Matt Harrington | 05/11/2015 16:39:27 |
![]() 212 forum posts 16 photos | The time has come to replace the modified saucepan that protects the motor on my S7 ! Whilst it is functional, it is not very attractive and is now rattling like mad. Does anyone have an alternative suggestion? Matt |
Nick Wheeler | 05/11/2015 16:53:22 |
1227 forum posts 101 photos | How about some self-adhesive stick-on foam to stop the rattle? Then you can do something important. |
Matt Harrington | 05/11/2015 17:12:38 |
Clive Hartland | 05/11/2015 17:25:17 |
![]() 2929 forum posts 41 photos | A mesh ( Steel) with a strong magnet attached to it making the screen magnetic but only good for ferrous. Would it work? Clive |
DMB | 05/11/2015 17:41:37 |
1585 forum posts 1 photos | I have a sheet of ali with 2 slots to clear motor bolts and it simply slides into place whilst bolts are slacked off. |
DMB | 05/11/2015 17:50:44 |
1585 forum posts 1 photos | . Edited By DMB on 05/11/2015 17:51:53 |
NJH | 05/11/2015 18:24:12 |
![]() 2314 forum posts 139 photos | Matt Give it a birthday - buy the cabinet stand, splash back and motor protection plate! ( After an unexpected windfall I did ! Norman |
Neil Wyatt | 05/11/2015 20:26:31 |
![]() 19226 forum posts 749 photos 86 articles | I saw a very neat arrangement the other day based around building an extended plywood enclosure behind the lathe, sloping down into the swarf tray - very neat. More detalils will be in MEW some time soon |
Enough! | 05/11/2015 21:50:16 |
1719 forum posts 1 photos | This is what I did on my ML7 to shield my rather large 3-ph motor from swarf (and to add a general swarf tray). It's (very) simple sheet aluminum work - in fact most of the "bends" are aluminum angle screwed/pop-riveted in place. There is some constriction of the working room around the spindle. I haven't found this to be a problem when using a regular 3 or 4 jaw chuck (the work is farther forward in that case) or normally when using a collet-chuck. It has been problematic once or twice with a faceplate .... but I can take the whole shebang off in ten minutes.
steamdave | 05/11/2015 21:51:54 |
526 forum posts 45 photos | Here's my motor protector: http://s1149.photobucket.com/user/steamdave/media/Splashback%201.jpg.html The Myford splashback doesn't cover the motor, so an auxilliary cover is advised. Dave |
Matt Harrington | 06/11/2015 10:46:24 |
![]() 212 forum posts 16 photos | Bandersnatch, that is an elegant solution - two guards in one! Norman, where to buy those bits? Myfords?
Thanks guys, I'll probably go off and buy some ally sheet..... Matt |
Hopper | 06/11/2015 10:58:33 |
![]() 7881 forum posts 397 photos | After digging about 40 years' worth of swarf out of my motor, I remounted it underneath the bench and fitted a longer V belt to reach it. Keeps it totally out of the swarf zone and leaves more room in behind the chuck for awkward jobs and cleaning. Not sure if it would work on your model but its worth a thought. |
Gordon W | 06/11/2015 12:06:11 |
2011 forum posts | Some elegant solutions . After I had my lathe for a few weeks I found brass dust all over the motor, so made a temporary guard from a cornflake packet and duct tape, this worked very well and has been for some years. I plan to make a better job in ally, using the cardboard as a template, one day. |
Ian S C | 06/11/2015 12:08:15 |
![]() 7468 forum posts 230 photos | Clive, I don't know if a magnet stuck onto an AC motor would be effected, it might just be demagnetised. Ian S C |
NJH | 06/11/2015 12:47:27 |
![]() 2314 forum posts 139 photos | Hi Matt Here is a picture of the motor swarf guard. The lathe came on the stand but later I "indulged myself" with the splash back and motor guard. Both were purchased from Myford - I don't know if they are still available though. As you will see the guard is a pretty simple ( but effective!) affair . Norman
Clive Hartland | 06/11/2015 14:36:10 |
![]() 2929 forum posts 41 photos | Ian, I was thinking more that the metal (Steel) screen would have the magnet attached to it and act as a catcher. The whole screen becoming magnetized.The magnet would not touch the motor body. I will have to try it myself and see what happens if I throw some filings at it! Clive |
Jon Gibbs | 06/11/2015 15:23:35 |
750 forum posts | Mine is more similar to Gordon's - a 2 litre icecream tub with the side cut off. It a snug fit, doesn't rattle and isn't affected by cutting and lubrication oil flying around Jon |
Neil Wyatt | 06/11/2015 17:41:50 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Bandersnatch on 05/11/2015 21:50:16:
This is what I did on my ML7 to shield my rather large 3-ph motor from swarf (and to add a general swarf tray). It's (very) simple sheet aluminum work - in fact most of the "bends" are aluminum angle screwed/pop-riveted in place. There is some constriction of the working room around the spindle. I haven't found this to be a problem when using a regular 3 or 4 jaw chuck (the work is farther forward in that case) or normally when using a collet-chuck. It has been problematic once or twice with a faceplate .... but I can take the whole shebang off in ten minutes. That's very similar to what I saw done in plywood. Neil |
Enough! | 06/11/2015 18:11:14 |
1719 forum posts 1 photos | Posted by Neil Wyatt on 06/11/2015 17:41:50:
I'm always a little iffy enclosing or fencing off high power electrical equipment with wood ..... old time radios notwithstanding. (Anyway, wood is for those other guys |
