Peter Bell | 19/01/2016 21:10:06 |
399 forum posts 167 photos | HI, My w/shop computer is dying. Its XP and going to replace it with a Window 7 machine. Last time I thought of doing this I found that needed an adapter board to go with the 64 bit machine---is it still the same? Thanks Peter |
John Stevenson | 19/01/2016 21:16:07 |
![]() 5068 forum posts 3 photos | Yes, parallel port will run under W7 but only 32 bit.
Pays to stick with XP for a controller PC. Plenty about and plenty cheap enough, people are giving those away now. |
Steambuff | 23/02/2016 11:39:56 |
![]() 544 forum posts 8 photos | A little unclear so to verify If the RAM is greater than 4Gb then it is only 64-bit .... If the RAM is under 4Gb then you can use 32-bit or 64-bit. (Although in 32-bit mode you will usually only see about 3.5Gb) Dave |
John Haine | 24/02/2016 09:02:27 |
5563 forum posts 322 photos | Mach3 will only drive the parallel port on a 32 bit Windows machine. If you have a 64 bit PC you need to use a separate motion controller, preferably through an Ethernet interface. It is easy and cheap to buy a used 32 bit PC with XP, so if you want to continue to use the parallel port this is the best route. I think there is an option to install Win7 on a 32 bit PC, and M3 probably will work on that. Suggest you look on the Mach3 support site where I'm sure this question has come up many times. |
Gray62 | 25/02/2016 14:33:16 |
1058 forum posts 16 photos | Posted by paul asselin 1 on 25/02/2016 14:06:00:
Posted by Steambuff on 23/02/2016 11:39:56:
A little unclear so to verify If the RAM is greater than 4Gb then it is only 64-bit .... If the RAM is under 4Gb then you can use 32-bit or 64-bit. (Although in 32-bit mode you will usually only see about 3.5Gb) Dave correction If the RAM is greater than 4Gb then you can use 64-bit and 32-bit(32bit os will allow you using only 3gb ram). If the RAM is under 4Gb then you can use only 32-bit . Also Incorrect, you can run a 64bit OS in 4 GB or less, I have numerous windows server 2008 R2 and win 2012 machines and 64 bit Linux running in anywhere between 1 and 4G RAM in a large Virtualised datacentre. |
Bowber | 10/03/2016 23:20:42 |
169 forum posts 24 photos | All very confusing but I didn't bother, I just used a new 64 bit computer and a UC100 usb controller. http://cncdrive.com/UC100.html There is a UK reseller https://www.cnc4you.co.uk/Motion-Control/UC100-USB-Motion-Controller Seems expensive but in the long run much better and you can use any pc you want after that, I have my laptop setup with Mach 3 as well as the dedicated pc (laptop is a backup) Steve |
Steamer1915 | 11/03/2016 08:35:38 |
![]() 171 forum posts 42 photos | Plus 1 for the UC100 usb controller. Windows 7 64 bit. Steve. |
Peter Bell | 12/03/2016 08:11:26 |
399 forum posts 167 photos | Thanks for the replies Sounds a very neat solution. I'd rather buy a new computer rather than have the same problems once again. Do hey work wiith W10 and are they as good as they seem? Peter |
Bowber | 14/03/2016 20:46:13 |
169 forum posts 24 photos | Sorry, bit slow in answering. PC is Windows 7 pro 64bit, laptop is windows 10 64bit My mill is setup with homing switches in series, zero plate, Estop and the normal stepper pinouts. I don't use limit switches but no reason they wouldn't work. Mill works smoothly and doesn't seem to have any problems and the Estop and homing switches work fine. Originally I left the motor tuning as was but I've since retuned it. Steve |
Peter Bell | 25/12/2017 19:13:56 |
399 forum posts 167 photos | Going to take the plunge and buy a UC100 controller but notice that since I first looked into it they are readily available on ebay at all sorts of prices. Has anyone bought one of these recently? |
Nick Hughes | 25/12/2017 22:24:26 |
![]() 307 forum posts 150 photos | HI Peter, There was some reports of fake UC100 controllers on ebay and there is a thread about this on the CNCdrive forum here:- **LINK** Nick. |
Peter Bell | 26/12/2017 08:14:56 |
399 forum posts 167 photos | Hi Nick, Thanks for the link which makes interesting reading. I suppose it depends on what works long term but there's no real way to find out apart from buying something and trying it hence my question. Its a lot like my experience has shown that many of the LED bulbs just dont last where branded ones do. More reading reveals that the genuine UC100 not just a usb to parallel adapter but a true motion controller and a genuine UC100 would certainly be the easiest solution but its almost 2 years since I initially asked and a lot could have changed. Peter |
Ady1 | 26/12/2017 11:08:29 |
![]() 6137 forum posts 893 photos | Unless you're loading up monstrous files you're as well sticking with 32 bit I gave up on 64bit, too slow, unstable, and prone to errors In a few years(10 or so) 64 bit may be more flexible and mature The latest incident was with irfanview I tried to load every jpg thumbnail on her 64bit win7 pooter, the 64bit version crashed at about 35000 jpgs (we're hunting for a photo) Testing the 32bit version on my XP machine was fine, 45 to 50000 jpgs so far Will try the 32bit version on her 64bit machine later Edited By Ady1 on 26/12/2017 11:36:40 |
Peter Bell | 26/12/2017 18:45:11 |
399 forum posts 167 photos | Following on from that advice borrowed a working 32 bit machine with XP. Succesfully installed Mach from my disc but the computer crashes as it tries to open Mach every time. Removed anti virus etc and its got plenty of memory, even tried a different copy of Mach but still get the same result! Any suggestions what to try next most welcome!
