MW | 09/02/2017 16:30:17 |
![]() 2052 forum posts 56 photos | Hi, Bit of an armchairneering/ ends and oddments kind of post, but.. Heres a silly question that occurred to me today, why, when people frequently paint castings/metal slides for lathes and machines, do they not consider painting their chucks as well? Are they prone to damage? They certainly rust. (painting could look awful on a chuck if it wasn't done properly). Just an interesting idea, but I've never seen anyone do it. I read this story today about a man who died a couple of years ago as a result of trying to machine a piece of stainless pipe that threw itself off the lathe, machining tube is certainly to be done with caution and everything properly secured, fixed steady or tailstock centre comes to mind.. He was only rubbing it down or cleaning up the outside of it, albeit unsecured on one end. (1.5M long!) so it was definitely a big lathe. A tragedy for him and his relatives but also another reminder to us to be careful about what we try, I know some of us have big machines but we can get over familiar with our equipment and it leads to this potentially. The force that threw it out was enough to pierce his skull and brain. Stay safe.. P.S, I actually avoid machining pipe if possible due to how unpredictable it can be. Michael W Edited By Michael-w on 09/02/2017 16:36:26 |
Ian Parkin | 09/02/2017 16:51:39 |
![]() 1174 forum posts 303 photos | Whilst a certain tragedy for the chap it sounds like an accident was inevitable a 4ft tube sticking out the chuck unsupported and only in the chuck 1.5 inch |
I.M. OUTAHERE | 09/02/2017 17:14:49 |
1468 forum posts 3 photos | Sometimes i use the surfaces of the chuck as reference points or to set the toolpost square to the centre line of the lathe for parting and painting would make this impossible besides the fact it would look UGLY ! Ian |
Martin 100 | 09/02/2017 17:23:13 |
287 forum posts 6 photos | Lots of hazards operating and working around machinery. We've all probably at some time had bits come loose in the chuck, tools dig in and shatter, dropped chucks etc resulting in bad language, cuts, blood blisters and bruises, some like the case above have sadly come off far worse. One quite prominent youtuber who really should know better was recently observed using scotchbrite to clean up a part with obvious ragged edges maybe 1/4" further in the recess from the internal diameter he was cleaning up. Something you might get away with on the bench. In a lathe, under power, and using your finger to poke the scotchbrite into the hole then its just the luck of the draw as to what happens next. The bloke was totally oblivious to the hazards and actively displaying this method of working as part of his skills without even a slightest inkling that someone else might try and copy his method of working and not be so lucky. P.S. Within limits a rusty chuck body clearly works just as well as a non-rusty one. The bits that matter are oiled or greased. |
Hacksaw | 09/02/2017 17:27:05 |
474 forum posts 202 photos | That "Industrial lathe accident " on youtube gives me the willies !! |
Nick_G | 09/02/2017 17:59:36 |
![]() 1808 forum posts 744 photos | . I would not consider painting a chuck for the reason given by XD 351. i.e. it's a valuable ref point and would look as ugly as naked fat bird sat on a stool. I find the best way to keep a machine free of rust is to use it.! As for 4ft sticking out of a chuck unsupported. It was never going to end well now was it. ............. Very 'Darwinian' IMHO Nick |
MW | 09/02/2017 18:21:14 |
Posted by Nick_G on 09/02/2017 17:59:36: .it's a valuable ref point and would look as ugly as naked fat bird sat on a stool. Nick Ah well, you never know Nick. Some of us may be quite partial to that. I used to use a leather faced, and copper mallet to knock the cam-lock chucks off the big boy lathes onto a wooden cradle. I guess with the size of it and the rather seizing fit that took hold on the recess, you could say unless you were the hulk it was totally necessary to hit the chuck in order to do the job. In that case, no question it would chip. But for the more dainty chucks, what situation occurs, other than handling, where you need to smack your chuck? Unless you're hitting it under power, which is obviously bad practice. Is there any reason why it should be damaged provided you're using it properly. There is the chuck key that could cause wear but unless you have a really bad aim, you wont be hitting the chuck body. I would agree, this certainly warrants a better quality of paint than your regular brands, but I think it could look good if you used a hard wearing glassy coat of enamel. I say again, is a rusting surface, shouldn't be struck(provided you aren't covered under the aforementioned handling and fitting procedures of big lathes), It could look good? Theres potential reasoning there, I give it that much. Michael W |
MW | 09/02/2017 18:24:22 |
![]() 2052 forum posts 56 photos | I should add I have an eternal fight trying to keep my four jaw from rusting using a variety of different preservatives, I haven't found one that's worked for more than a week yet. My three jaw I can just about manage to keep the rust at bay, despite a few flecks occurring now and again. But with the four jaw it ravages it like a monster. Anyone tried a varnish? If it looked as smooth and shiny as say, a new car, tell me you'd not be at least be tempted? Michael W Edited By Michael-w on 09/02/2017 18:27:58 |
Rick Kirkland 1 | 09/02/2017 18:28:59 |
![]() 175 forum posts | Forget paint, , chucks would look beautiful Blued. And rust resistant. T I C posting, , let's not have the pedantic posters go getting uptight. |
not done it yet | 09/02/2017 18:42:20 |
7517 forum posts 20 photos | That "Industrial lathe accident " on youtube gives me the willies !! I've watched that before. Nothing really to do with pipe. His loose clothing rippied off him. He was lucky it was a pipe, perhaps, or he could have been going round with the chuck and pipe!
