Surface grinding without coolant?
Symon12/09/2017 00:04:58
19 forum posts
Hey all
I'm about to grind the table of my Archdale milling machine as I've been restoring the full machine.
I'm just looking to tidy it up and have the patience to take small grinds.
The thing is...I don't have the flood coolant set up and was thinking of just going dry. Now, this shouldn't be a problem but my last wheel has got me worried as it exploded on a small job! I'd completed a big grind and was doing a small part when it failed. BUT I think this was more to do with the wheel being left unused for over a year (before I acquired the machine) rather than no coolant as my parts never got hot.
Wheels are pricey so I don't want to wreck the new one...and have it go in the middle of the job! laugh
Thanks for your time thumbs up
Rik Shaw12/09/2017 07:44:11
1494 forum posts
403 photos
Can't comment on the grinding wheel part as I'd need to see your setup. As for dry grinding your milling table - I'll assume its cast iron, you should be OK . Use the face mask unless you want to be spitting soot! Keep the wheel grit well open by dressing the wheel often using fast passes from the diamond each time
If you were grinding the steel mag chuck on a surface grinder you would need flood coolant for a "proper" job.
Rik
Edited By Rik Shaw on 12/09/2017 07:48:47
David George 112/09/2017 07:45:34
2110 forum posts
565 photos
Just saw this post. I have been grinding for many years and it is very rare for a wheel to explode but grinding without coolant was non of the ones. The job can expand under the wheel so you get a bigger cut and uneven finnish and if you can get the coolant fixed. The wheel can explode if fitted wrong ie, no paper washers on flanges, uneven tightening, over tightening, or banged or dropped wheel not tested (RING TEST) befor mounting.
David
Tony Pratt 112/09/2017 07:56:44
2319 forum posts
13 photos
If a wheel is not cracked when purchased & checked before fitting correctly & the outside is dressed there is no way it will just fail.
Tony
Symon12/09/2017 09:04:38
19 forum posts
Great replies, guys :D
I got to thinking while doing some research last night. I think, well, it's likely, that the last wheel went because of human err,errr, error indecision Ha!
Like I said, I'd done a big grind beforehand. This was the saddle of a mill and the front side at that. Heavy, unmoving lump. The break happened on a very small part that I had in a very small mag chuck. I think the part (which was tall at the time) has moved and jammed the wheel. POP!
I saw a video during my research that was totally what happened with me.
As for the table I have to clean up...I'll crack on and let yous know. It might not be possible but we'll see. It's all about having fun :D
fizzy12/09/2017 10:43:08
1860 forum posts
121 photos
When I worked for ICI I used to watch the chaps surface grinding and the grinder definately wasnt fitted with coolant
Chris Gunn12/09/2017 12:25:06
459 forum posts
28 photos
When I spent 6 months of my apprenticeship at Timsons on a Jones and Shipman 540, the coolant was used 100% of the time, to avoid burning and extend wheel life as well as keeping the dust down. The same applied to all the grinders in the place, surface and cylindrical.
Chris Gunn
Mike E.12/09/2017 15:12:41
217 forum posts
24 photos
My surface grinder doesn't have a coolant catching tray, but this may work for you ?
A spray bottle from Wilkie's or the pound shop and a piece of fish tank hose could be a simple solution to your issue, which costs almost nothing. Affix it to a convenient location, and add a small clamp to the trigger mechanism and you're in business.
Here are photos to give you a rough idea.
Edited By Mike E. on 12/09/2017 15:14:14
Edited By Mike E. on 12/09/2017 15:14:44
Symon12/09/2017 15:19:40
19 forum posts
That's not a bad idea at all Thanks.
Piero Franchi13/09/2017 08:09:47
124 forum posts
60 photos
I have not done any surface grinding at all.
But I do know from using angle grinders and belt sanders that the parts get hot very quickly.
I would have thought that the flood cooling was to keep the parts being ground from getting warm/hot and expanding and then you would lose your tolerance on the part being ground
Mike Poole13/09/2017 08:26:20
3676 forum posts
82 photos
I would have thought that apart from cooling the removal of debris was an important function of the coolant.
Nick Hughes13/09/2017 09:56:09
307 forum posts
150 photos
You use a different wheel for dry grinding, usually a "White" Aluminium Oxide, with a softer bond compared to those used with coolant.
After all most manual cutter re-sharpening is done dry.
Check out the Norton Abrasives website for details **LINK**
Nick.
not done it yet13/09/2017 11:22:18
7517 forum posts
20 photos
But usually with a bucket of water to keep the tool cool and not likely to the accuracy expected of a surface grinder.
We may cut dry on our lathes but with bigger jobs needing to be accurately turned, we may still need to allow the workpiece to cool before obtaining a good measurement. Horses for course, I say.
Mike E.13/09/2017 11:29:21
217 forum posts
24 photos
Hmmm, I didn't realize that discarding photos made just to reply to a thread would result in them disappearing in posts when deleted from an album.
Tony Pratt 113/09/2017 11:47:07
2319 forum posts
13 photos
Turning, milling & grinding can be performed both wet & dry. How to proceed depends on you, obviously at its simplest coolant cools the machining process & removes debris [dust/swarf].
Neither method is wrong in my opinion.
Tony
Symon27/09/2017 23:53:33
19 forum posts
Update: It's going well. The major over-capacity is my biggest issue as deflection is mad. Obviously.
But, I'm winning by taking it slowly and counter-balancing the machine etc. Looking like 0.001" over 40" (could be 0.002". I'll take that.
But it's a very slow process. We're talking 4-5 hour sittings laugh
Because of the large size I'm also getting unavoidable finish differences, but the joins are seamless.
