Here is a list of all the postings kevin large has made in our forums. Click on a thread name to jump to the thread.
Thread: Potentiometers |
22/07/2021 22:15:11 |
It's Rohr wsme-250 |
22/07/2021 21:25:51 |
Not sure if this the right place for this but here goes I bought a cheap Chinese tig foot pedal for my tig welder the first time I tried it it was working backwards so I changed 2 wires around and now it works the correct way round However when the pedal is fully depressed I only get a max of 100 amps and the max of the machine is 250 amps do I need a higher or lower resistance pot? |
Thread: Aluminium |
20/07/2021 15:28:00 |
Thank you all now just need to order the aluminium and make patterns |
18/07/2021 19:05:13 |
Hi all I would like to attempt to make a seat base for my triton I would like to use aluminium but what grade would be best for forming the seat I would want to bend and weld the pieces together any help appreciated |
Thread: Boiler |
30/08/2020 17:10:30 |
Woops |
30/08/2020 16:29:58 |
Hi Tim yes it is for steam I have several small steam engines ie Stuart beam etc I've made several small steam engines just simple stuff But would now like to make a bioler to run about 60 80 psi vertical about 100mm dia and about 250 high gas heated |
30/08/2020 16:02:09 |
Hi all I would like to make a simple vertical bioler can anyone point me to where I could get some free plans And what would be the best solder to use |
Thread: Stuart beam engine |
25/10/2019 07:49:58 |
Couple more questions What pressure should the boiler run at And what should I use to seal the glands on steam chest and cylinder |
24/10/2019 07:23:07 |
Many thanks |
23/10/2019 18:55:35 |
Hi all ran it up on steam today for first time lots of steam leaks bad one around the glass tube on the boiler what should I do to seal the leaks dont want to break anything |
22/10/2019 18:30:02 |
I've recently acquired a stuart beam engine dont know much about them it's been sat in a garage for a few years I've had it running on compressed air for a while there is a very light tapping that seems to be coming from the eccentric there is a tiny bit of play ? Also should there be compression at both ends of the cylinder if I open the top drain the engine will carry on running if I open the bottom drain it will stop Any help appreciated as I am new to live steam |
Thread: Gib on abwood |
01/05/2019 12:23:18 |
Thanks all it was as said adjuster behind |
30/04/2019 19:50:53 |
Ah this maybe the problem will have another look tomorrow The screws are slotted will try some heat and see if I can get them out |
30/04/2019 18:24:19 |
6inch abwood machine vice it's got some play in it but I cantc shift the gib screws any advice on this one |
Thread: Boxford back gear |
14/04/2019 13:44:18 |
It looks like a dp16 14.5 pa still not sure how many teeth yet as I can't all the bits So if someone can confirm that would be great |
13/04/2019 20:25:25 |
While drilling a large hole in back gear the small gear broke into pieces it looks like it's been broken before and locktited n the shaft My question is how many teeth should there be and what is the pitch is what cutter would I need to make another |
Thread: Electronic advice |
03/02/2019 17:58:15 |
Ok many thanks to all and especially Dave looks like I will have to go shopping again |
03/02/2019 14:26:01 |
Oh forgot to say lathe is running fine on another vfd |
03/02/2019 14:23:53 |
I turned on the power to vfd then flicked the start switch on the vfd via a remote pod |
03/02/2019 10:38:25 |
Have added some more pictures |
