Best cleaning media for screws etc
Martin King 2 | 19/05/2016 18:04:12 |
![]() 1129 forum posts 1 photos | Hi all, Have just got a small motor driven tumbler roller for cleaning and polishing gemstones etc. I thought I would try it on some good but grimy cap screws, so put in the 'barrel brightener' that came with it, dash of Fairy liquid and some water; left it for a couple of hours to find it full of thick foam. When washed off the parts were very clean but almost as much work getting rid of the foam and then drying them. Clearly I am doing something wrong here, any thoughts please? Regards, Martin |
John Rudd | 19/05/2016 18:09:32 |
1479 forum posts 1 photos | Is it worth trying an anti foaming additive? |
David Jupp | 19/05/2016 18:20:07 |
978 forum posts 26 photos | Or simply not adding detergent? Tumblers tend to use abrasives to do the cleaning/polishing. |
Muzzer | 19/05/2016 19:08:18 |
![]() 2904 forum posts 448 photos | Tumbling is basically an abrasive process, so generally used for deburring, polishing etc, rather than agitating detergents. In this case, perhaps something like Gunk or soluble cutting oil would be better, followed by simple rinsing in water (very hot, so it self dries after shaking most of the water off). Some added sand may speed up the process without the risk of wearing much away. |
Martin King 2 | 19/05/2016 20:14:13 |
![]() 1129 forum posts 1 photos | Sand sounds a bit severe to me, are thee other abrasive mediums perhaps? Something a bit more gentle, all I want to do is brighten and clean a bit. Anything that can be used dry? Martin |
Andrew Johnston | 19/05/2016 20:18:11 |
![]() 7061 forum posts 719 photos | Posted by Martin King 2 on 19/05/2016 20:14:13:
Anything that can be used dry? Walnut shells? Andrew |
V8Eng | 19/05/2016 20:31:54 |
1826 forum posts 1 photos | Have you tried emptying the barrel contents into a domestic type sieve, then rinsing it under a tap before tipping everything out onto some kitchen roll to sort the contents before drying? Edited By V8Eng on 19/05/2016 20:33:30 Edited By V8Eng on 19/05/2016 20:56:41 Edited By V8Eng on 19/05/2016 20:57:07 |
Michael Gilligan | 19/05/2016 20:33:14 |
![]() 23121 forum posts 1360 photos | Martin, I asked a related question last year You may find some of the responses useful MichaelG. |
Tony Pratt 1 | 19/05/2016 20:57:02 |
2319 forum posts 13 photos | Martin,
I expect your screws to go rusty very shortly. Tony |
Clive Hartland | 19/05/2016 21:21:17 |
![]() 2929 forum posts 41 photos | There is an ongoing post in another Forum telling to use S/Steel rods about 1 mm x 2 mm long. not sure how this works but reports say it gives excellent mechanical cleaning ! Clive |
John McNamara | 20/05/2016 01:09:56 |
![]() 1377 forum posts 133 photos | One of the most used tools in my workshop is the 200mm fine wire brush I have fitted to a grinder. Getting the right wheel is important. they are available in steel, brass and plastics of different bristle diameters. The wheels available at the hardware store may be too rough and tend to have a rather open density of wire. Industrial suppliers are the place to go, there are many grades. Mine is fine hardened steel wire, I cant tell you the type as it was purchased many years ago. You supplier should be able to advise you. Abrasive cleaning is not selective, I would reserve it for non precision parts. using it will round all edges. Edited By John McNamara on 20/05/2016 01:10:26 |
Peter Krogh | 20/05/2016 06:42:41 |
![]() 228 forum posts 20 photos | John, I have had a very similar wheel mounted for years just for cleaning parts. I also use it for light deburring and polishing, especially of threads. I don't know what I'd do without that fine wire wheel! Pete
Johan van Zanten | 20/05/2016 07:07:13 |
![]() 52 forum posts 98 photos |
Hi Martin, I use houshold soda. One spoon per liter. Cleans great,No foam at all. Best regards, Johan. |
I.M. OUTAHERE | 20/05/2016 08:02:16 |
