Newbie with an old Boley lathe
Paul Narramore12/10/2015 17:13:31
34 forum posts
6 photos
Hi, I am an utter novice with a lathe. I bought my 1940s Boley lathe a couple of years ago and have only used it for polishing stainless fasteners until now. I am restoring an old GoldWing motorcycle and needed to make a couple of spacers so thought it was about time I got some practice in. My first attempts using a pice of 18mm dia. brass was awful and I managed to both seize and snap off an 8mm twist drill in it, I then tried some aluminium bar with more success but I now know I should have used some cutting fluid. I still have difficulties getting the parting tool centred and the tip of the tool fell off! The lathe is without a power feed but it will do most of the jobs I'll need to do on it. Boleys seemed to have specialised in watchmaking lathes but this is a decent sized floor mounted lathe, and they were of German manufacture.
Bazyle12/10/2015 20:31:49
6956 forum posts
229 photos
Brass is notorious for grabbing the drill, pulling it into too deep a cut and breaking, but normally with smaller ones than 8mm. Normally the chuck just spins on the morse taper. It is often suggested that you blunt the drill by stoning a flat on the cutting edge, that is making a flat for a few thou in line with the axis of the drill so there is no sharp edge and it is scraping rather than cutting. All very well if you can have 2 sets of drills.
Otherwise you should use some oil so the chips can move easily and clear then very frequently to prevent jamming. Sometimes this type of drilling is called 'pecking'.
Ajohnw12/10/2015 21:07:11
3631 forum posts
160 photos
Sounds like you might have one of their 4's. I think all of their lathes are listed here
I seem to have a charmed life drilling brass. I know it will grab so drill it's cautiously and take no notice of the noise it usually makes. Cautiously just means drill slowly. It takes very little effort at the feed.
Can't really comment on your parting off problem. A photo of the tool might help. To post that you need to create an album - the green album icon up the page, place the photo in it and then post it in a thread using the camera icon. Or put some where on the web and paste a link using the one next to the camera.
To post a shot the photo needs to be in the album before replying to a thread.
Neil Wyatt12/10/2015 21:13:35
19226 forum posts
749 photos
86 articles
Welcome aboard Paul,
Your adventures suggest the lathe may not be perfectly adjusted, if tools are grabbing easily.
Might be worth checking the spindle and slides to ensure they are all well lubricated and without shake as a starting point.
Fatgadgi12/10/2015 23:39:22
188 forum posts
26 photos
Hi Paul
Carrying on from Neil's suggestion, it's possible that the tailstock barrel has a lot of axial play.
As said above, brass loves to snatch and pull the drill into it. So if the tailstock barrel can allow the drill to move freely by a significant amount towards the work then I could imagine that it could grab and seize up.
Just a thought ....
Regards (and welcome) - Will
Ady113/10/2015 00:55:09
6137 forum posts
893 photos
Boley made nice gear. It will take you a while to master your machine but with time and effort you will not be disappointed. Try not to be too hard on your lathe, boleys were often precision machines
Paul Narramore13/10/2015 11:14:19
34 forum posts
6 photos
According to John's link, mine may well be a Model 4LE as it has a steel drawer and cabinet beneath the bed. I degreased the lathe and bought some special oil resistant paint in light grey so she looks as smart as those in the link. A previous owner has fitted an electrical box to one side with what I presume to be a rheostat so the speed can be altered with the turn of a knob. Another switch reverses the rotation. Two oil reservoirs are fitted but these weep so oil eventually finds it's way onto the tray. (Don't worry, I will eventually get to learn the correct terms).
It's very possible that some parts are incorrectly adjusted, understandable on a 65yr old machine I guess. Since getting the tools properly set up to the centre point of the job, I will need to get a pointed tool to fit in the tail stock and adjust the height of the cutting tools with this.
We used to have a small model engineering shop in Maidstone, only a couple of miles from me but this moved a while back down to Staplehurst. I'm slowly accumulating small pieces of stainless steel, alloy and steel but I need to find a local supplier. There is an excellent stand which appears at my local classic motorcycle events, who sells all sorts of shapes and sizes of metals but that is no good if I want something straight away.
