Home Design, i wish to reassure myself on a few things
Kyle MacDonald | 23/08/2015 18:13:53 |
1 forum posts | I am designing and planning to build a personal submarine using a kayak as a base and building around it. my concern : - thick pvc is what I am thinking of using as the housing, but will it be strong enough to with stand two atmospheres of pressure at 30ft underwater?. I don't think ill dive to that but I want to have that room to go deep. I wish to keep this as inexpensive as possible. any help or suggestions will be great |
John McNamara | 24/08/2015 15:15:54 |
![]() 1377 forum posts 133 photos | Hi Kyle Welcome aboard The MEW Forum Gee you have picked a hard project. I guess you have tried the following Google search? The words inexpensive and safety are mutually exclusive. If you are not familiar with designing this sort of craft I suggest you seek professional help before starting. Building and using an untested design could be catastrophic. All commercially designed and built submarines are given extensive and rigorous testing both in the dry dock and at sea before being put into service. Edited By John McNamara on 24/08/2015 15:19:21 |
David Clark 1 | 24/08/2015 15:19:25 |
![]() 3357 forum posts 112 photos 10 articles | If it does not work you will save the cost of a coffin! |
Bikepete | 24/08/2015 15:21:38 |
250 forum posts 34 photos | A 'wet' sub (i.e. no pressure vessel - pilot is in standard scuba/dive gear) is a much less risky DIY venture... |
JasonB | 24/08/2015 15:28:54 |
![]() 25215 forum posts 3105 photos 1 articles | Depends how big an area your "thick" PVC will have to span, if its too large an area it will collapse but suitably supported may be OK depending of spacing of supports and what you call "thick" |
Muzzer | 24/08/2015 15:33:27 |
![]() 2904 forum posts 448 photos | Truly a Darwinian pursuit! I hope you have no family or dependants. At 30 feet, the pressure is about 13 PSI (using old units). Thick PVC would make an adequate coffin but to my knowledge nobody has made a submarine from that material. Plenty of home made mini subs are made and tested in the waters around Florida. Try searching "narco-submarine" for some ideas. |
JasonB | 24/08/2015 15:41:36 |
![]() 25215 forum posts 3105 photos 1 articles | Looks like it can be done with PVC drain pipe which would have more strength than flat sheet |
David Jupp | 24/08/2015 15:43:10 |
978 forum posts 26 photos | It sounds as if you are planning to have a pressure hull - I wouldn't think a kayak would be much good for that (shape for one thing). Amongst numerous other issues to consider - PVC can be brittle at low temperature. If you are actually planning a propulsion device for a SCUBA diver, things may not be so tricky. This project sounds rather like a life support system, so people may be cautious with giving any advice. |
Nick_G | 24/08/2015 16:01:07 |
![]() 1808 forum posts 744 photos | . It was done in WW2 **LINK** Don't think it was a pressure hull design though. Think I saw a documentary about it years ago. Perhaps it's on youtube.
Regards, Nick |
Neil Wyatt | 24/08/2015 16:02:10 |
![]() 19226 forum posts 749 photos 86 articles | I guess the overall pressure on a kayak will be 20-30 tons or more. at 30 feet deep. Without wanting to put a damper on this idea, I strongly advise that any design is checked by a qualified engineer as failure will almost certainly have fatal results. Personally I would go for building an ROV first to get some real experience. Neil |
Michael Gilligan | 24/08/2015 16:05:12 |
![]() 23121 forum posts 1360 photos | Posted by Kyle MacDonald on 23/08/2015 18:13:53:
I am designing and planning to build a personal submarine using a kayak as a base and building around it. my concern : - thick pvc is what I am thinking of using as the housing, but will it be strong enough to with stand two atmospheres of pressure at 30ft underwater?. I don't think ill dive to that but I want to have that room to go deep. I wish to keep this as inexpensive as possible. any help or suggestions will be great . Kyle, Before you do anything dangerous ... Please make a test tank and do some practical experiments. Note: I have used this method [albeit only to a test depth of about six feet] on some military equipment , so I know that the principle works: The materials are cheap: A domestic cold-water tank with a lid, and some plastic rainwater pipe. ... plus whatever bracing materials you might need
You will probably be surprised. MichaelG.
Neil Wyatt | 24/08/2015 16:06:32 |
![]() 19226 forum posts 749 photos 86 articles | A cautionary tales near the end of this: Neil |
Ajohnw | 24/08/2015 16:16:51 |
3631 forum posts 160 photos | Posted by Bikepete on 24/08/2015 15:21:38:
A 'wet' sub (i.e. no pressure vessel - pilot is in standard scuba/dive gear) is a much less risky DIY venture... Also much easier to get to sink. John - |
Nick_G | 24/08/2015 16:23:26 |
![]() 1808 forum posts 744 photos | . Do you intend to use it for running 'coke' for Columbian drug barons.? If so you will need good sonar fitted to stop you bashing into sunken prams and cars as you go all stealth like on your deliveries up the local canal.
Nick |
Alan Waddington 2 | 24/08/2015 16:46:02 |
537 forum posts 88 photos |
Ha ha good call, however more likely it's to transport food and things under his bridge......... Posted by Nick_G on 24/08/2015 16:23:26: . Do you intend to use it for running 'coke' for Columbian drug barons.? If so you will need good sonar fitted to stop you bashing into sunken prams and cars as you go all stealth like on your deliveries up the local canal.
Nick
David Clark 1 | 24/08/2015 17:02:29 |
![]() 3357 forum posts 112 photos 10 articles | I hope this project is not a way to bring illegal immigrants into the country?
JasonB | 24/08/2015 17:13:24 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by David Clark 1 on 24/08/2015 17:02:29:
Judging by the doome and gloome and dire warnings in a lot of the above posts it may actually reduce the number |
Clive Hartland | 24/08/2015 17:20:17 |
![]() 2929 forum posts 41 photos | Just to calm things down, I can remember seeing a TV show (USA origin) and they had 2 man submersibles but they had a moon pool in the bottom of the sub. This sub would carry 2 people and the could exit and enter the sub without any problem. The conning tower was where the person steering and diving controls were There were windows to see where you go. Electric propulsion. Now, this would not suffer from compression as it had this moon pool which kept the water at bay by a slight over pressure in the sub. More than likely made of fibre glass/resin and they always seemed to be yellow colour. Must have been safe as there was a nubile woman in it! The passengers/operators used no scuba gear and free dived from it. I am sure it was commercial at that time. Clive |
jason udall | 24/08/2015 17:39:54 |
2032 forum posts 41 photos | Just a steading thought. Submarine "escape" hoods were pretty much just that..a rubberised canvas hood filled with air bled in from a total loss system...it basically over flows out the bottom. ..air is basically supplied freely in the hood..like a classic diving suit... Extend this and you have a submersible. . Neglecting the controlled buoyancy. .pressure /flow regulation...propulsion. .. Think diving bell .. Before any form of pressurised breathing is attemped...do a scuba course..and learn some of the dive medicine. . |
jason udall | 24/08/2015 17:44:22 |
2032 forum posts 41 photos | Ok..back to the basic engineering..in a dive bell mode..the bell is at no pressure( across wall) ..if the bottom is open and air was at any pressure..the level woukd rise or fall to equalise. |
