Chris Denton | 02/10/2015 14:17:22 |
275 forum posts | I bought a load of facing mills from the ebay. Three of them take a triangular insert, I've never used triangular inserts before so have no idea what it could take. Any ideas please?
Chris Denton | 02/10/2015 14:19:34 |
275 forum posts | Edited By Chris Denton on 02/10/2015 14:20:12 |
John Rudd | 02/10/2015 14:34:57 |
1479 forum posts 1 photos | TCMT perhaps.... |
David Clark 1 | 02/10/2015 14:56:38 |
![]() 3357 forum posts 112 photos 10 articles | What make is the cutter? Does it have a part number? |
Muzzer | 02/10/2015 15:56:43 |
![]() 2904 forum posts 448 photos | Chinese Xmas Cracker brand by the looks? |
Chris Denton | 02/10/2015 16:08:51 |
275 forum posts | Yes, cheap Chinese one I think. Only marking is the diameter! I have three of them, all appear to take the same inserts. |
Ian S C | 03/10/2015 12:13:59 |
![]() 7468 forum posts 230 photos | Photo. Ian S C |
Ajohnw | 03/10/2015 13:12:46 |
3631 forum posts 160 photos | Looks like 16mm triangular tips would fit. As I use 11mm triangular on my lathe I've been hoping to find a milling holder for those but no luck so far even for 16mm. You might find that TCGT work better as they have more rake, John - |
Vic | 03/10/2015 16:35:58 |
3453 forum posts 23 photos | The inserts on my milling cutter don't have any rake, it all seems to be on the tool? |
Ajohnw | 03/10/2015 17:24:07 |
3631 forum posts 160 photos | Posted by Vic on 03/10/2015 16:35:58:
The inserts on my milling cutter don't have any rake, it all seems to be on the tool? RDG do one with what is probably a 16mm flat insert Some of the newer face mill holders use an oblong tip. On these the clearance angle looks to be in the normal range for carbide and rake is added by changing the shape of the top surface of the tip. I'm not sure how this applies to triangular tips but there does seem to be some low diameter face mills about, more end mill size that use triangular tips with rake. I've not seen any on ebay. I assume that the raked ones are fitted to square shoulders on the holder. I've no idea what they do on the RDG ones or similar but would assume they have very little if any rake. If anyone buys a face mill I would suggest looking at the tip prices. I've been toying with the idea of getting one and had a bit of a shock when I checked the tip price, ?? £7 each. Some types are a lot cheaper so I'm having another look around now and again as the rake does make a difference on a lathe. John - |
Enough! | 03/10/2015 17:31:03 |
1719 forum posts 1 photos | Triangular insets are usually defined by the inscribed circle .... probably 10mm in this case. TCMT or TNMG probably. You could always ask the eBay vendor. |
Chris Denton | 03/10/2015 17:43:04 |
275 forum posts | Ok thanks.
The vendor doesn't know the tips needed. I bought a box of around 9 face mills and three of them take this insert.
I have a spare 50mm one if you want it, £9 plus postage, similar to the RDG smaller 4 insert ones.
Ajohnw | 03/10/2015 18:45:39 |
3631 forum posts 160 photos | Posted by Bandersnatch on 03/10/2015 17:31:03:
Triangular insets are usually defined by the inscribed circle .... probably 10mm in this case. TCMT or TNMG probably. You could always ask the eBay vendor. They are prefixed with the length of one side of the triangle - If the mounting faces for the inserts are "square to the end" so that this type of insert could be fitted I'd like to buy the 50mm.
John -
Enough! | 03/10/2015 18:57:57 |
1719 forum posts 1 photos | John, I stand corrected. what I said is true in my experience in North America but it did occur to me after I posted that it may be done differently in Europe |
Ian P | 03/10/2015 19:31:00 |
![]() 2747 forum posts 123 photos | So far 12 replies to this thread but I still have not seen any real comments on trying to identify what type of insert would fit. I would suggest that measuring the size of the triangular recess would give an answer to the basic size, the next determining factor is how the tip is held in place. If its a central screw then its most likely that the insert has clearance rake and is single sided. Reversible inserts (six cutting corners) have no rake and rely on the holder having an angled face and these usually only have a centre hole too small for any sensible screw so these just to sit on a peg with some other clamping device. Lastly triangular inserts are available with no central hole. A picture of the holder would help.
Ian P
Michael Gilligan | 03/10/2015 20:49:17 |
![]() 23121 forum posts 1360 photos | Posted by Ian Phillips on 03/10/2015 19:31:00:.
A picture of the holder would help. . Ian, Isn't that in the second post ? MichaelG. |
Ian P | 03/10/2015 21:16:30 |
![]() 2747 forum posts 123 photos | Posted by Michael Gilligan on 03/10/2015 20:49:17:
A picture of the holder would help. . Ian, Isn't that in the second post ? MichaelG. Not on my PC Michael. I can see a wierd little icon/place holder but its not linked to anything. Its the only thing in that post other than a line saying its been edited by Chris. Ian P
Michael Gilligan | 03/10/2015 21:32:11 |
![]() 23121 forum posts 1360 photos | Ian, I've just copied the [offsite] image address: https://www.imageupload.co.uk/images/2015/10/02/image11026.jpg https://www.imageupload.co.uk/images/2015/10/02/image11026.jpg ... hopefully that will work. MichaelG. Edited By Michael Gilligan on 03/10/2015 21:33:00 |
Ian P | 03/10/2015 21:45:42 |
![]() 2747 forum posts 123 photos | Michael The plot thickens! When I click on your link I get this message Ian P (I get the same if I copy and paste your plain text version)
This webpage is not availableERR_SSL_VERSION_OR_CIPHER_MISMATCH
A secure connection cannot be established because this site uses an unsupported protocol.
Edited By Ian Phillips on 03/10/2015 21:46:47 |
Michael Gilligan | 03/10/2015 21:57:47 |
![]() 23121 forum posts 1360 photos | Ian, Very strange !! ... it works fine on my Mac and my iPad Presuming that Chris will have no objection, I will grab a copy and re-post it from my Album. [give me a few minutes] MichaelG. . Here goes:
Edited By Michael Gilligan on 03/10/2015 22:05:13 |
