Water softness for copper boilers
Ron Hancock21/04/2016 17:49:47
526 forum posts
95 photos
Hi just finished building my Black 5 now ready to run it.
I live in a hard water area so wondering if water softener salt would help.
I have seen it advertised on eBay 25 kg bags would this work or is it better just to add white vinegar.
I have also heard after running fill with cola will also clean.
any info would be great full please
ron
JasonB21/04/2016 17:56:00
Get some proper water treatment which will help stop scale forming . The "TC" is the one for copper boilers
Ron Hancock21/04/2016 17:58:52
526 forum posts
95 photos
Is it just caller TC sorry I am a novice
Ron
JasonB21/04/2016 18:00:08
Click on the bold water treatment in my post above and it will take you to as seller of "Multitreat TC"
Phil Whitley21/04/2016 22:00:14
1533 forum posts
147 photos
Use filtered rainwater, about as soft as you can get, and ever so slightly acid.
julian atkins21/04/2016 23:12:58
1285 forum posts
353 photos
Hi Ron,
Dont worry at the moment.
I will do a search online re your water quality for your area. I am quite sure you wont have the problems in parts of the south of england with hard water, which I was used to for many years.
Cheers,
Julian
DMB22/04/2016 00:11:09
1585 forum posts
Yes Julian, Brighton's water is very hard - pumped out of South Downs having filtered through the chalk hills. Tastes better than London's regurgitated sewage.
John.
John Fielding22/04/2016 13:36:05
235 forum posts
15 photos
Hi Ron,
As luck would have it I was reading some old ME magazines last night and there is a very good article on this subject.
Take a look at ME Vol 209, No 4438, 7-20 September 2012 for an article by Brian Baker called "Water Water". Everything you have always wanted to know, but where too scared to ask!
If you can't locate a copy then I can scan and send if you PM me with your email address.
Roderick Jenkins22/04/2016 13:52:06
2376 forum posts
800 photos
Posted by Ron Hancock on 21/04/2016 17:49:47:
Just to clear up any possible misconception: Water softener salt (normal NaCl) is used to regenerate an ion-exchange water softening system as often fitted to e.g. dishwashers. It is not added directly to the water to soften it.
HTH,
Rod
Bob Brown 122/04/2016 14:57:16
1022 forum posts
127 photos
While on this subject would reverse osmosis filter work?
Ron Hancock25/04/2016 20:03:09
526 forum posts
95 photos
Failed to steam again Sunday the screw fitting that goes into tube plate started leaking. I had sealed with Loctite worked fine at home but second steam at the club it failed. I could not beleive how it failed after steaming so well at home.
Back to drawing board try again
Ron
Neil Wyatt25/04/2016 20:25:24
19226 forum posts
749 photos
86 articles
Try boss white. Cheap as chips from B&Q.
"Boss White Jointing Compound is a non-toxic compound for sealing threaded joints on non-drinking water pipes. Suitable for hot and cold water and low pressure steam up to 7 bar."
OK, that's only 100psi, but its what LBSC always used.
Ron Hancock25/04/2016 20:28:46
526 forum posts
95 photos
Thank you Neil I will get some tomorrow and try it
Ron