The last time I used a lathe was when I was at school, fifty years ago. I then spent many years as an engineering draughtsman but always wanted to desert my drawing board and make stuff. Thanks for the welcome.
Paul Narramore14/10/2015 19:23:09
34 forum posts
6 photos
Today I went out to have another look at my old Boley after looking at numerous images of Model 4 lathes. The tailstock on mine doesn't have a wheel to wind the chuck in and out, but a long arm about 2ft long. I believe this may have been because the lathe was used for production work where the operator was required to produce dozens or even hundreds of a stock item.
The lathe is fitted with three oilers, all of which leak. Can anyone recommend oiltight oilers?
I have an adjustable parting tool on order through eBay.
This morning, whilst going through books in my personal library, I found an old copy of THE AMATEUR'S LATHE by L.H.Sparey in mint condition. That along with the numerous excellent videos on YouTube should get me well and truly started.
V8Eng14/10/2015 19:30:45
1826 forum posts
Posted by Paul Narramore on 14/10/2015 19:23:09:
I have Adams make of lubricators on my ML7, I purchased them at a Myford open day a few years ago.
They have been really good, there is a whole range on their website, here:
Edited By V8Eng on 14/10/2015 19:31:31
Edited By V8Eng on 14/10/2015 19:35:47
David Clark 114/10/2015 20:49:18
3357 forum posts
112 photos
10 articles
Hi Paul Do you have fibre washers under the oiler mount? If not an O ring might do to stop oil leaking. Can you see the oil leaking out as eventually the oil from the bearings will reach the tray in the normal course of events.
Paul Narramore15/10/2015 11:18:23
34 forum posts
6 photos
Well I put in a few squirts of oil - I wonder what the correct oil should be - into each oiler and by the next morning, the oil has found it's way into the tray. I guess that's a 'total loss' system and is meant to be like that. I think the problem is that the sprung loaded whatsits in the oilers don't actually seal themselves.
Thanks for the link V8.
I wonder what the chances of getting a conventional tailstock to suit my Boley?
(Later) On the question of lubricating oils, I could find nothing in this forum. The Boley does have a metal plaque with numerous oils recommended but I'm sure they are now obsolete. I did contact Esso(?) and quoted their lathe oil and was recommended the modern equivalent but it seems I can only buy 5 gallons at a time! I went onto an American forum and found it a 'nest of vipers'. Some people recommend an auto oil whilst others declare it is madness. Anything is better than nothing but the correct oil is best. A search on eBay brought up Esso Nuto VG32 from Myford (expensive) and Esso Nuto H32 from another source. A little baffling.
Edited By Paul Narramore on 15/10/2015 11:41:26
Paul Narramore19/10/2015 17:09:24
34 forum posts
6 photos
Well after a few hours using my new 60yr old 'toy' I have turned up a stepped aluminium spacer for the motorcycle I am refurbishing, and today made two spacers, this time in stainless steel. They are now fitted to the bike and look very nice. Both the mudguard and the rear grab handle are now properly mounted to the frame and nicely bolted down with stainless Allen bolts.
So what did I learn? Well one YouTube video mentioned 'Rigidity, rigidity, rigidity' and he was right. Whilst I tried to keep the overhang of both round bar and cutting tool short, and ensured the parting tool was central, there was still a fair amount of chatter and some smoke. Unlike the videos on YouTube - 'Tom's Techniques' range of videos is interesting - when no cutting fluid was used, I actually did use some as this kept both the noise and smoke down, and the finish was better.
Also I was unsure of what speed to use. My plain lathe has no speed indicator just an add-on with a variable speed rheostat which goes from 'Dead Slow' to 'Fast'. So how fast for ally and how fast for stainless steel?
Cleaning up after doing some turning is a chore as the cutting fluid mixes with the swarf. Once cleaned down I have added a 'nappy' to the tray. These are oil absorbing pads made from layers of paper and used in aircraft servicing. My son can get hold of packs of them and they do absorb oil well such as when doing oil/filter changes on the bike or car.
