Cylinder Honing Tool
ChrisH26/08/2015 21:33:29
1023 forum posts
30 photos
Where can I buy a tool at a reasonable price for honing model engine sized cylinders, that is, say ¾" diameter upwards?
Chris
John Rudd26/08/2015 21:44:51
1479 forum posts
Polly models do one.....their E1 model goes down to 1/2".. Cat price is £14-95
Look under their tools section ...
hth....
ChrisH26/08/2015 21:52:42
1023 forum posts
30 photos
Thanks John, that will do for starters - Polly was the one place I didn't look at!
Chris
NJH26/08/2015 21:56:27
2314 forum posts
139 photos
Chris
Yes I used one of Polly's hones and it worked well. You need to keep it lubricated, keep it moving and keep from spraying oil all round the workshop!
My solution was to do it on the drill press where the constant in / out action is easier. The oil was contained by " modifying" a tub of peaches ( I added the peaches to my breakfast cereal ..yum yum) It took a while but worked well.
Norman
Honing on Drill Press
Bob Brown 126/08/2015 22:15:29
1022 forum posts
127 photos
They are also available from other sources like **LINK** as they are used to hone brake cylinders. As Norman said can be messy and the mess is abrasive.
Bob
will hawkes26/08/2015 22:18:24
20 forum posts
you can get brake cyl hones with 3 stones that are adjustable from 19mm to about 50mm they cost about £8 inc post from most suppliers, i use the larger ones on bike cylinders , so i can see no problemsusing them for your model engines, will.
Roderick Jenkins26/08/2015 23:08:53
2376 forum posts
800 photos
I've got the Sealy kit which is widely available. I used it on my Wyvern cylinder and only this weekend:
Works very well lubricated with my usual cutting fluid. As for mess, they are not nearly as bad as lapping. The stones don't lose much material, most of the mess is from the item being honed. They are not as good as laps at producing a truly parallel bore but I found it good enough to get to 1/2 thou over a 4" length - certainly good enough for a piston with a ring. The hone got rid of a bit of a taper on the casting above in about 5 minutes.
Rod
Ian S C27/08/2015 11:55:50
7468 forum posts
230 photos
I start with a cylinder hone, then move on to a wooden lap as I want a fine finish for my hot air engines. For an engine with CI rings, a hone leaves a good pattern on the bore to aid bedding in, and retaining an oil film.
Ian S C
David Clark 127/08/2015 12:24:39
3357 forum posts
112 photos
10 articles
I think Polly sell honing fluid as well.
ChrisH27/08/2015 13:30:47
1023 forum posts
30 photos
Thanks guys, I will get the E1 hone from Polly plus the oil, should cover my needs.
Chris
Ajohnw27/08/2015 17:40:38
3631 forum posts
160 photos
I came across some shotgun honing stones once which I suspect might go smaller but I couldn't find a holder. I did wonder if the holders were adjustable too. They might be in order to obtain precise sizes.
Alex Collins27/08/2015 19:55:16
147 forum posts
38 photos
Turn a bit of rod just under size.
Cover in paper tape and Grinding paste.
Run in the lathe at a fairly slow speed.
Run your cylinder up and down for ~20 mins adding more paste as you go.
Repeat with the fine paste.
Take care not to bell the ends out.
Does it work as a method - 100% Yes.
Will it do what you need is up to you to decide.
jacques maurel28/08/2015 15:51:56
84 forum posts
20 photos
Hello
You'll soon dicover that honing is boring, so why not try boring instead of?
J Maurel
Ajohnw28/08/2015 16:09:50
3631 forum posts
160 photos
Posted by jacques maurel on 28/08/2015 15:51:56:
Hello
J Maurel
Probably because honing can produce both rounder and more parallel holes. With the some types of hones holes can be finished to a few microns, finish and everything else.
Ian S C29/08/2015 12:47:14
7468 forum posts
230 photos
With first honing, then lapping you can get a mirror finish, ideal for a cylinder using soft packing, or O rings, if you use CI rings, just hone it, the rings will bed in with the slight roughness, which will also hold a film of oil.
Honing is boring, but nothing on lapping.
Ian S C
Edited By Ian S C on 29/08/2015 12:48:43
