Here is a list of all the postings UJ Newton has made in our forums. Click on a thread name to jump to the thread.
Thread: methylated spirits |
06/02/2015 21:05:35 |
Ha ha..I burn them..Being in catering I get paid to..Utterley ridiculous! Glad about meths though..I m sure I cam build burner and tank lot cheaper than buying a gas one..Fumes arent the same either |
06/02/2015 20:33:09 |
06/02/2015 18:01:35 |
Ok Thanks Martin..whichsolder do you use? |
06/02/2015 17:34:43 |
Crikey,thats warm ..think I might just buy a gas burner ..Thanks Mike |
06/02/2015 16:51:18 |
Want to soft solder a meths burner for a very small boiler but am not sure which soft solder to use..Spent long enough on internet to write a thesis on meths !but still dont know what temperature it burns at! |
Thread: rivetting |
31/01/2015 13:40:05 |
Thank you very much |
31/01/2015 10:08:23 |
I want to rivet thin brass sheet for a 16 mil narrow guage size loco body but am not sure of the practicalities..I thought of making a flat drill but for 1/16 rivets,maybe not.. Wonder if anyone could tell me what the thinnest brass I could use to drill without damaging it. Thank you Jonathon |
Thread: Scams on ebay |
23/01/2015 08:39:17 |
I got caught once ,fortunately not much money involved, awaiting delivery of something I saw it on anorher seller site already sold..What annoyed me most was my negative feedback never appeared..How do they do that? I had a bit of a fright again when having won a first class little Flexispeed miller from an equally first class seller I saw the same machine on Tony Griffiths lathe site..The seller had put them there not the other way round! |
Thread: atraction engine |
07/01/2015 10:20:22 |
just had a very useful pm from a PYRTE buider.Minor problems which are being seen to and a lot cheaper than a Minnie..Just as well really I ve run out of storage space..Most of my workshop is still under the bed on a narrowboat..Might put a shed on the roof next |
Thread: Motor for Flexispeed Lathe |
06/01/2015 20:18:23 |
Ah .yes..100 w it is! |
06/01/2015 19:52:13 |
I ve got a Flexispeed horizontal mill and an older singer sewing machine motor(1 kw approx) I assume then they would also pair up? |
06/01/2015 17:32:59 |
Thanks Jason..I was misinformed about prices ! A minnie it is..Jonathon |
06/01/2015 16:47:38 |
A change from which lathe should I buy-which traction engine should I build?I had thought of the PYRTE but dont want to get involved until everything is tried and tested.. The PYRTE proncipal is what I m looking for though where I can buy, hopefully cheaper,and easy to machine gunmetal etc instead of cast iron .I wonder if any of the Hobbystore engines would be suitable..Thank you |
Thread: union lathe |
23/12/2014 21:45:05 |
phone up a museum which has belt driven machines and ask..I m trying to be a volunteer at Stretham Old Engine but I think they are all on holiday at the moment..Cambridge Museum of Technology might be easier |
23/12/2014 21:39:49 |
2parts lard 1part cod liver oil..you need proper raw lard not the stuff wrapped in packs..See Practical machinist forum.. Could try canvas belt..still buy it |
23/12/2014 19:58:05 |
I sure you will get enough info from people on the forum but there is a first rate book abouts belts and belting by Stationary Engine Magazine.. |
Thread: 0 MT |
18/12/2014 20:05:59 |
Thats very good..Wish my little lathe did tapers!I was wondering about cutting the top off, leaving the narrow part the right lenght then welding a little blank on and use a die for the thread..Then I realised I need a straight shank with a 0mt to get it in the lathe chuck to turn it .I m on the trail of a short one.. |
Thread: Slender rod turning for 8BA Studs |
18/12/2014 15:46:20 |
For a steady I use a knurling tool with the knurled rollers replaced.. |
Thread: 0 MT |
16/12/2014 18:33:09 |
I ve been told Sherline,Cowells and Unimat arent proper 0 mt..they ve been altered..I phoned the firms and they told me! I suppose it stops people buying cheaper ones from other firms just like camera firms uesd to do with films.. I wonder if I buy a dead centre , which is available, is it going to be possible to turn the end down on this mini mini lathe and use a die on it..It s tool steel? |
Thread: Heating a workshop. |
14/12/2014 20:32:37 |
dave..I m not Chris and there is nothing in my inbox! |
