3D printed soft jaws
opochka26/06/2017 21:25:55
33 forum posts
5 photos
Hi All,
I have spent some time looking for soft jaws for the 100 mm chucks
that are supplied on mini lathes.
Seems that no one makes them.
I decided to have a bash at 3D printing some jaws, which worked out quite well.
Facing 16mm dia brass washers to 1.5 mm. thick, holding on 1 mm.
800 rpm, depth of cut 0.25 mm. feedrate = very carefully !
The prints slip tightly over the front of the hard jaws, held in place with a M4 screw, which
is screwed into a 6 mm dia brass tube, super-glued into the plastic body.
Good thing about 3D printers is that they can print holes !
Rough and ready video > https://youtu.be/WPengSICgBk
Andrew Johnston26/06/2017 22:06:47
7061 forum posts
719 photos
Neat. thumbs up
Hacksaw26/06/2017 22:34:49
474 forum posts
202 photos
very
Nicholas Farr26/06/2017 22:48:37
3988 forum posts
1799 photos
Hi, I would have liked blue one's myself wink 2. All joking aside, a very good idea.
Regards Nick.
Dave Smith 1426/06/2017 22:57:39
222 forum posts
48 photos
Great idea, just got a new 3d printer at work, that we are calibrating ( read learning how to use it ). So I think a quick CAD session tomorrow morning and print set off.
Neil Wyatt27/06/2017 09:17:27
19226 forum posts
749 photos
86 articles
Excellent, I see a 3D printed bed stop as well!
Gary Wooding27/06/2017 09:50:08
1074 forum posts
290 photos
Very good idea, but don't let the work piece get too hot!
Ian Parkin27/06/2017 09:54:26
1174 forum posts
303 photos
looks good and I wouldnt mind some for my machine if you can go into production but why so much material on the outside of the jaw?
Nige27/06/2017 11:19:00
370 forum posts
65 photos
Very nice
Martin Kyte27/06/2017 11:22:25
3445 forum posts
62 photos
Posted by Neil Wyatt on 27/06/2017 09:17:27:
If I had a 3D printer I could stop in bed as well.
;0)
opochka27/06/2017 18:07:21
33 forum posts
5 photos
Ha Ha !
Yes this saddle stop was a previous 3D printed design, It went through a few iterations to get it correct,
Now it is 20 mm thick water-jet cut aluminium plate, powder coated.
I registered the design, and now it is currently selling as a kit for Mini- Lathes on Ebay.
dave
opochka27/06/2017 18:13:23
33 forum posts
5 photos
Posted by Ian Parkin on 27/06/2017 09:54:26:
I am considering making these kits from solid aluminium plate..or a casting !
There is only 10 mm thickness either side of the chuck jaws, and 10 mm over the end of the jaw to hold the
clamping screw, but as the chuck jaw is hidden it makes it all look disproportionately large !
Michael Cox 127/06/2017 18:39:10
555 forum posts
27 photos
Not having a 3D printer (yet!!!!) I had to make my soft jaws, which clamp onto the outside chuck jaws, using conventional machining methods. Further details are here:
http://mikesworkshop.weebly.com/soft-jaws.html
Nick Hulme28/06/2017 10:35:27
750 forum posts
37 photos
Top Idea! Well done that man!
I've been printing some prototypes in PLA for accessories which clamp onto digital caliper jaws, if you print the holes tapping size and ensure your wall thickness is plenty for the thread depth then M3 grub screws tighten holding the short end of the hex key to the point of finger pain without give or damage to tapped threads.
- Nick
opochka28/06/2017 11:00:42
33 forum posts
5 photos
Posted by Nick Hulme on 28/06/2017 10:35:27:
- Nick
Hi Nick,
I use hips filament mainly, ( High impact poly styrene ) I find this material gives the best crisp and strong prints.
It is also possible to print threads directly into the 3D print, depending on your cad software.
I use Solidworks, put threads in the holes, and the printer prints threads !
Just run a new hss tap down the threads to clean it up, eg. M4 makes a surprisingly strong thread in the plastic.
Don't have to mess about fitting steel nuts inside casings, etc.
dave
richardandtracy28/06/2017 12:45:09
943 forum posts
10 photos
Dave,
Silly SolidWorks question - how do you model the thread? Is it a triangle swept on a multi turn helix or is there something in the hole wizard I've missed? Just trying to find the quickest way of doing it.
Richard
Muzzer28/06/2017 13:35:29
2904 forum posts
448 photos
SW models the threads by default, assuming you use the standard thread wizard. Fusion 360 (and Onshape? I forget) allow you to save computing power by turning "cosmetic" threads off - in many situations, modelled threads serve no purpose even if they look pretty on the screen. Arguably, as long as they are called out on the drawing they don't need to be fully modelled in the CAD. But if you are planning to print them out / save as STL, clearly you want them to be modelled.
Murray
Sorry - to answer your question, you will find the thread wizard if you click the pull down under the hole wizard in the std ribbon. You need a circular feature to point it at eg an existing hole or a sketch, then it has all the data for std metric, imperial etc threads.
Edited By Muzzer on 28/06/2017 13:40:46
David Jupp28/06/2017 13:43:46
978 forum posts
26 photos
Cosmetic Threads are often simply axially patterned circumferential ridges, not a true helix. This reduces load on the computer, but is not of any use for screwing things together. Check carefully before attempting to print.
jimmy b28/06/2017 13:47:09
857 forum posts
45 photos
Interesting, now the shape has been explained. I use fusion360, modelled threads print very well. I've managed to get away with just running a grubscrew through the part. I use PLA. I've made quite a few special form soft jaws. I'd not thought of printing some, untill now!
Muzzer28/06/2017 13:48:16
2904 forum posts
448 photos
About the printed jaws - did you change the settings to increase the density, rather than the default 20% or so fill? Normally the slicer s/w will allow to change the density of the honeycombing. Depending on the size of the part and the machining forces anticipated, it is a tradeoff between the time and cost of printing vs the strength of the jaws.
Murray
