Push Button oiler ball Stuck!
Mark Eisen | 15/01/2017 08:05:20 |
![]() 88 forum posts 68 photos | One of the Push Button oilers ball is stuck in my lathe. The lathe is a Steelmaster SM-0920V 9 X 20 , PS How do I post a photo?
Edited By Mark Eisen on 15/01/2017 08:07:56 |
Brian H | 15/01/2017 08:54:55 |
![]() 2312 forum posts 112 photos | Thick grease or glue on the end of a thin rod or even a BBQ skewer? Best of luck with it anyway. Brian |
Speedy Builder5 | 15/01/2017 09:07:29 |
2878 forum posts 248 photos | I don't know how big the hole is, but could you suck it out - Get a small plastic tube (Inside of an empty biro) and tape this up to your hoover pipe, then try to suck it out. The ball may be stainless and non magnetic ? |
Thor 🇳🇴 | 15/01/2017 09:13:05 |
![]() 1766 forum posts 46 photos | Hi Mark, I agree with Brian, try with a bit of glue on a rod. To post photos, see this thread. Thor |
Brian Wood | 15/01/2017 10:02:34 |
2742 forum posts 39 photos | Mark, |
Brian Wood | 15/01/2017 10:45:46 |
Gordon W | 15/01/2017 10:56:52 |
2011 forum posts | First find out where the little ball has gone- might be in a vunerable place. |
peak4 | 15/01/2017 11:16:50 |
![]() 2207 forum posts 210 photos | Depends where it is, can you get to the other side of the orifice, even indirectly, with an air line. If so, try blowing it out, with a rag to catch the ball; a) so you don't lose it, b) to avoid shooting next door's cat . |
Michael Gilligan | 15/01/2017 11:43:02 |
![]() 23121 forum posts 1360 photos | Posted by Brian Wood on 15/01/2017 10:45:46:
. Brian, Conceptually, that's a great idea, but [even as a Loctite enthusiast] ... I suspect that you might need to insert "engage the Infinite Improbability Drive" somewhere in that closing line. **LINK** http://hitchhikers.wikia.com/wiki/Infinite_Improbability_Drive ... In all honesty, I think the vacuum pipe is more likely to succeed. MichaelG.
mark costello 1 | 15/01/2017 17:43:52 |
![]() 800 forum posts 16 photos | Vacuum and pressure. Make it irresistible. |
Rik Shaw | 15/01/2017 18:51:44 |
![]() 1494 forum posts 403 photos | " run a self tap screw into it and pull the whole thing out with nail pincers" Thanks for that Brian - I have a couple of stuck balls on my lathe so I'll use your method to remove them. They seem to be reasonably cheap on ebay so I'd better get some in. Rik |
daveb | 15/01/2017 18:57:46 |
631 forum posts 14 photos | It's probably not worth spending too much time on a damaged one, they are available at modest cost in Metric and Imperial sizes from a number of model engineering suppliers. |
Mark Eisen | 16/01/2017 09:45:24 |
![]() 88 forum posts 68 photos | Sorry about being blurred trying to get a close up, but the is what it should look like. |
Mark Eisen | 16/01/2017 09:47:29 |
Here is the stuck ball I think the silver/shiny bit on the L/H is the spring. Edited By Mark Eisen on 16/01/2017 10:09:21 |
Mark Eisen | 16/01/2017 09:49:58 |
![]() 88 forum posts 68 photos | Old and new Push Button oiler. I screwed a self tapper in to the old one and used a claw hammer to lever it out.
Mark Eisen | 16/01/2017 09:53:14 |
![]() 88 forum posts 68 photos | The next two photos are from the very high quality loose leaved chinglish manual that came with it. PS I just worked out how to add more than one pic at a time to a post.
Edited By Mark Eisen on 16/01/2017 10:12:22 |
Mark Eisen | 16/01/2017 10:03:04 |
![]() 88 forum posts 68 photos | I have bought 20 X 6 mm Push Button oilers for $4.43 |
Mark Eisen | 24/01/2017 06:20:46 |
![]() 88 forum posts 68 photos | Success at last.
The two cup-head screws that hold the apron on.
Mark Eisen | 24/01/2017 06:22:43 |
Here is the culprit, some reason it had a double spring it was the one on the left I could see.
Good as new.
Thank you every one for all you help and advice. |
David Taylor | 24/01/2017 22:05:25 |
![]() 144 forum posts 39 photos | Thanks for the link! My lathe has the same problem. I'll get some as soon as the seller gets back. |
