Brian Rice 1 | 28/01/2015 19:21:21 |
82 forum posts 11 photos | any one tried ball turning on a mini lathe looking at this attachment. http://www.chronos.ltd.uk/engineering-tools/2013/2562/ |
LADmachining | 28/01/2015 19:35:41 |
![]() 126 forum posts 11 photos | I asked a similar question several months ago.
http://www.model-engineer.co.uk/forums/postings.asp?th=94307
Rgds,
Edited By LADmachining on 28/01/2015 19:36:03 |
Brian Rice 1 | 28/01/2015 20:30:25 |
82 forum posts 11 photos | Did you purchase one Anthony? |
mick70 | 29/01/2015 07:46:10 |
524 forum posts 38 photos | bought one couple of weeks ago. only used it to make some radius dies for ring roller i was making but works brilliantly very impressed with it. hoping to get some spare time to have a go at making ball next week. |
Brian Rice 1 | 29/01/2015 10:12:13 |
82 forum posts 11 photos | Posted by naughtyboy on 29/01/2015 07:46:10:
bought one couple of weeks ago. only used it to make some radius dies for ring roller i was making but works brilliantly very impressed with it. hoping to get some spare time to have a go at making ball next week. Hi what machine are you using it on?
mick70 | 29/01/2015 12:46:06 |
524 forum posts 38 photos | promise not to laugh?
it's a clarke 430. |
Brian Rice 1 | 29/01/2015 13:15:24 |
82 forum posts 11 photos | Hay man if it does the job why not, engieering is a bit like photography (which I'am into ) you get your brand snobs I have seen it a lot you get the guy with the all singing and dancing top of the range camera and he never takes it of auto,I have in the past had fully equipped workshop but marriage brake up put pay to that,now have a mini lathe and mill which I get just as much enjoyment out of and the best bit it's in a spare room no more waiting for the workshop to warm up before you can make a start. Well of to make more chips. |
mick70 | 29/01/2015 14:02:22 |
524 forum posts 38 photos | i know what you mean about snobs. left another forum cos comments about having clarke lathe. will admit it needed tweeking but what doesn't? |
Neil Wyatt | 29/01/2015 14:46:05 |
![]() 19226 forum posts 749 photos 86 articles | I wouldn't worry, you 'umble eeditor has a Clarke CL300M, albeit much modified Neil |
mick70 | 29/01/2015 16:47:36 |
524 forum posts 38 photos | can't find much on mods for clarke lathes. apart fron couple of articles years ago. |
Brian Rice 1 | 29/01/2015 17:30:29 |
82 forum posts 11 photos | Posted by naughtyboy on 29/01/2015 14:02:22:
i know what you mean about snobs. left another forum cos comments about having clarke lathe. will admit it needed tweeking but what doesn't? I asked on another site some very good answers,but other take it you been in engerneering all your life when it is just a hobby to whittle away the day now I've retired,as far as the Clark goes all just about from the same factory's just diffren colours and bed sizes. |
oldvelo | 30/01/2015 01:51:43 |
297 forum posts 56 photos | Hi Brian Ball turning is a very pleasing job on a lathe real hands on work Ignore the snobs not worth bothering with the inadequate sods who think that if you put someone down it will elevate their standing in life. We share thoughts and ideas to attempt to help make life easier for all that want to learn more. Motto "Attack the problem not the person". The ball turners I use is a Boring head mounted on a sturdy bracket the bolts on the topslide with the toolpost removed. Rambling off topic!!!! Neil I see that you have an Amp Meter on the control box in the photo of your lathe an essential in my biased opinion for any machine tool. Eric |
Bill Pudney | 30/01/2015 02:19:53 |
622 forum posts 24 photos | Posted by oldvelo on 30/01/2015 01:51:43:
Neil I see that you have an Amp Meter on the control box in the photo of your lathe an essential in my biased opinion for any machine tool. Eric Quite right! When I had to work for a living I was trying to establish what a "safe" level was for low rate production machines. Never came to a conclusion, except that sometimes more was better than less!! cheers Bill |
John Stevenson | 30/01/2015 08:55:19 |
![]() 5068 forum posts 3 photos | At the risk of being bias as many know I do do some work for ARC but I use one of these cheap gismo's.
Simple, quick, swaps easily between lathes and does the job.
I had one for the CVA I used to own and it was so complex to set up it was quicker to linish a ball on
This one does what it says on the tin. |
CotswoldsPhil | 30/01/2015 10:10:13 |
![]() 196 forum posts 112 photos | I was making this attachment when the article about using a boring head as a ball-turner was published. It works very well once you get your head around setting it up and grinding a knife tool on the end of a 3/8 HSS toolbit. I made the adapter for the George Thomas type boring head made many moons ago. Setting up is made a lot easier with the QCTH. Getting the cutting tool geometry is a bit tricky The finished ball for the handle of the ball-turner attachment! The finish is straight from the tool. Regards Phil H Edited By CotswoldsPhil on 30/01/2015 10:14:21 |
Brian Rice 1 | 30/01/2015 10:18:31 |
82 forum posts 11 photos | Thank you all for your help ,John I have looked at the ARC attachment is it possible to use index cutters in it I do not have the knowledge or the equipment to re sharpen tool steel very small workshop in home so bench space is a premium plus noise I'm sure next door put a glass on thr wall to hear what going on. |
Ian S C | 30/01/2015 10:54:23 |
![]() 7468 forum posts 230 photos | Brian, a small bench grinder would be no noisier than the lathe, and quieter than the kitchen wiz/cake mixer in the kitchen. Once you master grinding up lathe tools you may find that you use them for general turning as well. Ian S C |
Nobby | 30/01/2015 12:09:29 |
![]() 587 forum posts 113 photos | Hi Edited By Nobby on 30/01/2015 12:10:02 |
Neil Wyatt | 30/01/2015 15:01:12 |
![]() 19226 forum posts 749 photos 86 articles | > Neil I see that you have an Amp Meter on the control box in the photo of your lathe an essential in my biased opinion for any machine tool. It's driven by a VFD output to read a percentage of rated power, so it give a true indication of how hard the motor is working. Don't write off using form tools: Neil Edited By Neil Wyatt on 30/01/2015 15:02:21 |
martin perman | 30/01/2015 15:15:09 |
![]() 2095 forum posts 75 photos | Naughtyboy
Whats a Clarke 430, I have a CL500M which I'm very happy with.
Martin P |
