Andrew Tinsley | 19/11/2016 12:26:35 |
1817 forum posts 2 photos | Many years ago, I had a tin of casting filler from Myfords, to smarten up my ML7 lathe. At last I am getting around to restoring my ML7. I have long ago lost the tin. It was mainly coloured black with some red and yellow. I think it had the picture of an imp on the front, although my memory may be at fault. The name was something like Trimar------? Does this ring a bell with anyone and is the product still available? I ask because the guy responsible for preparing the lathe castings for painting, said it was by far the best product for filling castings. You might be surprised at what a Myford bed looks like before it is filled. There is quite a lot of filler used before it is passed for painting! Am I being too fussy here and should I just use car body filler for my restoration job? Andrew. |
Monoman | 19/11/2016 13:12:40 |
51 forum posts 7 photos | I think you will find the product was made and supplied by Trimite in Uxbridge. I worked there for some years. They amalgamated with Weilburger a while ago but you will find them under the Trimite name, now located in Hayes Middlesex. If you call their technical advice centre you might be able to track down the product they sold to Myford in Nottingham. Mono
mark smith 20 | 19/11/2016 13:37:38 |
682 forum posts 337 photos | Ive painted alot of old machines and i always found car body filler a pain to sand and it also shrinks. I tend to only use it on big defects ,the rest i just use that fast drying high build zinc primer (far easier to sand and stays put better. |
not done it yet | 19/11/2016 14:08:05 |
7517 forum posts 20 photos | If that is the same crew as supplied Raglan with surface coatings, don't bother. They only supply to industry, fail to respond to emails, etc. Basically don't want to know, or hear from, individuals. Car body filler is the best bet. Used by many for years and years. Edited By not done it yet on 19/11/2016 14:10:15 |
Neil Wyatt | 19/11/2016 15:17:34 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Andrew Tinsley on 19/11/2016 12:26:35: You might be surprised at what a Myford bed looks like before it is filled. There is quite a lot of filler used before it is passed for painting! It amused me when recently someone posted a moan that a casting on a Chinese lathe had filler on it. Generally only better quality items have the castings tidied up before painting... Neil |
DDT | 19/11/2016 16:43:48 |
9 forum posts | I've no connection to either company but Rapid Electronics and I'm sure loads of other companies sell Loctite EA 3471 or EA 3479 metal filled compounds. The aluminium variety worked a treat in reclaiming a porous casting for me, the only downside is the cost if it's just for cosmetic reasons. (allegedly some humans spend more on beauty products every week !)...........DDT Edited By DDT on 19/11/2016 17:02:07 |
Ian S C | 20/11/2016 10:22:36 |
![]() 7468 forum posts 230 photos | I have a tin (about 800g) of Scols Super Iron Cement, it's a grey powder that is mixed with a small amount of water to make a putty . Ian S C |
JA | 20/11/2016 12:46:02 |
![]() 1605 forum posts 83 photos | Was not water glass once used to fill aluminium casting defects? I think I was casually told this during my apprenticeship when trying to cast a screwdriver handle. I know that my mother used it to preserve eggs before we had a fridge when I was a kid. JA |
Nicholas Farr | 20/11/2016 13:57:11 |
![]() 3988 forum posts 1799 photos | Posted by Neil Wyatt on 19/11/2016 15:17:34:
Posted by Andrew Tinsley on 19/11/2016 12:26:35: You might be surprised at what a Myford bed looks like before it is filled. There is quite a lot of filler used before it is passed for painting! It amused me when recently someone posted a moan that a casting on a Chinese lathe had filler on it. Generally only better quality items have the castings tidied up before painting... Neil Hi, it's not only castings that get filler before painting, I've seen industrial machines where thick steel plates have been profiled out with Oxy/Acetylene and were filled with body filler where the cut gouged out a notch along the edge, due to impurities in the steel. It's not until the paint gets chipped over time during use, that you are able to notice them. Regards Nick. |
Gordon W | 20/11/2016 14:36:14 |
2011 forum posts | When I was a lad common putty was used as a filler, but not mentioned. Water glass ,sodium silicate from memory, mixed with iron filings also common. The iron rusts and the mix goes hard, more expensive than putty tho'. Is good for egg preserving also. |
