Member postings for Adam Phillips
Here is a list of all the postings Adam Phillips has made in our forums. Click on a thread name to jump to the thread.
Thread: Cast Iron Watch Case
04/01/2020 19:17:49
Damascus Steel would get my vote. If you really want to get interesting try meteorite if you can find one. There are a few watches shown on Instagram made of it
Good luck Adam
Thread: Disposal of workshop contents
03/09/2019 15:19:25
Have you not thought of maybe selling as an already setup business. Just a thought
Thread: Lorch LAS lathe
08/07/2019 18:18:34
Thanks Dave
thank for the heads up I will leave it well alone turning the spindel by hand it all seems to run very smoothly. The Lathe has not been powered up for over ten years and the belt looks ok but with counter shaft and original belt the machine will be to deep for my bench
08/07/2019 17:17:51
Hi All
Now the 918 is on its way to Ron's house I want to get on with sorting my new to me 1958 Lorch LAS. the first thing will be to strip the Head stock spindel for a good clean and the fit a new belt. So my question is Has anyone done this before and are there any particular pitfalls to look out for. I have the manual from lathes.co.uk which is a good start
Thanks in advance Adam
Thread: My new lathe a Warco 918
04/07/2019 11:14:52
Hi Ron. There is a lot of information on the yarhoo 920 forum that I found very good. If you google 9x20 lathe or youtube there are hundreds of posts. Stephan gotteswinter on youtube did an amazing job on a very similar lathe about 3 years ago
Best Adam
Thread: Classified For Sale
03/07/2019 16:34:24
Hi Ron. I always remove an add after the item has been sold and have sold few things from this site. I have also bought stuff. Its very useful to get things seen by people with similar interests. See you on Monday
Thread: Boley & Leinen
01/12/2018 11:02:25
Burned again.I know where to go next time. Thanks Duncan
30/11/2018 18:46:25
Thank you Michael. The oil and bearings are on the way
30/11/2018 14:50:36
Hello all
I have just started to rebuild the head stock of my new old Ebay Boley & Leinen model 83 lathe. The bearings are shot and grumbling . They appear to be oil lubricated as there is a wicking system inside the head casting. So my questions are should I fit sealed bearings or the unshielded type as original. more important perhaps is what type of oil to use.
thanks in advance
Thread: Grinder safety
05/10/2018 17:52:15
Hi
I have a question regarding CBN and diamond grinding wheels. I have an acute sharpening system and have just ordered a CBN wheel for it. I see on youtube than no one seems to have any guards around the wheels. Is this safe? I also have some diamond wheels on the way from China these are the sort with an aluminium hub. Can I run these without guards? Eye protection is standard of course
Thread: Rocol RTD shelf life
30/09/2018 13:42:03
I wish there was an expiry date on the roads around here they are all dead
Thread: Tailstock tapping chuck
31/08/2018 19:12:57
Hi there
Steve Jordan has a good system using an ER collet chuck. Yotube again
Regards Adam
Thread: Joint Round Edge Needle Files
31/08/2018 19:01:39
Hi there
I use these when I am making watch case hinges. They are for making the half round groove that the hinge tubes are soldered into. In the watch and jewelry trade a hinge is often called a joint. The ones to have are the course cut as it a very fiddly job and time consuming. If you can find a video on Yotube of Martin Matthwes he shows how its done
Best Adam
Thread: HMS Queen Elizabeth due out today
27/06/2017 13:53:48
The magic money tree strikes again
Regards Adam
Thread: Hobbymat milling machine
16/06/2017 19:45:32
Hi Nigel
No I like to get it each month to help support my local news agent I know is more money so perhaps I should
Adam
16/06/2017 17:02:45
Hallow to all
I am trying to find some plans for a fine down feed for my hobbymat mill. I understand there was an article in M E W no168 but so far there have been non come up for sale on Ebay. Can anyone point me to another option. Are article reprints available or maybe someone has already put something up on the web
Thanks Adam
12/05/2017 13:23:30
Hi Roger
Yes my head stock leans forward so now I have another thing to get used to. I have a full set of metric collets that came with the mill but would like some imperial ones so I can use some of my existing tooling. Does any one know if they are a standard model or specific to hobbymat. I see they were listed in the original catalogue
09/05/2017 09:44:26
Hi Lathejack
I agree with your view its a fine machine and thanks for all your information. I have now down loaded the technical specifications manual from the yarhoo Prazi group forum and I hope this will give me all the information I knead to grease the milling head
Thank you all for your help
Thread: This monster arrived in our small harbour today
08/05/2017 18:23:21
Stay away you might catch somthing
08/05/2017 18:18:57
Thanks for the info. the mill is 25 years old so I was told so I think it would be a good idea to renew the grease in the head stock. If I remove the left hand cover only will that give me enough access to do the job? and do I remove the gear selector leavers first Thanks in advance for all your help
Adam
