Ajohnw | 18/10/2016 23:11:11 |
3631 forum posts 160 photos | This came with my small lathe. One of the few that show signs of rust. The ball races on the arms are spring loaded towards the 2 that are solidly mounted at each end. Stiff wire springs. The same size and type used on the pin on the dividing attachment that came with the laths so probably made by the same person. I suppose it could be used to test for straightness or even roundness. The DTI reads to 1/10,000", it still works well too. John -
Michael Gilligan | 18/10/2016 23:29:20 |
![]() 23121 forum posts 1360 photos | I'm sure you're on the right track, John ... It could, conceivably be for setting the cutter on a between-centres boring bar; but then it would make more sense to have centres. MichaelG. |
MW | 18/10/2016 23:38:23 |
![]() 2052 forum posts 56 photos | I dont know about you but the fact that the clock is positioned upright to the fence indicates to me that it may have been used as a simple depth clock/comparitor of sorts, quite probably for measuring roundness like you said if it has the ball races going across it. Specialist depthing fixtures to buy from the measuring companies from the likes of mitutoyo even today can set you back a few hundred quid. But the dial gauge is the important bit and it's feasible someone may have made a simple fixture to meet that need a long time ago. Michael W |
mark smith 20 | 18/10/2016 23:54:01 |
682 forum posts 337 photos | Its definitely a concentricity gauge, ive seen similar homemade ones used for bullet shell cases., though this looks bigger and probably just for round turned projects. I had a similar but different device which came with a wartime Pultra lathe i have . Edited By mark smith 20 on 18/10/2016 23:55:18 |
warwick wilton 1 | 19/10/2016 03:55:19 |
17 forum posts 2 photos | could it be for checking or straiten rod or bar stock. place bar in bearings and turn. |
Graham Butcher | 19/10/2016 07:39:26 |
21 forum posts 3 photos | It could have been made to measure the straightness of arrows. |
Rod Ashton | 19/10/2016 07:46:59 |
344 forum posts 12 photos | Graham, I think has it. I have a professionally made version for the purpose of arrow straightening and it is essentially the same. |
Martin Kyte | 19/10/2016 09:26:27 |
![]() 3445 forum posts 62 photos | Or straightening clock arbors.? |
Ajohnw | 19/10/2016 10:08:50 |
3631 forum posts 160 photos | I don't think it was made in a home workshop. The main body is 1" x 1/4" and bent too well for that. The Comet brand small tools were introduced in 1937. No info on when it ceased other than a company name change in the mid 60's. I would have thought that the person who sold me the lathe would have known if the previous owner had an interest in archery. He was interested in clocks. No info on the owner before that but he was alive when he sold the lathe so probably just sold that on with it's bits and pieces.
It does sound like it's vaguely arrow related. I did have a bow, arrows and target when rather young. Wooden shafts and somewhat larger diameter shafts than modern ones. John - Edited By Ajohnw on 19/10/2016 10:10:45 |
Russell Eberhardt | 19/10/2016 11:27:22 |
![]() 2785 forum posts 87 photos | I used to practise kyudo (japanese archery) and used aluminium arrows as the bamboo ones were too expensive. They were always getting bent, particularly if I missed the target and hit the wall I used a pair of v-blocks and a drill press to straighten them by eye. John's tool would have been much better. Russell. |
Ajohnw | 19/10/2016 12:21:03 |
John - |
not done it yet | 19/10/2016 12:57:01 |
7517 forum posts 20 photos | http://www.ebay.co.uk/itm/Arten-Arrowsett-arrow-straightener-/122062884256?hash=item1c6b83cda0%3Ag%3AaZ0AAOSwENxXmkq2&nma=true&si=X7Sg%252FtPXLwpPF9zngwdoj4ojn%252BA%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
A newer version, sold on epay reentlly. An 'unused' one fetched £76 since. |