1468 forum posts 3 photos | You may find front loading washing machine powder to work as it is low suds . I usually use an ultra sonic cleaner with a mild degreaser. Clive , i recently seen an advert for steel pins for cleaning brass cases (rifle / pistol ) never seen them before ! I used to use corn cob pet bedding and load it with liquid car polish for my ammo - best stuff i ever used and dirt cheap. Ian
Tim Stevens | 21/05/2016 12:04:27 |
![]() 1779 forum posts 1 photos | Jewellers suppliers offer a range of barrelling media, both abrasive (ceramics etc) and burnishing (hard steel balls and other shapes). I'm not sure that either would be good for screws as the threads will be damaged, but very useful for cleaning and polishing castings, etc. Which is, you see, what jewellery makers use them for, in the main. Or, for our transatlantic readers, jewelry ... Tim |
Bazyle | 21/05/2016 14:54:52 |
![]() 6956 forum posts 229 photos | My home made roller is on a top shelf unused for some years. It wasn't the easy instant solution I hope for. Plenty of hobby suppliers offering the materials. I used 'ceramic shapes'. They were not abrasive themselves but various grades of abrasive were added and the shapes rubbed it against the part. It wasn't aggressive enough to deburr and didn't get into the corners well either. I remember the rods being available so they are not a new invention but never tried them. |
Johan van Zanten | 21/05/2016 16:29:01 |
![]() 52 forum posts 98 photos | Hi all, I follow the tumbler discussion on this forum for some time but I think it is not that easy to get good results. I made my tumbler 20 years ago and use it very frequent with good results. The driving unit is a geared fractional horsepower motor with a speed of about 100 rpm. My drums are made from sewage tubes with a diameter of 120 mm, carefully covered with rubber sheet. They are half way filled with medium made from offcuts stainless steel . The sharp edges are essential to reach the corners of the workpiece. I use one spoon of siliciumcarbide grit as abrasive. To lubricate the process I use a cup of water with a spoon of washing soda. The tumbling time varies depending on the workpiece between 12 and 20 hours. For a brass or bronze workpieces I use brass medium. Tumbling is ideal for (silver)soldered workpieces. The parts of my latest engine are tumbled for 15 hours direct from the mill. I am looking for a reasonable priced bowl for a vibratory tumbler. This shortens the operation time. As you see there are happy tumblers in the model engineering world.
Best regards,
Johan. |
MW | 21/05/2016 16:52:25 |
![]() 2052 forum posts 56 photos | There are specialist companies out there that make tumbling media, from pink grinding stones to brass, steel shot you name it. I took a look at a few at the MACH expo in birmingham NEC a number of years ago. You might wanna check out the rotary magnetic deburring/tumbling machines too. A large central magnet spins at high speed and you place the parts in a plastic jug and fill it with metal needles, they abrade the parts as the magnet spins. I think theyre sold from the far east. You dont need to be fussy with it either, it only needs a mixture of fairy and water to get it going and it's very gentle on the components. Ideal for plastics/small components. You can separate the metal needles from the parts with collinder/mesh baskets afterwards. Michael W
Michael Gilligan | 21/05/2016 17:34:35 |
![]() 23121 forum posts 1360 photos | Johan, Thanks for posting the photos and description Very encouraging !! MichaellG. |
Martin King 2 | 21/05/2016 17:47:02 |
![]() 1129 forum posts 1 photos | Posted by Tony Pratt 1 on 19/05/2016 20:57:02:
Martin,
I expect your screws to go rusty very shortly. Tony Hi Tony, After placing the screws on a plate in a warm oven after our supper the screws dried well and show no signs of rusting at this time.. I intend to try some different media and see what happens on another small batch and will report back. At present I scrap reasonable quantities of cap screws, small model enginieering size nuts and bolts etc which seems a shame. Regards, Martin |
