Soldering gun, not iron.
vintagengineer10/04/2017 20:50:57
469 forum posts
6 photos
Can anyone recommend a good quality soldering gun. Cost isn't an issue as my customer is paying for it.
I am rewiring a car and I need something that is quick and reliable!
Michael Gilligan10/04/2017 21:02:03
23121 forum posts
1360 photos
Posted by vintagengineer on 10/04/2017 20:50:57:
Weller works fine for me.
http://www.mytoolshed.co.uk/p9780/Weller_8100UD_Expert_Soldering_Gun/product_info.html?utm_source=googleversafeed&vfsku=9780&gpla=pla&gclid=CLz7y7zXmtMCFYoK0wodJrYCiw
Edited By Michael Gilligan on 10/04/2017 21:03:53
vintagengineer10/04/2017 21:03:39
469 forum posts
6 photos
Which model of Weller gun is that?
Michael Gilligan10/04/2017 21:05:17
23121 forum posts
1360 photos
Just posted the link
P.S. ... At the risk of stating the obvious: they only work on AC
Edited By Michael Gilligan on 10/04/2017 21:06:03
Muzzer10/04/2017 21:28:16
2904 forum posts
448 photos
It's a bloody big transformer that sends a big fat current through the bit to heat it up dead quickly.
Peter Krogh10/04/2017 21:32:31
228 forum posts
20 photos
I have a Well 125 gun that I purchased in 1965 and it works just fine. Wonderful fast!  Very simple. Not much to go wrong!!
Pete
Edited By Peter Krogh on 10/04/2017 21:33:16
Michael Gilligan10/04/2017 21:40:51
23121 forum posts
1360 photos
Posted by Muzzer on 10/04/2017 21:28:16:
Yup yes
Nowt much to it ... but it works.
Bob Brown 110/04/2017 22:07:14
1022 forum posts
127 photos
A friend of mine uses a hot air soldering gun for soldering car electrics.
Gordon W11/04/2017 09:32:17
2011 forum posts
I use a mains type also, it heats up quickly and copes with car wiring easily, maybe not battery cable. The little light I thought was a gimic is useful. It's little Draper, from memory Also has the advantage of not using power when it's idle.
MW11/04/2017 10:47:55
2052 forum posts
56 photos
Please forgive my total ignorance on this topic but i'd like to ask,
What advantages does a gun type iron have over a normal iron?
Michael W
Speedy Builder511/04/2017 11:03:33
2878 forum posts
248 photos
Out of choice, I wouldn't solder as over time, the wire snaps just at the solder joint, I don't know why (Flux ?), but it has failed me on a couple of vintage car re-builds. Funny how the old screw down connectors (Typical Lucas type) seem to go rusty, corrode and still work. The cheap crimp terminals are made of thinner metal than top quality terminals and the cheaper ones with bullet ends are frail especially when you pull them appart a couple of times.
BobH
Muzzer11/04/2017 11:14:39
2904 forum posts
448 photos
Posted by Michael-w on 11/04/2017 10:47:55:
Michael W
Doesn't need to be left on, ready to start fires and cause nasty burns. And by heating up rapidly, it isn't an inconvenience. Not much use for small surface mount components but for through hole compts and sticking bits of metal together they are apparently pretty handy.
Here's another rather earnest Canadian* (I'm guessing by his accent), explaining how they are useful:
*Universally Challenged (Monkman) reference
Neil Wyatt11/04/2017 11:17:40
19226 forum posts
749 photos
86 articles
Posted by vintagengineer on 10/04/2017 21:03:39:
<grease>
Weller! Weller! Weller!
Tell me more! Tell me more!
</grease>
I'll get me coat...
peak411/04/2017 11:19:07
2207 forum posts
210 photos
Posted by Speedy Builder5 on 11/04/2017 11:03:33:
BobH
I believe the solder tracks back up the multi-cored wire and acts as a stress point where it stops, hence the need for strain relief incorporating the outer insulation.
Personally, I think the problem is often too much solder, rather than too little; frequently caused by an iron with too little heat capacity.
That is, one needs to offer the iron to the joint for too long to get it hot enough to melt the solder, thereby heating up too much of the wire, albeit slowly; this allows the solder to track too far up the wire.
It's not just about speed and cost that the highest quality, mil spec, connectors tend to be crimped rather than soldered.
Bill
Ian S C11/04/2017 12:01:52
7468 forum posts
230 photos
I have a Weller soldering gun, but prefer an ordinary electric iron, I have a choice of 80 year old 65 W Solon, or a 175 W Weller. I find the gun really has insufficient amount of metal in the heated area to make a good joint quickly, I remember having the same problem 50 years or so ago on the few soldered joints required on wires on some of the aircraft I worked on. The solder tends to make copper wire brittle.
Ian S C
pgk pgk11/04/2017 12:15:28
2661 forum posts
294 photos
We used to use the weller guns for quick and dirty cautery in the late 60's but if you didn't want to get bitten was a good idea to make sure plenty of anaesthetic about. The tips used to burn out quite quickly though - a corrosive effect of burn blood and tissue or just the temp of burning carbon?
Mike Poole11/04/2017 12:31:57
3676 forum posts
82 photos
Posted by peak4 on 11/04/2017 11:19:07:
BobH
Bill
+1 for those observations Bill, it is remarkable how far the solder will wick up the cable if too much solder is applied, the insulation retreats as the wire is heated so exposes a stress point. I believe crimp connectors are more reliable by quite a high factor. In control panel wiring there seems to be a move to spring clamp connections with bare ends to the wire, in my experience these are very reliable and cheap to install as they are quick compared to lugging a cable and screwing into a terminal. The downside of many wiring systems is that the cable and terminations should be of a matching spec to create a sound connection, too often people use what they have and the connection will be compromised.
vintagengineer11/04/2017 13:07:36
469 forum posts
6 photos
When you laying under a dash board upside down with your arse in the air, the last thing you want is hot soldering iron adding to your predicament!
Michael W
SillyOldDuffer11/04/2017 14:46:50
10668 forum posts
2415 photos
Posted by Mike Poole on 11/04/2017 12:31:57:
BobH
Bill
I've got a 1980's write-up on this somewhere that from memory pretty much confirms what you say. Soldering isn't the best way of making a cable joint if the wiring is subject to vibration, flexing or thermal contraction. Crimping was said to be much more reliable than soldering but it had to be done properly. I remember wire-wrap was supposed to be 'good' too, but that technology seems to have disappeared entirely. I wonder why?
Mike Poole11/04/2017 15:34:00
3676 forum posts
82 photos
Wire wrapping does seem to have fallen by the wayside, I had a fault on a robot once where I had to get the entire card cage out to access the backplane which was wire wrapped, turned out that the wire was too tightly pulled against one of the posts and had shorted out, took seconds to fix but half a day of diagnosis and dismantling. I think wire wrapped backplanes have fallen out of use for a number of reasons, multi-layer PCB backplanes with plated through holes are much less labour intensive and equipment seems to be more modular with either ribbon cable interconnections or fast serial links. LSI has also put much more onto one board so racks of cards are less common.
