Eric Cox | 06/08/2016 09:54:13 |
![]() 557 forum posts 38 photos | Can anyone suggest a suitable clear varnish for polished Mild Steel to stop it rusting. |
Roger Head | 06/08/2016 10:12:39 |
209 forum posts 7 photos | Someone (can't remember who) has previously recommended Rustins metal lacquer. http://www.rustins.eu/Details.asp?ProductID=811 Roger Edit: Note that they (Rustins) recommend it for brass, copper, bronze, and silver, with no mention of MS at all. It would be interesting to know why MS is omitted. Maybe they simply expect any steel product to have a protective coating already applied. Edited By Roger Head on 06/08/2016 10:19:12 |
Ian S C | 06/08/2016 10:14:13 |
![]() 7468 forum posts 230 photos | If the thing you want to protect is going to sit on a shelf, use hair spray. Ian S C |
Brian Wood | 06/08/2016 10:38:47 |
2742 forum posts 39 photos | Eric,
Roger Head | 06/08/2016 10:43:29 |
209 forum posts 7 photos | Posted by Ian S C on 06/08/2016 10:14:13:
If the thing you want to protect is going to sit on a shelf, ... But if not, then here's a good Aussie product http://www.kbs-coatings.com.au/diamond-finish-clearcoat-instructions/ Note that you need to warm it up a bit for curing. Usual disclaimer... Roger Edited By Roger Head on 06/08/2016 10:45:57 |
John Reese | 06/08/2016 21:09:11 |
![]() 1071 forum posts | Clickspring uses a 50-50 dilution of clear lacquer for his polished metal parts. |
roy entwistle | 06/08/2016 21:18:22 |
1716 forum posts | Clickspring uses a 50-50 dilution of clear lacquer for his polished metal parts. Diluted with what ? |
john carruthers | 07/08/2016 07:25:48 |
![]() 617 forum posts 180 photos | Clickspring uses a 50-50 dilution of clear lacquer for his polished metal parts. Diluted with what ?<< |
Alan Wood 4 | 07/08/2016 09:00:22 |
257 forum posts 14 photos | Linseed oil cut with thinners, |
speelwerk | 07/08/2016 10:16:44 |
464 forum posts 2 photos | I now use old fashion French polish for metal parts, works easy and dries fast. Niko. |
mechman48 | 07/08/2016 12:45:08 |
![]() 2947 forum posts 468 photos | + 1 for Ian SC... hair lacquer. George.
I.M. OUTAHERE | 08/08/2016 07:10:12 |
1468 forum posts 3 photos | Although i haven't tried it , what about clear nail polish thinned with acetone ? What about 2 pak clear Automotive paint ? I would never have thought of hair spray ! Ian. |
Jon Gibbs | 08/08/2016 08:48:18 |
750 forum posts | Melamine pre-catalyzed lacquer is crystal clear - comes as liquid or spray can. You can thin the liquid with cellulose thinners and paint on. Jon |
