AF hex?
Axel17/11/2016 17:15:25
126 forum posts
I just want to know what AF means. I read in an instruction that the part is made from 4mm AF hex?
Andy Holdaway17/11/2016 17:21:19
167 forum posts
15 photos
I've always understood AF to mean 'Across Flats', but I stand to be corrected by those with a greater knowledge than mine!
Andy
John Rudd17/11/2016 17:25:11
1479 forum posts
Axel,
It simply means 'across flats'.....the distance between 2 parallel sides.so in your case you need some hex bar that is 4mm across from one flat face to opposing one....
Its as simple as that......
Axel17/11/2016 17:29:37
126 forum posts
Thanks too all, I just figured it out myslef actually! (Not too stupid after all!)
Tim Stevens17/11/2016 17:32:46
1779 forum posts
A sure candidate for the proposed Glossary
Cheers, Tim
stevetee17/11/2016 19:19:34
145 forum posts
14 photos
As we are on the subject of 'across flats' does anyone know how the rather odd Whitworth hexagon sizes came about . I genuinely don't know but I do know 2 things 1/ whit head sizes were reduced in the war to the 'next size down' bsf sized hexagons. 2/ whit BSF hex sizes match neither metric or imperial ' whole' sizes , so for example 5/16 bsf has a hex size a little bigger than 1/2" but bigger than 13mm, but smaller than 14mm or 9/16.
Brian Oldford17/11/2016 19:26:06
686 forum posts
18 photos
I'm unsure why BSW spanners are the sizes they are but in trying to find an answer I came across this at http://www.sat.dundee.ac.uk/psc/spanner_jaw.html
"It is a common view that the odd Whitworth/BS spanner sizes are 'illogical' and that the newer metric system is much more 'logical', but consider this: To cover 1/4" to 3/4" in both fine (BSF) and coarse (BSW) threads, the British system defines 9 diameters and requires 9 spanners (or 10 if you also include the original large head Whitworth sizes as well). The UNF/UNC system defines 8 diameters for the same range but requires 11 spanners. For the broadly equivalent range in metric of M6 to M18 using all the common metric standards in use, there are 8 diameters defined but a total of 15 spanners are required! (i.e. 69% more spanners per diameters than the British system). Is this progress?"
stevetee17/11/2016 19:41:52
145 forum posts
14 photos
I came up with these tables which show the 'irrational' whitworth /BSF hex sizes. I seem to remember that , certainly at one time, getting hexagonal bar in 'whitworth ' sizes was not an problem. We certainly had it in school early 1970's, and later on when I worked in engineering .
http://www.oldengine.org/members/diesel/Tables/WhitAF.htm
Edited By stevetee on 17/11/2016 19:47:28
Chris Evans 617/11/2016 19:51:45
2156 forum posts
Hexagonal bar in whitworth sizes is still available. Some sizes as mentioned are close to other nominal sizes 3/16 W 1/4 BSF are 0.440" A/F the next size up is 0.525" A/F other oddities follow. I think the original thinking was as a ratio of the shank diameter.
Neil Wyatt17/11/2016 21:42:56
19226 forum posts
749 photos
86 articles
Posted by Tim Stevens on 17/11/2016 17:32:46:
Cheers, Tim
The glossary has attracted minimal contributions
Unlike the 'alternative' version proving our forum members have better knowledge of workshop esperanto than any other workshop language
Michael Gilligan17/11/2016 21:53:29
23121 forum posts
1360 photos
Posted by Neil Wyatt on 17/11/2016 21:42:56:
Maybe your publishers were right [it's all on the internet] devil
... if only you can find it.
Hevanscc17/11/2016 22:39:23
89 forum posts
33 photos
Posted by stevetee on 17/11/2016 19:19:34:
This has perplexed me also. Found this explanation on the intenet at http://www.enginehistory.org/british_fasteners.shtml
The derivation of Whitworth wrench sizes is another obscure mystery. From a Jaguar enthusiasts' web site **LINK** "...the hex sizes were originally governed by the commercially available steel hex bar stock sizes, in the days before automated screw machines, when nuts and bolts were cut from hex bar stock."
Clive Foster17/11/2016 23:32:00
3630 forum posts
128 photos
My understanding was that Whitworth sized his hexagons so they could be produced reasonably easily from nomial fraction sized round bar stock. Probably by forging or rolling down as machines able to cut round down to size in production quantities were not common when he first promulgated the standards.
The large hexagons of the original Whithworth sizes appear to be derived from some intuitive internal stress assessment based on relative depth of thread and the amount of metal between the thread and the hexagon. Large heads being desirable anyway when bolting timber or not too accurately finished plates and beams together as was very common then.
We tend to forget how much and how rapidly basic stock material size and finish changed between Whitworths day and WW1 or thereabouts. From the viewpoint of the amateur and producers of modestly engineered componets series production WW1 standards are pretty much good enough. Just a lot more expensive (relatively) to achieve then. General state of the art in Whitworths time could be fairly, by todays standards, said to be "Gwad, that's rough, real rough.". The high priced, highly finished "artistic" products of clockmakers et al being totally atypical. We get a distorted view of the quality of things produced in the past because all the ordinary cheap stuff that most folks had to use fell apart and was binned long before the antique and similar buff were born.
clive
Brian Baker 118/11/2016 07:29:25
229 forum posts
40 photos
American fred?
Ian S C18/11/2016 09:35:45
7468 forum posts
230 photos
I think you'll find that the "original" Whitworth had square nuts, and bolt heads, and these were forged by the black smith.
Ian S C
MW18/11/2016 11:02:42
2052 forum posts
56 photos
Posted by Ian S C on 18/11/2016 09:35:45:
Ian S C
Very much like the old coach bolts that riddle my garden shed, they look forged.
Michael W