Muzzer | 20/11/2016 15:27:12 |
![]() 2904 forum posts 448 photos | Aha. Sodium silicate / water glass! Best used for making chemical gardens. That takes me back a few years... The Mercans seem to love "restoring" old machine tools and being Mercans, they care more about looks than action. From what I've seen over on hobby-machinist.com, the preferred method is to use body filler to get a smooth finish, then paint over. The results are often pretty impressive but I'd rather spend the time and effort fettling the mechanical parts myself. |
Adam Phillips | 20/11/2016 15:35:46 |
![]() 47 forum posts | If you want to make a filler that easy to sand then mix epoxy with glass bubbles . It a filler used in boat building. |
Scrumpy | 20/11/2016 16:35:54 |
![]() 152 forum posts | Some years ago I rebuilt a milling machine and filled the castings with a product called Belzona this firm have agents all over the uk |
SillyOldDuffer | 20/11/2016 17:07:08 |
10668 forum posts 2415 photos | For traditionalists:
Take care if you come across an old casting that appears to have been beautified with solder - Antimony is poisonous. Dave
Neil Wyatt | 20/11/2016 17:33:13 |
![]() 19226 forum posts 749 photos 86 articles | Posted by SillyOldDuffer on 20/11/2016 17:07:08:
Take care if you come across an old casting that appears to have been beautified with solder - Antimony is poisonous. Not as poisonous as the lead |
SillyOldDuffer | 20/11/2016 18:17:25 |
10668 forum posts 2415 photos | Posted by Neil Wyatt on 20/11/2016 17:33:13:
Take care if you come across an old casting that appears to have been beautified with solder - Antimony is poisonous. Not as poisonous as the lead Well, maybe. My book gives an LD50 of 100mg/kg for Antimony (rats), whereas Lead 'just' gets a mention as a carcinogen and teratogen. Both are more dangerous when heated and both make many poisonous compounds. Where I am on thin ice is that the Antimony is in an alloy - might be trapped like Mercury in fillings. Lead is cumulative though. Needs to be tested - can you suggest anyone to experiment on! |
Neil Wyatt | 20/11/2016 19:47:43 |
![]() 19226 forum posts 749 photos 86 articles | Wkipdia is interesting, it says: "The elemental antimony metal does not affect human and environmental health. Inhalation of antimony trioxide (and similar poorly soluble Sb(III) dust particles such as antimony dust) is considered harmful and suspected of causing cancer." en.wikipedia.org/wiki/Antimony#Precautions Neil |
SillyOldDuffer | 20/11/2016 20:19:48 |
10668 forum posts 2415 photos | My source is the 5th edition of ‘Dangerous Properties of Industrial Materials’. Heavily abbreviatiated: ip = ‘intraperitoneal’, sc = ‘subcutaneous’, im = ‘intramuscular’, LD50 = concentration required to kill 50% of a population, LDLO is the lowest published lethal concentration, THR is the summary toxicity statement, acute unless otherwise stated. HIGH means ‘Capable of causing death or permanent injury due to the exposures of normal use; incapacitating and poisonous; requires special handling. For Antimony: Acute tox data: Oral LD50 (rat) = 100mg/kg; ip LDLO (rat) = 100mg/kg In comparison, Arsenic: Acute tox data: im LDLO (rat) = 25mg/kg; sc LDLO (rabbit) = 300mg/kg; Tasty stuff! Dave |
Ian S C | 21/11/2016 09:19:22 |
![]() 7468 forum posts 230 photos | When I was at school we spent the last few days of the school year stripping, and painting the workshop machines, the old Harrison lathes seemed to be more filler than casting, there were more holes than Swiss Cheese. Ian S C |
Muzzer | 21/11/2016 09:49:27 |
![]() 2904 forum posts 448 photos | "Toxicity" is not a simple term. Salt is toxic in large quantities but essential in small. Similarly, many other "toxic" elements are essential for correct functioning of the body. And there are a lot of different "toxicities". Much of the LD50 toxicity data is based on (lethal) injections into rats and while they give a fair indication of the likely toxicity in humans, it's not always the case. We have not been allowed to carry out the same tests on humans, even in the interests of science. Either way, we are very unlikely to find ourselves injected with 10g of Antimony (100mg/kg x 100kg) into the peritoneum - and if we did, we'd probably get down A&E before too long, to get it fixed. The elements we call "heavy metals" tend to bioaccumulate in the tissues and bones. These may not kill us immediately but cause some pretty unpleasant effects. LD50 data is not particularly helpful there unless you are trying to end it all quickly. Metalloids (including arsenic) and radioactive elements also have undesirable effects. |
