Roderick Jenkins | 14/02/2016 18:56:31 |
![]() 2376 forum posts 800 photos | I needed to make a V anvil for my hardness tester today. Basically a disc with a locating spigot and a v across to hold round items. Turning the disc was straightforward but milling the V was a bit of a conundrum. I wanted to set the anvil up at 90 degrees, cut with an end mill so that I had a faced surface then rotate through 180 degrees and face the other surface. Not going to happen with the dividing head on my mill - completely out of headroom: Sir John Stevenson rode to the rescue with one of his collet blocks. I'd only bought it because someone on here said they were good for holding round stuff in the vice: I'd already drilled a small hole through the centre of the anvil so I knew that when the v was symmetrical with hole that the v centre would be in the centre of the anvil. Useful item, a collet block. Cheers, Rod edited for spelling and other nonsense Edited By Roderick Jenkins on 14/02/2016 18:57:50 |
Chris Evans 6 | 14/02/2016 21:03:16 |
![]() 2156 forum posts | I have 5C collet blocks, one of the workshops most useful tools. |
Vic | 14/02/2016 21:55:52 |
3453 forum posts 23 photos | I've got a single sq ER32 collet block and a couple of the 5C to ER32, very handy to have around. |
Howard Lewis | 15/02/2016 12:03:08 |
7227 forum posts 21 photos | I made myself a square, and a hexagonal block for both ER25 and ER 32, only to find later, that John had made a more refined and better looking version. Very useful! Before anyone asks "Why square ones? You can, mill round all sides when its vertical in the vice" Stating the painfully obvious, lying horizontal, one or more flats can be milled on long material, and it can be held closer to the cut. Howard |
John Stevenson | 15/02/2016 13:33:14 |
![]() 5068 forum posts 3 photos | Rod, Please forward this post to Ketan at ARC.
After the mauling I got off the tax man and the VAT man at end of January that 4 quid could be the difference between a bowl of soup this week or me sharing Winston, the Old English Sheepdogs, dinner.
Things are getting dire.
Involute Curve | 15/02/2016 13:46:46 |
![]() 337 forum posts 107 photos | Do you sell your stuff direct John, or though a retailer?
Shaun
tss ok I found em.... Edited By Involute Curve on 15/02/2016 13:49:32 |
NJH | 15/02/2016 13:46:48 |
![]() 2314 forum posts 139 photos | John It would seem that you are keeping Winston handy - just IN CASE ?! Norman
Involute Curve | 15/02/2016 13:52:09 |
![]() 337 forum posts 107 photos | But out of stock..... get on with it man... |
Ketan Swali | 15/02/2016 14:39:51 |
1481 forum posts 149 photos | Blocks: Hopefully in by the 29th of this month. Winston: Arrived safe and well. Will send him back on 29th. Ketan at ARC. |
Georgineer | 15/02/2016 15:16:07 |
652 forum posts 33 photos | "John It would seem that you are keeping Winston handy - just IN CASE ?! Norman" https://www.youtube.com/watch?v=tnpAvjNH2CA George |
Neil Wyatt | 15/02/2016 15:30:29 |
![]() 19226 forum posts 749 photos 86 articles | Something few folks seem to have noticed is that the corners of the JS blocks are accurately chamfered and wide enough that you can hold them in the vice across the 'corners'. This means you can divide by 8 with the square ones and 12 with the hex ones, although they obviously don't give the same height above datum when you do this. Chin up Winston, If I was being hassled by a bulldog dressed as Jane Fonda, I would mail myself to Leicester too. Neil |
Clive Hartland | 15/02/2016 16:29:16 |
![]() 2929 forum posts 41 photos | John, never that the dog should suffer, as for the Tax man you can join my club as they have now taken me off self assessment and will not allow me to change my income to get re-assessed! Trying to talk to a Tax man is akin to speaking Esperanto as they do not seem to understand the gist of a letter nor it's intent and you receive a non sense letter in return. Also try two different tax code numbers from two different tax offices. Cambridge, Portsmouth and somewhere in Wales at one time with three different tax codes. Clive |
Ian S C | 16/02/2016 09:45:32 |
![]() 7468 forum posts 230 photos | John, don't eat the dog, some people might get upset. Ian S C |
