Rainbows | 02/01/2016 13:55:57 |
658 forum posts 236 photos | My usual brand for drill bits is dormer but recently got a Guhring 14mm twist drill. Anyone here got an opinion either way on the quality of them? Couldn't find much on the internet except their website so I suppose they usually sell direct to industry. |
Rik Shaw | 02/01/2016 13:59:03 |
![]() 1494 forum posts 403 photos | A top brand. I have a fair bit of their tooling and it is quality stuff. Rik |
Raymond Anderson | 02/01/2016 14:11:52 |
![]() 785 forum posts 152 photos | Yes, i'll second that. Guhring gear is top drawer . In the same drawer as Titex , Emuge Franken, and others. I have a lot of their Drills both Hss and Carbide, as well as quite a few coated taps. Guhring are made for production so buy without fear. |
Thor 🇳🇴 | 02/01/2016 15:15:49 |
![]() 1766 forum posts 46 photos | I don't have twist drills from Gühring, but I have milling cutters, they are good. So Gühring tools get a thumbs up from me. Thor |
mechman48 | 02/01/2016 15:23:56 |
![]() 2947 forum posts 468 photos | Have a number of Guhring small drills myself; the quality is top notch, no wobble, straight as a die, sizes drilled within .001" not oversized, the only trouble is their price but if I can 'obtain', 'be given' any tooling by them I will grab it. George. |
Emgee | 02/01/2016 15:44:08 |
2610 forum posts 312 photos | As all comments have said, top quality tooling. Emgee
Chris Evans 6 | 02/01/2016 16:52:03 |
![]() 2156 forum posts | Last set of Guhring drills I bought for work all needed grinding before they would cut. I got the Rep into work to show him and he took them away. He gave me a replacement set that where fine and allowed me to keep the first set to take home. I am still using them 3 years after retirement. |
Ian Hewson | 02/01/2016 17:01:09 |
354 forum posts 33 photos | First class drills, used them for drilling thousands of 2mm holes in bolt heads for lock wires, sharpen up well and last forever. |
Rainbows | 02/01/2016 17:05:35 |
658 forum posts 236 photos | It was listed as only used a few times and I think the seller must have reground it since it was last sharpened. For £8 it was cheaper than I could get a standard Dormer 14mm bit and only slightly more than a cheesegrade unbranded one. |
Andrew Johnston | 02/01/2016 17:23:57 |
![]() 7061 forum posts 719 photos | I have some of their drills, taps and milling cutters; never had any complaints about them, even in tougher materials like 316 stainless steel. Andrew |
bodge | 02/01/2016 20:11:32 |
186 forum posts 3 photos | Guhring milling cutters & drills available from MSC industrial supply co . often they have Guhring stuff on offer on their sales flyers they have online . Hertel drills & milling cutters are also pretty good too ! bodge |
Neil Lickfold | 04/01/2016 08:18:19 |
1025 forum posts 204 photos | Guhring make a huge range of drills, some for specific materials. We use a lot of Guhring drills at my place of work and we have different ones for different materials. They are very well made tools and if you run them correctly get a lot of holes drilled per drill. They also drill very well to size also. Once re sharpened if they are not recoated, then I use the feeds/speeds for the uncoated drills. Guhring also offers custom tooling for specific tasks as well, that most other companies do not offer to do. Neil |
David Clark 1 | 04/01/2016 08:38:29 |
![]() 3357 forum posts 112 photos 10 articles | Guhring are good drills if you can afford them. Used them for years for hardened steel airplane components. |
