Injectors
A simple explanation
Eric Cox02/10/2015 09:23:50
557 forum posts
38 photos
For ignoramuses like myself can you explain in "simple" terms
1) What does an injector do
2) How does it do it
3) What does it mean if you have water and steam coming out of the overflow.
julian atkins02/10/2015 09:33:14
1285 forum posts
353 photos
1) it squirts hot water into a boiler
2) a jet of very fast moving steam condenses in water and the resulting very fast moving jet of 'water' is converted to a slower moving jet of sufficient pressure to overcome the boiler pressure.
3) it isnt working.
cheers,
julian
Stuart Bridger03/10/2015 12:24:47
566 forum posts
31 photos
I'm glad someone was brave enough to ask that question
Michael Malleson06/10/2015 10:38:05
62 forum posts
At last, an explanation without any mathematics, none of which helps anyway when the darned things just won't work.
Mike.
Paul Lousick06/10/2015 11:35:09
2276 forum posts
801 photos
Injectors are designed to work at different pressure ranges and should be selected to suit your operating pressure. They often do not work when too hot. (turn the water on first, then the steam. Then steam off first and water off last) (unless it is a lifting type injector with only a steam valve). If not working they may need cleaning by dismantling and soaking the cones in vinegar to remove calcium deposits.
Mark P.06/10/2015 12:26:08
634 forum posts
9 photos
I thought that there was an imp inside with a little pump.
Nigel Bennett06/10/2015 12:48:32
500 forum posts
31 photos
Apart from trawling back through ME over the years for Lawrie Laurence's and others' articles, "Miniature Injectors Inside & Out" by DAG Brown is a mine of information on the subject. He also covers fault-finding and the design of water valves. Even if you don't intend making your own, it's probably worth a punt.
Neil Wyatt06/10/2015 15:25:45
19226 forum posts
749 photos
86 articles
Want a non-mathematical description of the physics?
Hot steam is squirted out of a nozzle, sucking up cold water. The water has to be cold enough it doesn't boil, but mixes with the steam to form a powerful jet of hot water, collected by another cone, that 'punches' its way into the boiler past a valve.
Andrew Johnston06/10/2015 15:54:36
7061 forum posts
719 photos
Posted by Neil Wyatt on 06/10/2015 15:25:45:
Ah, but how does the non-mathematics explain the following? We have two input streams; a mass of steam at boiler pressure, so it has stored energy due to the pressure, and a greater mass of water at atmospheric pressure, so no stored pressure energy. We end up with the combined mass of steam and water at, or more than, boiler pressure, so lots of stored pressure energy. Where does the extra energy come from?
Neil Wyatt06/10/2015 17:05:58
19226 forum posts
749 photos
86 articles
I know this is a trick question, but I deliberately didn't complicate my original answer with the high efficiency of injectors...
What extra energy?
If you turned the boiler heat off and ran the injector the boiler would cool down, and lose pressure, more quickly than with the injector off.
It's a very efficient process, but some heat will always be lost through the injector pipework and the injector itself.
If you tried to stop this by insulating the injector, it would get so hot that the incoming water would boil and the injector would stop working.
Muzzer06/10/2015 18:20:56
2904 forum posts
448 photos
Presumably the "heat of condensation"?
Andrew Johnston06/10/2015 21:35:36
7061 forum posts
719 photos
I'm sorry I asked now. Never mind, I'll run through the literature and sort it out for myself.
Paul Lousick06/10/2015 23:08:08
2276 forum posts
801 photos
When it works, I just call it man made magic !
Stewart Hart07/10/2015 07:11:24
674 forum posts
357 photos
Posted by Andrew Johnston on 06/10/2015 15:54:36:
The cold water condenses the steam this causes a vacuum sucking in more water and starting the whole process off, this is why they don't work very well with hot water:- hotter the water the less steam it can condense the lower the vacuum, also this is why its important that none of your joints leak as it will just sucks in air.
I was lucky enough to have been tutored by a very knowledgeable and skill-full model engineer in their manufacture, with his help I made a batch of five that all worked I was chuffed to death, making your own injectors certainly give you bragging rights on the track.
Stew
julian atkins07/10/2015 08:57:54
1285 forum posts
353 photos
hi Stew,
in the interests of accuracy may i be permitted to correct you on a few points?
it is not the case that 'the cold water condenses the steam this causes a vacuum'. when the steam leaves the end of the steam cone nozzle it is already below atmospheric pressure. the steam nozzle plus first half of the combining cone acts as a sort of ejector. if the proportions and details of these parts and the check valve are correctly designed and made, the injector will be of the lifting type. it will also then be 'automatic' and self-restarting.
it is not the case that 'the hotter the water the less steam it can condense the lower the vacuum'. hot water will be lifted as much as cold water. what does happen with hot water (above 46 degrees celcius) is that in the combining cone the steam's considerable latent heat causes the water to boil, and so the injector wont work.
cheers,
julian
Cornish Jack07/10/2015 11:54:26
1228 forum posts
172 photos
Practically all modern aircraft use the same principle for fuel tank 'draining' (i.e. getting the dregs out) known as jet pumps. I used to explain the operation as being similar to egg blowing but that only worked with the 'wrinklies'. The young F/Os just looked blank, so, much dry marker expenditure and hand-wagging ensued. How do they work?? Yes, jolly good question, well formulated, nicely presented, thank you!!!crook The parallel is asking an Italian to describe Sophia Loren with his hands tied behind his back.
rgds
Bill
Muzzer07/10/2015 12:58:45
2904 forum posts
448 photos
Never been convinced I understood exactly how these are connected up. I understand the use of venturis to draw water in with the steam and also for slowing the stream down again to allow the pressure to overcome the boiler pressure. Obviously the water (and overflow) connections must be at low (atmospheric) pressure otherwise the steam wouldn't come out in the first place.
My question is - is there a significant fraction of the steam lost to the overflow connection? I always imagined there must be but haven't ever heard it explained. When using the injector, is a fair bit of steam dumped up the stack?
Murray
Neil Wyatt07/10/2015 14:35:51
19226 forum posts
749 photos
86 articles
Murray
No.
jason udall07/10/2015 14:47:44
2032 forum posts
41 photos
All seems odd to me.
"Slow down the steam to overcome the boiler pressure"...???
That would seem to , when taken to extreme.allow a simple pipe loop . steam to steam. to induce a circulation ...
Mmm stick a turbine in the way and you have free energy...can't be right...
Yes I know these things work but always smelt abit fishy on the thermodynamic front.
jason udall07/10/2015 14:50:05
2032 forum posts
41 photos
And if this seems odd take a look at vortex nozzles. ..very cold air from compressed air..
