Harry Wilkes | 16/06/2015 15:59:57 | |
![]() 1613 forum posts 72 photos | Hi Guy's I need to make a couple of tapered dowel pins which I understand are 1:48 but can anyone advise me what angle I would need to set my cross slide ? Thanks H | |
Capstan Speaking | 16/06/2015 16:15:32 | |
![]() 177 forum posts 14 photos | It's 0.595 degrees. I'd just buy a pack. | |
KWIL | 16/06/2015 16:19:00 | |
3681 forum posts 70 photos | 1 :48 taper, tan setover = 1/48. ....1.19 degrees. good luck. Much easier to buy them | |
Capstan Speaking | 16/06/2015 16:20:34 | |
![]() 177 forum posts 14 photos | Harry asked what the offset was. You've given the included angle. | |
Keith Long | 16/06/2015 16:38:33 | |
883 forum posts 11 photos | Just for the record, if the taper dowels are METRIC then the standard included taper is 1:50 not 1:48 which is for IMPERIAL | |
Neil Wyatt | 16/06/2015 17:23:23 | |
![]() 19226 forum posts 749 photos 86 articles | > Just for the record, if the taper dowels are METRIC then the standard included taper is 1:50 not 1:48 which is for IMPERIAL Use brass pins and an 'ammer. Neil | |
Harry Wilkes | 16/06/2015 21:12:45 | |
![]() 1613 forum posts 72 photos | Posted by Capstan Speaking on 16/06/2015 16:15:32:
It's 0.595 degrees. I'd just buy a pack. Many thanks to all for the info, Capstan Speaking if you can tell me where I can by a pack of 5/32 I'd certainly buy them ! I have checked out several website thrown up by google but 5/32 seem's to be the illusive size Cheers H | |
Vic | 16/06/2015 21:48:47 | |
3453 forum posts 23 photos | http://www.boneham.co.uk/resources/Dowel%20Pins%20and%20Clevis%20Pins.pdf
Bob Brown 1 | 16/06/2015 22:14:51 | |
![]() 1022 forum posts 127 photos | or here **LINK** | |
stan pearson 1 | 16/06/2015 22:16:01 | |
![]() 135 forum posts 2 photos | Hello H Reeves sell them 5/32" x 1" long Stan | |
Harry Wilkes | 16/06/2015 22:32:33 | |
![]() 1613 forum posts 72 photos | Thanks again guy's Cheers H | |
Lambton | 17/06/2015 05:14:00 | |
![]() 694 forum posts 2 photos | You will need a taper reamer for preparing the hole. Drill it first to the small end diameter of the pin then carefully ream until the pin engages properly. | |
Harry Wilkes | 17/06/2015 05:15:48 | |
![]() 1613 forum posts 72 photos | Posted by Bob Brown 1 on 16/06/2015 22:14:51:
or here **LINK** Wow £6.95 for a pack of 5 and wait for it £6.50 P&P
Clive Hartland | 17/06/2015 07:59:45 | |
![]() 2929 forum posts 41 photos | The modern method now is, 'Roll Pins'. most of the new kit coming in has roll pins on shafts if they have to lock things to the shafts. makes servicing much easier as you do not have to hammer seven bells out of something to get a taper pin out. Clive | |
julian atkins | 17/06/2015 08:24:03 | |
![]() 1285 forum posts 353 photos | hi harry, if you pm me i will send you a couple. cheers, julian | |
Michael Gilligan | 17/06/2015 08:39:08 | |
![]() 23121 forum posts 1360 photos | Posted by Harry Wilkes on 17/06/2015 05:15:48:
. Harry, It looks like your opening question was the right one to ask !! What I don't think you have told us is whether the tapered holes already exist. i.e. are you making something, or refurbishing it ? This is significant because, as mentioned by others; you need a tapered hole for a taper pin. If the hole already exists, you need to measure it carefully ... and if not, you will need a reamer. Given the close similarity between 5/32" x 2" 1:48 and 4mm x 50mm 1:50 ... be very careful to check what people are trying to sell you. If you have the reamer, it's best to put it in the lathe and set the top-slide to match its taper. If you don't have the reamer, then you could make a D-bit version from Silver Steel, and turn it and the Pins at the same top-slide setting. Of course; Clive's roll-pins have merit in the appropriate situation. MichaelG. . Edit: ... or you might hit lucky, and find a nice chap like Julian Edited By Michael Gilligan on 17/06/2015 08:41:13 | |
Ajohnw | 17/06/2015 09:47:22 | |
3631 forum posts 160 photos | I noticed rather a long time ago that plastic moulding tools for battery cases were not dowelled any more and used roll pins and asked about it as given the size of the chunks of steel and the location needed it surprised me. It seems that roll pins are sized so that smaller ones can be knocked into larger ones. That's what they were doing. This must be at least 15 years ago. Tapered pins have the advantage that precise diameters are not needed only a fairly precise taper. Roll pins are designed to be driven into drilled holes. John - Edited By John W1 on 17/06/2015 09:51:57 | |
Harry Wilkes | 17/06/2015 15:58:36 | |
![]() 1613 forum posts 72 photos | Posted by julian atkins on 17/06/2015 08:24:03:
hi harry, if you pm me i will send you a couple. cheers, julian Julian many thanks for your kind offer will PM you, Michael yes I have a tapered reamed hole ready for the the dowel ! Cheers H | |
Harry Wilkes | 17/06/2015 16:11:50 | |
![]() 1613 forum posts 72 photos | Just to fill you guy's in where the piston rod is fitted into the crosshead on my traction engine a tapered dowel pins is used it should be a small tapered wedge but in my case it's a dowel. The one I fitted last time was very tight when I came to remove it and I damaged getting it out Cheers H Posted by Michael Gilligan on 17/06/2015 08:39:08: Posted by Harry Wilkes on 17/06/2015 05:15:48:
Paul Lousick | 17/06/2015 23:05:22 | |
2276 forum posts 801 photos | Machinists Workshop just posted some info about taper pins:
Taper Pin Tips By David Winkel I’m sure most of us have had to deal with removing taper pins in machinery that were driven home by a gorilla with a 10 pound hammer. After driving one of these stubborn pins out, do yourself, or the next guy, a favor and coat the new pin with a thin film of Moly Sulfide grease. Tap it home until seated, but no more!
Pins are sized by the large end diameter and you need to measure the large end hole diameter to determine the proper size replacement to use. Often the lip of the hole will be munged so you should measure the hole down a little deeper. Here’s a trick: choose a burr-free drill shank with a diameter that allows it to go down the hole perhaps 1/8” or so. Measure the insertion depth and call it “D.” Mic the shank diameter and call it “d.” A pin’s standard taper is 1/4”/foot or 1/48”/inch. So, the big end hole diameter will be D/48 + d One final trick is to make the pin slightly shorter so the small end is recessed in a pocket about 1/16” deep when driven home. That will keep the drive-out pin punch centered for easier removal by the next guy. |
