Here is a list of all the postings Ron Hancock has made in our forums. Click on a thread name to jump to the thread.
Thread: Black 5 Rebuild finished at last |
03/04/2018 17:23:29 |
Thanks Neil been a hard slog but been well worth it. Wondered many times if I would Fail but brilliant now. Ron |
03/04/2018 17:21:37 |
Hi Martin yes before full Regulator struggled now Max 1/4 pulls like a steam train never dreamt it could be so powerful. Well impressed Ron |
03/04/2018 16:18:25 |
not been on for Awile but now Happy with my 5" Black 5. I have now fitted Stainless Super Heater A's did not have one before. I also fitted a 15 mm gas Valve for my Regulator with an 1/2 pipe feeding the Super Heater. I have Also from Super heater fitted 10 mm pipe from super heater to Cylinders that was difficult. It now has loads power before it struggled to pull 7 persons going to see how many it will pull Thursday. It's such a different Loco with the Upgrades. Looking forward to second Run on it.
Thread: Black 5 Timing |
03/11/2017 21:20:59 |
No I forgot to add besides the Crank coming out witch upset the timing. Also my uncle built frames motion gear and pistons over 60 years ago. He built it coping original l plans from crew but his first build. Since I finished building it always thought it lacked power. He had built it with steam pipes of 3/16 was told to small so used 1/4 but after found they should have been 3/8. I also found from my new club members the 10 mm gas valve is to small for a 5” Black 5 hence now fitting a 15mm Gas valve. I think the timing is very hard to get right first time unless you really understand it so many try and get wrong. The only real way I think is to get some one who knows what they are doing to check it and if it’s wrong set correctly. If in doubt ask a professional and learn from it |
03/11/2017 21:20:15 |
03/11/2017 20:25:55 |
Well bit more work to do going to change the 10 mm gas valve for a 15 mm gas valve. Also changing the pipe work from cylinders to boiler from 1/4 to 3/8. Made new pipework to cylinders with oil feed in got to make fittings to go through boiler. Still got my timing to do but afraid making it worse but luckily Julian Atkins has offered to set it for me as he has done so many. I can follow part of it but does not properly sink in. My Black 5 lacked pulling power I have fitted new pistons and Rings but still struggled to pull 7 on the Flat. Thought if I try and get every thing as suggested stand a good chance of solving lack of power. With timing set as it should be correct size pipes and larger gas valve hope it soolves the problem. Ron
19/10/2017 12:30:32 |
Thread: Black 5 ready again to run |
18/10/2017 14:06:45 |
Like the Driver he he the Ladies where very slim |
18/10/2017 11:27:09 |
Well Ran my Black 5 Sunday with new Injector from Pavsteam worked perfect picked up every time. Loco Ran ok but really lacking power. I had 7 adults on it realty struggled to pull them even in full forward gear. Guys at the Club suggested the Valve timing might be out so going to read up on it see if it’s set right. Other than lacking power she Ran ok. Back to drawing board get my head into books and learn how to set Valve timing. Ron Edited By Ron Hancock on 18/10/2017 11:28:23 |
14/10/2017 10:43:21 |
Thank you Brian hope it does Ron
13/10/2017 23:36:05 |
ronThanks Guys Fingers crossed
13/10/2017 22:14:10 |
Well going to Run this Sunday after a load of many problems, I have had the Crank done that came loose rebuilt axle pump new boiler cladding now fits. Just received a new Injector from Paul Pavier that really is suposed to be the very best, I have had so many that did not work i have had piping changed plus i also changed also clacks ect. I sent three to Julian Atkins who found the ventura in the tops where to big and would not work, Julian going to send two back going to return to suplier see if they will change or refund, I borrowed one from Julian that did pick up gave me hope. Bought another from Manchester i think that one will be ok its a black one same as reeves. Will fit the new one on Sunday and see if i have now got every thing sorted. I have run it on axle pump Ran fine till axle pump went and crank came loose. I have now repainted it and for the first time feel very confident in it. Roll on Sunday at Coalville its even forcast 21 deg so looks like its all going the right way. We will see Ron |
Thread: Boiler Cladding for Taper Boiler help |
18/07/2017 11:06:32 |
Thank you Guys it's just so springy Keatly metals suggested 0.7 so that's what I have. Just going to take my time I have the old one I took of that was a bit to short looked dreadful. The boiler had to have an inch and a half extension price added by GB Boilers as it was to short to reach the Smoke Box. I should have bought a new brass plate then but decided to do it later. Well back in workshop time to get more experience this game so much to learn. Thank goodness for sites like this so you can get info from people who have already made Loco's. us novices would never learn if it was not passed down to us keeping Model Engineering alive.. many thanks Ron |
17/07/2017 22:44:14 |
Hi i have just taken my boiler cladding of to fit a new one. My Black 5 boiler is tapered any suggestions on How to fit it neatly. Last time the back edge was ok but the front edge i could not get close to the boiler. I tried using home made clamps like large jubilee clips. Should i aneal the brass sheet will it be easier to fit tight. I have seen so many that look so good must be a way of doing it. Any suggestions greatful as still trying to learn Ron |
Thread: injector problems still |
08/07/2017 23:11:09 |
Thank you will see if I can track him down. At moment I now have a working injector. I had thought it must be my Loco but fitted last one and it pics up Lovely. Going to Run it Tomorrow see how it performs then. Thank for advice Ron |
06/07/2017 12:16:59 |
Think i posted wrong video sorry https://youtu.be/ZPAWljV898Q You cannot beleive how good it feels
06/07/2017 11:50:41 |
https://youtu.be/YQPwu2VGJZM Well got my new injector from Blackgates this morning fitted as you can see on Video utube it picked up no problem so after buying 7 one works feel very elated as the only other one that would work was one of Julian Atkins thank you Julian. such a relief at last. |
05/07/2017 21:47:45 |
Your not kidding tried everything just been out fitted paper fuel filter to Injector pipe no way anything will get past that. I have also changed all plastic piping and used petrol pipe clips. Will guarantee no air leaks or muck getting into injector. I have new Injector coming from Blackgates tomorrow to Try. I have also been given another supplier who comes highly recommended so hope after this all will be well. I have also washed clacks in white viniger blew out with air line fitted new balls in. Will steam again tomorrow toes fingers crossed now Ron
05/07/2017 18:42:23 |
I used a very fine filter they use on pressure water pumps to keep clean. Most injectors here work with water first if you use steam first the injector will over heat and not work. No idea what can be wrong other than the injector itself. I have ordered a no 3 hope to get from Blackgates tomorrow will see if I can get that one working. Ron |
05/07/2017 17:42:22 |
Hi if it's the case that not enough steam to ouch it not sure why it works on the borrowed one. I am using 3/16 pipe same with globe Valve. When Ben Pavier of BP Steam changed the piping and fitted borrowed injector he had it working Lovely. I got these two new ones to try but no way will it put water into boiler. Surely just closing water so it's slow would then work I just don't know Ron |