The tool post on my lathe has a series of M4 Allen screws to hold the cutting tools and I don't think this is anywhere near secure enough. When I get around to it I shall drill and tap M6 or even bigger threads for larger Allen screws as these will hold the tools more securely.
All good clean fun so far
Ajohnw19/10/2015 17:29:53
3631 forum posts
160 photos
Chatter on a lathe like that is more likely to be down to loose slides or head stock bearing possibly augmented by technique and tools.
M4 is big enough providing they are high tensile which they usually are. If not the ends bell out often making them difficult to remove.
Edited By John W1 on 19/10/2015 17:45:36
john carruthers19/10/2015 17:45:13
617 forum posts
180 photos
Have you tried MES for materials?
Michael Gilligan19/10/2015 18:24:43
23121 forum posts
1360 photos
Paul,
Regarding Oils ... Have a look at this recent thread.
What's good for Pultra should be good for Boley.
Ajohnw19/10/2015 20:48:34
3631 forum posts
160 photos
Anyone know what the spindle size is on this lathe. Morse 1, 2 , 3 etc. If it's up to Schaublin plain bearings size most people seem to use grade 32 hydraulic fluid in them. There may be people about on the yahoo Schaublin group that familiar with this lathe. It looks like it use adjustable taper bearings in the headstock and maybe a tapered gib strip on the saddle. The lathe co uk photo's don't show enough of the rest but the compound and cross slide look conventional.
Ian S C20/10/2015 09:33:26
7468 forum posts
230 photos
For speeds(depends on diameter), stainless, go to the lower speeds, you don't actually need it to smoke. For aluminium, start at mid range, and go up or down till it feels right, a bit of kerosene/paraffin UK is a good lube for aluminium, If you use carbide tools most work can be done dry.
Ian S C
Paul Narramore20/10/2015 09:51:54
34 forum posts
6 photos
Posted by john carruthers on 19/10/2015 17:45:13:
Thanks John. They used to have a little shop in Maidstone but a while ago moved down to Staplehurst. As the sun is shining, I may get the motorbike out and have a ride down there. There's a classic motorcycle show at the East Sussex showground at Ardingly this weekend and there's always a stall there selling all sorts of metal, and cheaply too. I have bought some cutting fluid but when reading my book on cutting fluids, it says that they are 'soluble' and should be mixed with water. I used mine neat so had better read the instructions on the bottle!
The drill chuck came loose yesterday and it seems I was over enthusiastic with lubricating the Morse taper. I've cleaned it off and replaced it dry.
Is it good practise to mount a lathe tool in the tool post with packing pieces ABOVE and below the tool? I have only had the 5mm packing piece below the tool and with the screws bearing down on the top of the tool.
ega20/10/2015 10:14:11
2805 forum posts
219 photos
Paul Narramore:
I was a frequent visitor to the Hedley Street premises when MES were in Maidstone and do occasionally get down to Staplehurst. As has already been pointed out they do have an online catalogue and shop.
No pictures yet of your Boley which I hope you will not modify without careful thought.
Morse tapers should not be lubricated (although a thin film of oil keeps rust at bay and should do no harm).
Speaking of oil, Warco and others sell in small quantities but I wonder whether you could get some thorough the Maidstone ME club which I believe still has its model railway at Mote Park.
Paul Narramore20/10/2015 17:00:34
34 forum posts
6 photos
Modify? Who said anything about modifying? One thing I would like though is a conventional tail stock. The existing one has a long lever to pull on; I've been told this is because the lathe was once used for production purposes, churning out loads of small parts.
No pictures, I know. It seems whenever I go to yet another forum (Family history, gardening, motorbikes, F1...) each has a completely different method of attaching photos. The only way I know how to do it, and which works some of the time, is to use my smartphone and post on Facebook. Transfer it from the FB page onto a forum then delete the first image. Ball aching, I know, but..... I will have yet another go though. Heck, I can't even attach my avatar!
(Later) I've just tried to read and understand "How to post images and create an album" but my eyes quickly glazed over and I nodded off. Far, far to complicated for me. I was born in 1946 for goodness sake!
Edited By Paul Narramore on 20/10/2015 17:02:12
Edited By Paul Narramore on 20/10/2015 17:07:10