Neil Wyatt | 26/12/2017 19:34:06 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Ady1 on 26/12/2017 11:08:29:
The latest incident was with irfanview I tried to load every jpg thumbnail on her 64bit win7 pooter, the 64bit version crashed at about 35000 jpgs (we're hunting for a photo) A caution with Irfanview... by default bit saves space by loading images at 50% resolution. if you don't tell it not to you can end up batch resampling your images into much smaller ones than you want - GRRRR. It may have made sense when computers only had megs of memory instead of several gigabytes... Neil |
Ady1 | 26/12/2017 21:20:25 |
![]() 6137 forum posts 893 photos | There's a few flavours of XP XP, pro with service pack 3 is the one I have found works best of all I can't upgrade now lol, too much stuff works well, just bought another 775 Motherboard for when the current one goes poof Whatever you do, try and get an SSD as your main drive, they're pretty fabby Try installing MACH 3 about half a dozen times before you give up, pooters are funny things, my designspark mechanical took 3 or 4 shots and the best ABBEY package I found was a german one, which I reset to English The big important software packages can be a bit hit and miss Edited By Ady1 on 26/12/2017 21:26:54 |
Ady1 | 26/12/2017 21:33:48 |
![]() 6137 forum posts 893 photos | EDIT on the SSD It looks like amazon sellers could be firing out returned SSDs, I got mine from Currys/PC world in a sealed package Just thought I should say |
Russell Eberhardt | 27/12/2017 10:17:20 |
![]() 2785 forum posts 87 photos | Posted by Ady1 on 26/12/2017 21:20:25:
Whatever you do, try and get an SSD as your main drive, they're pretty fabby They are fine for Windows 7 and above but for XP you need to do some tweeking to stop un-necessary writes to the SSD which could result in early wearing out. Russell |
SillyOldDuffer | 27/12/2017 17:48:19 |
10668 forum posts 2415 photos | Posted by Russell Eberhardt on 27/12/2017 10:17:20:
Whatever you do, try and get an SSD as your main drive, they're pretty fabby ... but for XP you need to do some tweeking ...
Hard to keep up with technology so I may be out-of-date but SSD on XP used to be a 'no-no' in corporate computing. Special cases apart, it was simply too expensive to tune the system and/or replace worn out SSDs on computers that worked hard for a living. XP pre-dates SSDs; in it's ignorance XP behaves like the computer equivalent of a bad driver - it rides the clutch, spins the wheels, and does a lot of red-lining! In consequence an SSD on XP is likely to have a short life. XP can be manually tuned to behave better with an SSD but it's not easy - advanced system admin, some of it.
I'm not sure how necessary this is today on a hobby computer. Modern SSDs have better built-in wear levelling that should reduce the damage XP does. On the minus side, no-one supports SSDs on XP because it's obsolete and really effective cooperation between SSDs and Microsoft didn't exist until Windows 7 and later. All bets are off - don't expect old computers to support new technology! On the plus side, an SSD installed on a lightly loaded XP machine might last 'long enough' for the owner to not care about the reduced lifetime. I expect a decent SSD would take a couple of years ill-treatment before flaking out! Dave Edited By SillyOldDuffer on 27/12/2017 17:50:12 |
Ady1 | 27/12/2017 18:50:12 |
![]() 6137 forum posts 893 photos | I've been beating the snot out of my SSD on XP for just over two years so far Runs 24/7 most days, 80% chip load(overclocked) I do OCR and PDF stuff, become a bit of an obsession really The onboard software is meant to spread the load around on ssd drives, will revisit this thread if it ever fails edit: On some jobs the drive goes down to 10GB left (usually about 50 GB) 120BG total size, I use a 2 terrabyte drive for storing stuff Edited By Ady1 on 27/12/2017 18:52:33 |
