kevin large | 23/12/2014 17:39:56 |
143 forum posts 3 photos | hi all I have bought my first lathe all I know is its a union lathe quite basic I think it does not have a power feed my question is the leather belt slips and seems a bit loose I cant see any way of tightening it it does have a metal clip joiner should I cut it a bit and make it tighter if so how tight ? also an old fellow told me they used to paint the belts with something in the old days to stop them sliping but didn't remember what it was called. any help appreciated |
UJ Newton | 23/12/2014 19:58:05 |
23 forum posts | I sure you will get enough info from people on the forum but there is a first rate book abouts belts and belting by Stationary Engine Magazine.. |
Bazyle | 23/12/2014 20:45:52 |
![]() 6956 forum posts 229 photos | have you seen this site Check the belt isn't covered with oil. It may need cleaning, drying. The old fellow was referring to 'belt dressing' but not sure if it is still around. The modern stuff is probably for car fan belts, not leather. Google 'lathe belt dressing'
Nobby | 23/12/2014 21:16:01 |
![]() 587 forum posts 113 photos | Hi Kevin |
UJ Newton | 23/12/2014 21:39:49 |
23 forum posts | 2parts lard 1part cod liver oil..you need proper raw lard not the stuff wrapped in packs..See Practical machinist forum.. Could try canvas belt..still buy it |
UJ Newton | 23/12/2014 21:45:05 |
23 forum posts | phone up a museum which has belt driven machines and ask..I m trying to be a volunteer at Stretham Old Engine but I think they are all on holiday at the moment..Cambridge Museum of Technology might be easier |
Nicholas Farr | 24/12/2014 02:29:09 |
![]() 3988 forum posts 1799 photos | Hi Kevin, you may wish to consider this **LINK** I have no connection with this company, but have used some of thier products, including belt spray. Regards Nick. |
Roger Provins 2 | 24/12/2014 04:59:45 |
344 forum posts | If you're anywhere near Gloucester I've a can of Rocol you can try out. Roger |
Paul Lousick | 24/12/2014 05:12:36 |
2276 forum posts 801 photos | Hi Kevin, I am surprised that there is no way of adjusting the belt tension. There is normally some way of moving the drive pulley or moving an idler pulley to tension the belt. My 1948 Southbend lathe has flat belts and a lever that moves the motor. If you cut the belt you will probably need a new belt clip to match the one on the other end of the belt. (could be hard to find as they are not so common now). And if you replace the clips on both ends the belt could be too short. I have bought a can of spray for car fan belts from a car accessory shop to prevent slippage of rubber belts. Should also work on leather. Paul. |
Brian Wood | 24/12/2014 10:00:01 |
2742 forum posts 39 photos | Hello Kevin, You are looking for 'belt stick', it is a black resin based material that is applied to the inside of the running belt where friction melts it and impregnates the belt. You get a satisfying sticky tearing noise as the belt runs off the slack side of the pulley. It comes in a paper wrapped stick about a foot long. Try agricultural engineers for it, it used to be available in Yorkshire up to 20 years ago. Old traction engine owners are likely to know of it as well, the ones that demonstrate belt driven machinery at fairs. www.lathes.co.uk is another possibility, they sell flat belt jointing. Belt dressing is lanolin based and is used to soften old belting, it won't help at all in this case. Regards Brian Edited By Brian Wood on 24/12/2014 10:01:48 |
kevin large | 24/12/2014 10:06:01 |
143 forum posts 3 photos | Thanks for all your comments I have ordered a new belt but will also try and shorten the leather one |
Speedy Builder5 | 24/12/2014 10:48:51 |
2878 forum posts 248 photos | Go to a good music shop and ask for a block of ROSIN as used on violin bows. We used to use it on dad's old flat belt lathe. I believe that Rosin is the hardened gum from pine trees. Perhaps bury it in your garden for 10,000 years then dig it up and call it amber. BobH |
Ian S C | 24/12/2014 12:19:36 |
![]() 7468 forum posts 230 photos | In agricultural use, it was common to use molasses(? spelling), only problem with that is mice, they eat the belt. There was a thread about this subject a few years back. Ian S C |
mechman48 | 28/12/2014 16:32:51 |
![]() 2947 forum posts 468 photos | I recall during my apprentice days we used to use stuff we called 'black fat' or 'clagum', came in a 25 litre drum, looked like thick black treacle, but was much denser than treacle (the black fat not the apprentice George |
Matt D | 28/12/2014 17:07:08 |
8 forum posts | I don't know if it was the best stuff but we used to put Stockholm tar on an elevator belt used for lifting bales in the 70's, it was probably pine oil. More recently on drive belts we used a spray tin of "Belt Dressing" which contained Rosin. I probably shouldn't mention it but on my Edgar 5 lathe I had a flat belt, the joint of which clicked and annoyed me so I replaced it with a cheap 40mm synchronous belt with the teeth facing out (bliss). To do this you will need some form of belt adjustment unless you are very lucky but the web is full of adverts for cheap toothed belts with quite a range of lengths. Unless such modern things offend it might be worth a look. Matt. |
Ian S C | 29/12/2014 09:45:07 |
![]() 7468 forum posts 230 photos | I'v seen car timing belts used inside out, and shortened by cutting a long chamfer, and gluing and stitching. A jocky pulley could be used instead, if of small diameter, a toothed pulley to match the belt, but if it were reasonably large a plane one would be ok. It is possible to get heat joined flat belt, it's best to give the belt supplier the size of the pulleys, and the distance apart of the shafts, they will make up the belt. One place that will sort you out for this type of belt is Ian S C
Edited By Ian S C on 29/12/2014 09:53:19 |
Gordon W | 29/12/2014 09:47:59 |
2011 forum posts | I used to like the click of the belt joint, I miss it , odd isn't it. Flat toothed belts ( timing belts ) do make good drive belts, but no need to buy, go yo nearest garage and they should have lots off cam-belt replacement jobs. |
