Vic | 01/08/2016 15:00:07 |
3453 forum posts 23 photos | I bought several sets of serial taps quite a while back and having used the M6 set I wasn't particularly impressed so they've all sat in the box. The other day though I had no choice but to use the M2.5 set as I didn't have a conventional tap. I figured this might be a good thing as its pretty easy to snap a tap that small. I then noticed the set wasn't quite right, it had a number three tap and two number ones but no number two! Luckily it worked ok just using a 1 and 3. Moral of the story is to thoroughly check stuff when you buy it even if you don't plan to use it straight away! |
Bazyle | 01/08/2016 16:11:39 |
![]() 6956 forum posts 229 photos | By serial taps I take it you mean taper, second and plug. I don't know about others but for thick steel I find I have to take it in repeated stages That is part way in with taper, then a bit of second to open up the first couple of threads and back to the taper. repeat ad infinitum. I just don't see how even with a larger one that an M6 taper will go right through half an inch of steel without breaking. I use a drill which is much bigger than normal tables too. |
Michael Gilligan | 01/08/2016 16:42:20 |
![]() 23121 forum posts 1360 photos | Posted by Bazyle on 01/08/2016 16:11:39:
By serial taps I take it you mean taper, second and plug. . Why ? ... Vic might well actually mean 'Serial Taps' http://www.kanabco.com/vms/cutting_tools_tap/cutting_tools_tap_06.html MichaelG. |
Gordon W | 01/08/2016 16:48:54 |
2011 forum posts | My cheapo metric set of taps must be serial, although not marked or sold as such. Have to use the last tap to get a normal thread, and I tend to use bigger than standard holes. |
Vic | 01/08/2016 17:16:11 |
3453 forum posts 23 photos | Thank you Michael, yes I did mean Serial Taps! I did qualify this by saying I didn't have a "conventional" tap. I've now ordered a conventional taper tap to add to my arsenal to see if it's actually any better or worse! |
Thor 🇳🇴 | 01/08/2016 18:27:39 |
![]() 1766 forum posts 46 photos | Never had your problem Vic, with one of the taps in a serial set missing. Funny, I also had problems with my M6 serial tap - the last one - so I bought a Völkel M6 plug tap. I find it is much easier to tap a thread using serial taps, so mine are used quite a lot. Thor Edited By Thor on 01/08/2016 18:28:42 |
Neil Wyatt | 01/08/2016 19:03:08 |
![]() 19226 forum posts 749 photos 86 articles | My metric set are serial taps and the ability to tap a 'tight' thread is very handy. The final tap is unmarked rather than having three rings. Also the amount of lead is greater as the taps get smaller so a sort of 'hybrid set'? Neil |
Martin Connelly | 01/08/2016 19:08:39 |
![]() 2549 forum posts 235 photos | Typical depth of thread should be close to one diameter. You should not normally be tapping over 12mm for a M6 thread. Martin |
Vic | 01/08/2016 20:51:13 |
3453 forum posts 23 photos | Posted by Neil Wyatt on 01/08/2016 19:03:08: The final tap is unmarked rather than having three rings. Neil I have two taps with one ring and one with no ring. I guess I'm lucky to have the final tap! |
Ajohnw | 02/08/2016 10:50:13 |
3631 forum posts 160 photos | Posted by Vic on 01/08/2016 17:16:11:
Thank you Michael, yes I did mean Serial Taps! I did qualify this by saying I didn't have a "conventional" tap. I've now ordered a conventional taper tap to add to my arsenal to see if it's actually any better or worse! Following that link I wonder when the hell Ketan will restock the ones he has run out of. Probably never if he is waiting to sell all of the other sizes. M4 has been like that for a long time. John - |
Howard Lewis | 02/08/2016 22:57:31 |
7227 forum posts 21 photos | Presumably you are using some form of lubricant for tapping, such as Trefolex, Rocol STD, or as I often do, Bacon Fat? Although not recommended practice, it is possible to go from Taper to Bottoming tap if careful. Many taps break because they are subjected to bending, (You can usually tell if too much torque is being applied, before it breaks). A Tapping Fixture which holds the tap perpendicular to the work avoids bending the Tap. There is a physical law which says that if you do break it, it will be in the last hole on the final operation of the workpiece. Believed to be Newton's Fourth Law (of the eternal cussedness of things; sometimes attributed to Sod) Howard
John Stevenson | 03/08/2016 10:16:29 |
![]() 5068 forum posts 3 photos | I use them and find them invaluable in some of the more testing materials like stainless, aluminium bronze, unobtainium, scrapbinimum and EN hardaswitchestits |
Howard Lewis | 03/08/2016 14:07:50 |
7227 forum posts 21 photos | The worst that I ever had was tapping a 1/4 BSW in place of the stripped self tapper thread in a battery terminal post. Being lead, the swarf does not break, just curls and jams very easily, so the thread needs to be cut in stages. Howard
Ian P | 12/09/2018 15:28:44 |
![]() 2747 forum posts 123 photos | I know its and old thread (and the links in it have stopped working) but where can I buy serial taps? My go to place (where I bought some previously) is Arc, but they seem to only have a few odd ones left in the catalogue. I'm looking for M3, 4, 5, 6 (but Arc still have M5). Not many suppliers seem to stock these in the UK.
IanP
JasonB | 12/09/2018 15:42:09 |
![]() 25215 forum posts 3105 photos 1 articles | Rotagrip do them by Volkel which are quite a good make, I usually buy via their e-bay shop Edited By JasonB on 12/09/2018 15:45:43 |
Ian P | 12/09/2018 15:51:08 |
![]() 2747 forum posts 123 photos | Volkel are fine, Rotagrip are a little light on details and dont even say how many are in a set (they infer some sizes only have two taps). Price is a lot different to Ketan's too! Ian P |
JasonB | 12/09/2018 15:56:09 |
![]() 25215 forum posts 3105 photos 1 articles | They do unbranded WcAAOSwu4BVoWAi">sets at a lower price too Edited By JasonB on 12/09/2018 15:56:41 |
Nick Clarke 3 | 12/09/2018 18:25:14 |
![]() 1607 forum posts 69 photos | Posted by Howard Lewis on 02/08/2016 22:57:31: There is a physical law which says that if you do break it, it will be in the last hole on the final operation of the workpiece. Believed to be Newton's Fourth Law (of the eternal cussedness of things; sometimes attributed to Sod) Howard As a teacher I prefer the version of the law that states :- A piece of toast, when dropped, will always land butter side down - UNLESS you are trying to demonstrate this to someone else! |
