Milling Slots
Milling neat slots in Gauge Plate
simon Hewitt 121/11/2016 11:05:27
44 forum posts
10 photos
I need to mill slots in 2 pieces of Gauge plate 1/8" thick. Slots are 3/32 and 1/2" wide and about 1" long (to make the base of a slide valve chest). I cannot get them neat,parallel, straight! what advice? I always seem to get the end cutting wider than the main length, or changing width along the cut, ....
not done it yet21/11/2016 11:21:33
7517 forum posts
20 photos
Initially more narrow than required finished size, then clean up the slot sides to size. That is if all other tnings are satisfacory - support, rigidity of machine, tool quality, axes tightened down, etc
Nick_G21/11/2016 11:22:46
1808 forum posts
744 photos
Posted by simon Hewitt 1 on 21/11/2016 11:05:27:
Have you got the table locked down in the axis you are not moving the cut in.?
If so are the gibs in the axis you are moving adjusted to give as little play / movement as possible while still remaining smooth to axis movement.
Nick
Neil Wyatt21/11/2016 11:42:30
19226 forum posts
749 photos
86 articles
Unless you are taking very shallow cuts a 3/32" cutter will flex on a tough material like gauge plate, especially if you are using an end mill rather than a slot drill.
Try using a short 1/16" FC3 cutter to mill out the centre then take a skim off each side.
Hopper21/11/2016 12:44:12
7881 forum posts
397 photos
As mentioned already, use a two-flute slot drill rather than a four-flute end mill when milling slots.
Chris Evans 621/11/2016 13:23:55
2156 forum posts
O1 (gauge plate) is a bitch to machine even after years of experience so don't lose heart. Do as suggested and make sure gibs are adjusted/table locked and use a slot drill.
JasonB21/11/2016 16:15:06
Real question is why does it have to be gauge plate?
Bit of Mild steel would do or better still slice off the end of a bit of round cast iron, flat brass strip or plate.
If you must go with gauge plate then I would first drill the two ends of the slot 3/32, rough out the middle with a 2mm FC-3 cutter and then finish off with a 2-flute 3/32" cutter at 1/32" depth per pass.
simon Hewitt 121/11/2016 16:21:48
44 forum posts
10 photos
because I have some, and if I get it right, it will last forever.
But if I cannot get it right, i may start again with brass.
Tony Pratt 102/04/2017 12:29:34
2319 forum posts
13 photos
Posted by simon Hewitt 1 on 21/11/2016 16:21:48:
It make take forever to get it rightwink Seriously for this application you would be better off using brass or mild steel.
Tony
Ian S C02/04/2017 12:47:08
7468 forum posts
230 photos
The gauge plate is susceptible to rusting, more so than mild steel, and even if your steam engine is only used with air, it will be subject to condensation.
Ian S C
JasonB02/04/2017 13:27:57
Denbeigh Drill question moved to here
ronan walsh02/04/2017 14:18:38
546 forum posts
32 photos
Have you considered having it wire edm'ed ? But as people here have said, gauge plate rusts like billy-oh.
