Build a bird feeder
Better than what's on the market
Tractor man20/06/2017 06:09:35
426 forum posts
Hi all.
Replacing another broken plastic bird feeder I added to my to do list by deciding to build a better bird feeder.
Using some alloy scaffold tube and some odds and sods including a stainless steel saucer I came up with a smaller sized copy of the traditional bird feeder which I wanted to use nyger seed in. It attracts gold finches like crazy.
I think it looks smart but what will my feathered friends make of it?
Thor 🇳🇴20/06/2017 06:18:19
1766 forum posts
46 photos
I guess you must have succeded since the bird feeder has already attracted the goldfinches.
Thor
Ady120/06/2017 07:39:50
6137 forum posts
893 photos
There's definitely a niche for bullet/squirrel proof bird feeders
The problem I found was the weight restricts which bush you can hang it on
...I suppose that leads onto building an adjustable height hanger for a bullet proof feeder...
Clive Hartland20/06/2017 08:04:37
2929 forum posts
41 photos
I presume you are having squirrel problems, they are quite clever at biting out the base or even pulling out the pins that hold the base in place.
One, fit a swivel so that the squirrel gets flung off the feeder which will rotate under it's weight. Two, perhaps make a round ball shape wire guard that the squirrel cannot get through. Three, shoot the damn things!
Ady120/06/2017 08:24:56
6137 forum posts
893 photos
There's probably an easy repellent which works for squirrels but I know not what
Male urine (Monkey testosterone) works for foxes and badgers, fill up a bottle, chuck it liberally round the garden and they magically stop digging up your garden and pooping on your back step
Edited By Ady1 on 20/06/2017 08:26:56
Ady120/06/2017 08:35:50
6137 forum posts
893 photos
Squirrels seem to have exceptional gnawing abilities
A friend had them go through a brand new flashing plate on the roof so they could build a nest in his loft, so even that zinc plate stuff (soft alloy?) can't stop them
peak420/06/2017 09:55:24
2207 forum posts
210 photos
I'm having an ongoing battle with the little blighters myself.
They've happily gnawed through the wire mesh of the steel peanut feeder and eaten the plastic feeder holes off the seed dispensers.
I've duplicated the latter with fittings made from some leftover 22mm copper pipe, which has slowed em down a tad, though there's still deep gouges in it.
Next solution was to take the pole off the feeder hangers, and suspend it from a wire hanging out of the neighbour's tree. That failed, they can jump further than I thought. Ho Hum
One much vaunted solution is to add hot chilli powder to the peanut and birdfood mixes; apparently birds don't have chilli receptors, but squirrels do, so I tried liberally coating everything with extra hot chilli oil. The Buxton sub species seem to love Mexican peanuts; I think I'm up to plan G now.
I did make a solid oak bird table with a slate roof, and have slowed them down a bit by blocking the open sides with galv wire mesh, but a couple of times, Jane's found one trapped inside; presumably squeezed in through the mesh, gorged itself stupid and then was too big to escape.
Maybe time to try a longer pole and a Slinky.
Edited By peak4 on 20/06/2017 10:00:08
Nick_G20/06/2017 10:06:17
1808 forum posts
744 photos
Posted by Ady1 on 20/06/2017 08:24:56:
There is. yes
Lead in .22 ins diameter moving rapidly. smiley
Nick
Gordon W20/06/2017 10:47:27
2011 forum posts
I had a friend ,living in the middle of nowhere, who fed red squirrels every morning. He was taken ill and to hospital. The squirrels had eaten through the timber window frames and into the empty house within two weeks. Reds are protected. My problem is crows and magpies steal everything. Got netting everywhere but they are very bright. BTW male urine is scattered every night but has no effect on foxes and badgers, seems to work for deer.
Ady120/06/2017 11:34:57
6137 forum posts
893 photos
Works great for us, maybe it depends on the monkey
Squirrels are heavy for their size because they're solid muscle so a weight driven system like that hilarious slinky video above could be the best solution
A possible ME article of the future...? (if the editor ever gets home)
Gordon W20/06/2017 11:58:13
2011 forum posts
Ady-who are calling a monkey ? I see you live in the south, full of grey things, fed by the tourists.
Clive Hartland20/06/2017 12:10:06
2929 forum posts
41 photos
One of the best deterrents was a metal disc with the seed basket under it, the squirrel would get on the metal disc and it's weight would start it turning until centrifugal force took over. Squirrel flying through the air in all directions.
As said, a metal projectile solves the problem except for disposal.
V8Eng20/06/2017 12:33:51
1826 forum posts
Posted by Gordon W on 20/06/2017 11:58:13:
Stop being rude about us southern grey haired pensioners, I do not get fed by tourists either!laughwink
Edited By V8Eng on 20/06/2017 12:34:08
Neil Wyatt20/06/2017 16:10:41
19226 forum posts
749 photos
86 articles
Chilli powder, birds can't taste it.
N.
David Standing 120/06/2017 16:14:41
1297 forum posts
50 photos
+1 for sending them a lead snack wink 2.
It is no coincidence that all three of my air rifles are zeroed at the peanut feeder range teeth 2.
David Standing 120/06/2017 16:15:47
1297 forum posts
50 photos
Posted by Clive Hartland on 20/06/2017 12:10:06:
That's what local councils introduced wheelie bins for! smile p
colin hawes20/06/2017 16:56:51
570 forum posts
18 photos
After squirrels repeatedly gnawed holes through the plastic base on a bird feeder I replaced the plastic part with a home made metal one. Pleased with myself, the next morning I looked out of the window to see a squirrel in the final stage of separating the whole thing from the tree by chewing through the rather thin twig the wire suspension was looped over and running off with the whole feeder.. I never did find it. These amusing varmints get most of the nuts from my hazel trees every year too by pinching them well before they finish ripening. They seem to be cleverer than me. Colin
duncan webster20/06/2017 19:10:05
5307 forum posts
83 photos
How about supporting the feeder on 2 metal posts close to each other, but insulated, and connected to an electric fence pulser
Neil Wyatt20/06/2017 19:38:03
19226 forum posts
749 photos
86 articles
Posted by colin hawes on 20/06/2017 16:56:51:
A hedge with ripe hazelnuts has become a thing of the past, sadly.
modeng200020/06/2017 19:39:27
340 forum posts
I have tried the electric fence idea but the squirrel just hung on eating the nuts and jerking each time the feeder was impulsedfrown
