04:03:56 |
![]() 1071 forum posts | Posted by Jon on 01/10/2017 02:02:14:
Arc do them but are so annoying to use each and every time clamp something up. Limited travel of a bolt with allen key that rounds off, slacken off eccentric cam drops out fist around to retrieve then line up and start screw off repetitively. Need hammer and allen key to tighten up or wont hold job, same with undoing. I agree If you back out the screw a bit too far the "nut" that engages the grooves in the body drops off and you have to dismount the vise to put it back. To eliminate that problem I replaced the Allen screw with a stud and tall (coupling) nut. It also serves as kind of a handle to help get "nut" engaged in the slot. |
JasonB | 01/10/2017 07:33:50 |
![]() 25215 forum posts 3105 photos 1 articles | I've got a couple of vices for the SX2.7 From ARC and both are Quite nice to use. The Versatile on swivel base has a form of wedge action on the movable jaw that forces it down when you tighten up and also has the bonus of being able to hold quite large thin items due to the additional jaw mounting positions. Quite a large vice so probably not the best thing on a X1 mill! The type 2 precision is a lot more compact so more suited to the smaller machines, Works a bit easier either a "T" type key and you get used to how far to undo the screw, Plenty of traditional vices use a separate handle to tighten so I don't see an issue with a separate key plus if you have the vice mounted along the table the key is a lot easier than a cranked handle. |
Chris Evans 6 | 01/10/2017 09:12:18 |
![]() 2156 forum posts | I have not used or seen one yet but MSC have vices on this months offer sheet. I would have bought one this month but had to buy another read out display for the mill and I like to keep expenditure in the workshop sensible. I use a piece of bar about 35x25x150 with Vee's milled along the length and vertically loose in the vice to hold small rounds. The vertical vee is useful when milling slots in cheese head screws as it always repeats on centre. |
SillyOldDuffer | 01/10/2017 12:02:02 |
10668 forum posts 2415 photos | I invested in a DH-1 and am pleased with it. Unusually flexible, an interesting design. The only downside for me is that it's a tad small on a WM18 (jaws 25x85mm) : the size is probably a positive advantage on a smaller mill. Dave |
Vic | 01/10/2017 12:41:01 |
3453 forum posts 23 photos | I bought a SOBA machine vice which has been very good. I should however have bought it with a swivel base though. |
Howi | 01/10/2017 12:55:38 |
![]() 442 forum posts 19 photos | I got one with a swivel base from Arc, it was the first thing to go( the swivel base that is, the vice itself is very good), I can see no reason to put it back on. I cut a slot I the base of the vice for a key piece that would fit in the slots on the milling table, so I don't have to align the vice every time it is put on the table. Each to his own I suppose
Mike Poole | 01/10/2017 15:52:46 |
![]() 3676 forum posts 82 photos | I have a VMC and have a DH-1 and a 100mm Vertex K4, both meet expectation and are satisfactory. Having entered the water before ARC listed the kurt copies I may have gone for one of those. I think the size of vice should be in keeping with the machine but as big as possible. Going too large can hinder the amount of movement sometimes. Mike A pair of vices can be useful but is quite an expense for the odd job. Direct clamping to the table is very versatile and should always be considered. Edited By Mike Poole on 01/10/2017 15:57:40 |
not done it yet | 01/10/2017 15:59:02 |
7517 forum posts 20 photos | I saw 2 x Abwood 6" milling vises for sale recently. Very good make and these were in very good condition. Maidstone or Maidehead. A bit too big for my needs, otherwise there would only be one for sale now. |
John Reese | 01/10/2017 16:35:51 |
![]() 1071 forum posts | JasonB's suggestions are basically the same as mine, except he referred to specific models. Either type would work well, depending on your preference. The swivel base can be useful occasionally but is really not needed. You can clamp a vise directly to the table at any angle you want. |
Nick Hulme | 01/10/2017 17:20:30 |
750 forum posts 37 photos | Posted by Jon on 01/10/2017 02:02:14:
Arc do them but are so annoying to use each and every time clamp something up. Limited travel of a bolt with allen key that rounds off, slacken off eccentric cam drops out fist around to retrieve then line up and start screw off repetitively. Need hammer and allen key to tighten up or wont hold job, same with undoing. Had one for over 5 years, I can only assume you're using it wrong, I have the threads lubed with MOS2 and clean them each time the vice comes off the mill, I have never come close to rounding the hex in the screw, I don't use cheap hex keys though! |
Nick Hulme | 01/10/2017 17:26:40 |
750 forum posts 37 photos | I also use a pair of these for longer/larger jobs https://trtoolingandmachinery.co.uk/collections/workholding/products/100mm-cnc-modular-precision-vice They are very good,
- Nick |
Jon | 01/10/2017 18:52:16 |
1001 forum posts 49 photos | Had one for over 5 years, I can only assume you're using it wrong, I have the threads lubed with MOS2 and clean them each time the vice comes off the mill, I have never come close to rounding the hex in the screw, I don't use cheap hex keys though! In all fairness i am not a newby learning the ropes. Its the allen key supplied thats rounded off. Not a lover of hammering things like to do it by feel but this is a necessity to tighten these vices up with a limited arc of travel to get a hold on the allen key. |
Michael Briggs | 01/10/2017 19:40:34 |
221 forum posts 12 photos | I have two type 2 Arc vices. They are very easy to use, I have a replaced the cap head screws with a better quality item. As Jason suggested a tee Allen key makes operation a breeze, use a standard type rather than ball end. To release, unscrew about two turns then lever the screw by pushing the key forwards. No connection to Arc, they are one of the better suppliers we have, but not perfect. I have not received a shed load of free goodies from them, just decent service tarnished by a frosty reception when making justified returns. |
Alan Gordon 4 | 01/10/2017 20:19:02 |
129 forum posts 13 photos | Well interesting Topic lads I am contemplating a Vertex 5" / 6" Kurt clone, I would love a Kurt but the Missus wont allow it lol |
Andrew Johnston | 01/10/2017 21:07:42 |
![]() 7061 forum posts 719 photos | I've got a genuine Kurt vice which is excellent, my advice would be to sell the missus and buy the Kurt. Andrew |