Roger Williams 2 | 09/02/2017 18:45:51 |
368 forum posts 7 photos | Its quite possible he only intended doing this at a very low RPM, still daft I know, and perhaps forgot that it was in high range....... Referring to the fatal accident at the beginning. Edited By Roger Williams 2 on 09/02/2017 18:49:44 |
MW | 09/02/2017 18:53:16 |
![]() 2052 forum posts 56 photos | Well back on topic number two, The coroner said (not a machinist I know) that he appeared to believe that what he was doing would be safe. It sounds like a big lug or fabrication was welded to the pipe. The piece was gripped 40mm deep on the lug end with the open tube facing downwards towards the tail end. So he believed that this would be adequate to support it. To be honest, given how long it is, it doesn't sound like this was an operation he'd done before. Because at 1.5M, i'd imagine the runout would be horrendous. I would've atleast used a fixed steady on this setup if it were available. However, i'm not going to go judging or condemning him as hindsight is a wonderful thing and i'm not closely involved with what happened. But it did scare me slightly. As I have had a piece of much shorter copper tube come off the lathe in the past. And that did have a steady. I'm still in one piece obviously but it hit the roof of my shed. And was bent inwards by quite a margin. Michael W Edited By Michael-w on 09/02/2017 18:54:57 |
daveb | 09/02/2017 18:55:33 |
631 forum posts 14 photos | I treat bare iron and steel surfaces with beeswax furniture polish, works well on chucks, handles and handwheels. Dave. |
MW | 09/02/2017 18:59:20 |
![]() 2052 forum posts 56 photos | Posted by daveb on 09/02/2017 18:55:33:
I treat bare iron and steel surfaces with beeswax furniture polish, works well on chucks, handles and handwheels. Dave. Good to know, I might try that. I have some carnuba wax that may give a similar sealing effect. Michael W |
Nick_G | 09/02/2017 19:29:07 |
![]() 1808 forum posts 744 photos | Posted by Michael-w on 09/02/2017 18:21:14:
Is there any reason why it should be damaged provided you're using it properly. Michael W . Swarf.. ............ You know that sharp abrasive by product you get from a lathe when you use it.
Nick |
JasonB | 09/02/2017 19:37:52 |
![]() 25215 forum posts 3105 photos 1 articles | Do you never tap a machined side of a piece of work back against the chuck face so it sits true to then machine the other side? Or I often put a couple of parallels against the chuck face and push the work up against that to again set the machined face true. Can't see that working once you have slapped a thick uneven coat of glossy enamel onto it. I find that keeping chucks in te cabinet under the lateh does not help with rusting as they stay cold and any moisture in the workshop as it warms up such as your breath or from cutting fluid will condense out on teh cold metal. J |
MW | 09/02/2017 20:05:30 |
![]() 2052 forum posts 56 photos | Posted by JasonB on 09/02/2017 19:37:52:
Do you never tap a machined side of a piece of work back against the chuck face so it sits true to then machine the other side? Or I often put a couple of parallels against the chuck face and push the work up against that to again set the machined face true. Can't see that working once you have slapped a thick uneven coat of glossy enamel onto it. J(asonB) You got me JasonB, I admit defeat. I do use parallels occasionally on the chuck face. I guess i'll just have to do with rusty old iron. Michael W
vintagengineer | 09/02/2017 20:11:25 |
![]() 469 forum posts 6 photos | With regard to the lathe accident I was always taught to always put a centre in, if the amount sticking out exceeds the amount being held. Even when you are facing the material! |
not done it yet | 09/02/2017 20:22:54 |
That is why I have installed a small dehumidifier in my small partitioned-off and insulated workshop area. Just works a few hours at night on E7, but warms and dries it sufficiently to avoid condensation. Probably need air con in the summer! Re painting - no item that may show signs of failure (before actually failing, hopefully) should be surface coated with paint. This is apart from the aethsetics and practical problems of alignment with other parts. Blueing or blacking would be acceptable, but expensive - and eventually wear in places. I know I would not operate a chuck if there were any signs of cracks developing. |
peak4 | 09/02/2017 20:31:53 |
![]() 2207 forum posts 210 photos | Re. Rust proofing, not tried using it on chucks, but Motorex 645 aerosol works well on the various bikes. I'm still using old stock, but I believe This Is The Same Stuff, just renamed. |
