Help on key for 4-jaw chuck needed
Trevor Wright29/12/2014 08:37:25
139 forum posts
36 photos
Finally got round to fitting the 4-jaw chuck that came with my Bantam only to find that I did not have a chuck key.
Measured the square socket on the jaws at 7.6mm AF - roughly 19/64" - is this some special Colchester size? Or have I got some sort of mongrel chuck? The chuck has D1-3 taper lock pins that I ended up making as the price new was excessive
I can make a chuck key but would prefer an off-the-shelf as homemade will not be strong enough.
Trevor
Lambton29/12/2014 09:00:07
694 forum posts
Trevor,
I have made several chuck keys over the years always from large high tensile bolts. M16s are ideal for smallish keys.
I have also made arbors for 1"bore lit saws from M24 bolts reducing the shank to 16mm threading it 20tpi to suit my Clarkson chuck, turning the hexagon off the head then turning a suitable spigot to take the slit saw.
A chuck key needs to be tough resisting torque just like a high tensile bolt. Made directly from such a bolt no heat treatment is necessary. Don't use silver steel as it is not suitable for this application. ( I am sure many of you will tell me they have successfully used silver steel for chuck keys but I have always found it to be a greatly over-rated material for many applications).
JasonB29/12/2014 09:15:18
Just measured my two Bisons
3-jaw 9.5mm hole, 9.0mm key
4-jaw 7.2mm hole, 6.7mm key
So about a 7mm or 9/32 square end should do you.
Trevor Wright29/12/2014 09:19:07
139 forum posts
36 photos
Lambton,
With you on Silver Steel, it is soft un-treated and brittle when hardened. Like the idea of making from high tensile bolts, the metal is sufficiently tough but not brittle.
The lack of replies leads me to the conclusion that I will be knocking one up tonight.....
Trevor
Edited By Trevor Wright on 29/12/2014 09:22:17
Trevor Wright29/12/2014 09:21:55
139 forum posts
36 photos
Jason,
Cannot find a 7mm or 9/32" at the usual suppliers.....will have a more detailed look at lunch break....thanks.
trevor
JasonB29/12/2014 09:24:27
Bison list 7mm as spares, you could always grind down the next size up from a cheaper source. Or try somewhere like Home & workshop or G&M Tools
Trevor Wright29/12/2014 09:36:23
139 forum posts
36 photos
Thanks Jason,
emails sent to both contacts.
Trevor
Gordon W29/12/2014 10:02:34
2011 forum posts
The square rod in most door locks is about the right size 5/16" or 7 , 8mm. Ive made a few keys and all still working.
Trevor Wright29/12/2014 10:30:59
139 forum posts
36 photos
Typical, found one from cromwell tools, IND4905910K, out of stock.....
Gordon, could turn a diameter and press fit to a T bar.......need a 4 jaw for that though......
Trevor
Bazyle29/12/2014 10:40:23
6956 forum posts
229 photos
Posted by Trevor Wright on 29/12/2014 09:19:07:
Just how many replies do you expect in 45 minutes on a Monday morning? On a normal day I would have spent most of that on the M25 traffic jam but as it is a holiday beer I had barely got up and lit the fire by that time. Only just got awake enough to log in
The key for my Boxford 3 jaw is just mild steel but maybe Colchester owners are a tougher breed.....teeth
Gordon W29/12/2014 11:46:31
2011 forum posts
I just drilled a bit of rod in the end , filed the corners off the square and hammered it in. Weld up and cross drill for tommy bar. I f no welding gear soft solder down the hole will hold it. I'm trying to type this in a woolly hat and padded jacket but my fingers are going. Back to welding, at least keeps the fingers warm.
Russell Eberhardt29/12/2014 12:05:07
2785 forum posts
87 photos
Posted by Trevor Wright on 29/12/2014 09:19:07:With you on Silver Steel, it is soft un-treated and brittle when hardened. Like the idea of making from high tensile bolts, the metal is sufficiently tough but not brittle.
It all depends on the correct heat treatment.
Russell.
Trevor Wright29/12/2014 12:36:31
139 forum posts
36 photos
Gordon, was not having a go at you, just trying to be ironic, seems some cannot see it.......
When a post has over 50 views and only one reply it kind of confirmed what I was already thinking, hence the comment. Jasons post was there when I submitted.
trevor
Bob Perkins29/12/2014 13:20:33
249 forum posts
60 photos
I made a second chuck key for mine out of a bit of odd stock I had lying around, and it's been fine. it might be just me but I find two chuck keys essential for setting and making fine adjustments, loosening and tightening opposite jaws at the same time.
Bob..
Russell Eberhardt29/12/2014 14:26:24
2785 forum posts
87 photos
I find it hard to believe that a home-made key will not be strong enough. My British made chucks all have keys made from a soft material, most likely mild steel. The only one with a hard key is Chinese. If a mild steel one isn't strong enough I would suggest that you are over-tightening the chuck.
As far as silver steel is concerned, it has about twice the yield strength of mild steel in its soft, supplied state. 8.8 HT fasteners are only slightly better:
Yield strengths:
  • Mild steel 250 MPa
  • Silver steel 480 to 690 MPa
  • 8.8 HT 640 MPa
Russell
Gordon W29/12/2014 14:48:59
2011 forum posts
I did not for a minute think you were having a go, don't care if you do. As others have said mild steel is good enough. I made two small keys,one short and one longer. Made from black bar with brass knurled knobs on. These are invaluable for setting the 4 jaw before final tightening with the big key.
colin hawes29/12/2014 18:53:13
570 forum posts
18 photos
I made a mild steel (EN 3B) key for a 5" chuck 30 years ago. I'm certainly not strong enough to twist it but then I never use a long tube on it to do so. Colin
ANDY CAWLEY30/12/2014 07:23:13
190 forum posts
50 photos
When making your key make sure it is long enough for the Tommy bar to clear the dial gauge used in setting the work in the chuck. I made mine too short and it is a constant source of irritation, I must make a longer one!😢
Greg Ross30/12/2014 09:52:00
2 forum posts
By the use of D1-3 it indicates the machine is probably a Chipmaster or a Bantam. Just a point to watch, the camlock holes are almost the same size square as the 4 jaw chuck holes. Don't get the spanners/keys mixed up, you will finish up splitting the corners of the square holes. A correct fitting spanner/Key is essential.
Ian S C30/12/2014 10:43:32
7468 forum posts
230 photos
The chucks that came with my lathe use 10 mm keys, and when I change jaws, or move them over a long distance I use the speed wrench from my 3/8" drive socket set (Just if anyone is interested).
Ian S C
