Slender rod turning for 8BA Studs
Tool for turning 2.2 mm rod for making 8BA studs
David Haythornthwaite17/12/2014 19:22:30
45 forum posts
7 photos
I have to make some 8BA studs for a steam engine that I am making.
I see there has been discussion about 8BA studs on this forum back in October 2012 and a regular contributor called NJH showed a picture of a thin piece turning tool which carried a bush to support the turned rod next to the actual cutting tool.
I would like to know where to obtain such a tool - or even know the correct name for it. I seem to remember one being detailed in MEW many years ago, but cannot find it in the index.
Can anyone help? If NJH reads this I would be interested where he bought it from.
David H
Neil Wyatt17/12/2014 19:56:42
19226 forum posts
749 photos
86 articles
Hello David,
Its a steady rest, but I think you will search along while if you seek one that works like that.
Alternatives include a box tool and making one yourself - which shouldn't be too difficult. It can be as simple as a bar clamped to the toolpost with a hole drilled in it. The difficult bit is setting the point of the tool to get the right cut.
This is my box tool:
David Haythornthwaite17/12/2014 20:48:12
45 forum posts
7 photos
Thanks Neil,
It was most interesting to see that, I particularly liked the way it uses a V steady to stop the piece from both lifting and from pushing away whilst being adjustable for many diameters without having to make bushes.
I was thinking of making something to go in the toolpost, so you could use it for long lengths and I am now wondering about a tool in the top (compound) slide, therefore finely adjustable for diameter, and providing the support from the back toolpost. I like making tools equally to making models, and despite my current resolution to "get on with the steam engine", it looks like a tool project may be on the way.
Thanks for your help. Have a great Christmas and a Happy New Year. MEW is coming along just a treat. - well done.
Thanks again.
Kind Regards
David
JasonB17/12/2014 20:51:57
Chronos used to sell one but not seen it listed for a while, have a search on some of the other forums like MHEM, MEM and MECH the subject has been covered on them all. Not too hard to make one either.
HMEM thread
Edited By JasonB on 17/12/2014 20:55:00
NJH17/12/2014 21:07:32
2314 forum posts
139 photos
David
I have sent you a pm - however I see that Jason as supplied a picture of the beast! By all meant though contact me if you think that I can help.
Norman
Maurice17/12/2014 21:43:40
469 forum posts
50 photos
I needed to turn down a long slender rod some time ago. I made a similar device to that shown, by making a replacement jaw for my travelling steady, Bored a 1/4" hole in it when fitted to the lathe, and reduced this with a bronze bush, drilled to the size of the rod. After the right amount of cut was determined by trial and error, the rod was turned down at one pass.
Maurice
David Haythornthwaite17/12/2014 23:07:33
45 forum posts
7 photos
Thanks Jason, Norman and Maurice.
I think I shall make something along the lines of the photo Jason posted.
I have also wondered whether to have the rear toolpost (QC) carry the supporting bush, swivelling my topslide round 90 deg. so that it carries my tangential tool right up to the back of the bush. The bush would then be centralised to the lathe centre by the cross slide feed and the diameter i.e. the cut would be controlled by the top slide feed.
We shall see - but thanks everyone.
David
Nobby17/12/2014 23:26:33
587 forum posts
113 photos
Hi David
I suppose the next problem will be threading the 8ba ?
Nobby
David Haythornthwaite18/12/2014 09:03:31
45 forum posts
7 photos
Hi Nobby
"I suppose the next problem will be threading the 8ba ?"
No problem with that. The ends of the studs will be threaded by holding the stud in an ER25 collet and using a die in a tailstock die holder. (yes they are long enough, - I think). If not, for the short ones, I shall thread them, one end, whilst they are on the parent material, cut off and screw them into a threaded mandrell in the chuck (or collet). For the tapping I have a home made pillar tool.
David
Nobby18/12/2014 11:05:43
587 forum posts
113 photos
Hi David
Thats what I thought . I also use a tailstock die holder and cut 8 Ba in steel . I did wonder as well as you if using the back toolpost to support to the bush Then rotate the topslide round square with the X slide so the X slide does not move when you put a cut on to final size for 8BA
Nobby
Gray6218/12/2014 11:33:28
1058 forum posts
16 photos
There was a small roller box described in MEW October 2002 (Issue 85) Neat little device but a little OTT if you are not going to use it much (mine hasn't seen light of day for a few years now.
Bob Unitt 118/12/2014 12:33:48
323 forum posts
35 photos
You could try a 'rose bit' - a hollow end-mill held in the tailstock through which you pass the workpiece to reduce it to the diameter of the hole. Advantages are that it always cuts to the required dimension, and applies no lateral pressure to the workpiece as it cuts. I don't know if they're commercially available, I made my own years ago to produce some 8ba bolts in stainless.
Rose bit for producing narrow rod
john jennings 118/12/2014 12:54:46
69 forum posts
Interested to know that a rose tool works on (free cutting ?) stainless.
They are (were?) a traditonal clockmakers tool so apart from brass (running down small screw blanks) would also cope with pivot steel a part hardened carbon steel.
Worth a try as easy to make and set up
Bob Unitt 118/12/2014 14:16:11
323 forum posts
35 photos
Posted by john jennings 1 on 18/12/2014 12:54:46:
I can't remember the stainless steel I used, probably something I scrounged from a friend who was company secretary of a steel distributor (a really useful guy to know ). It was for the 'wet end' of a steam engine. The cutter was most likely hardened & tempered 'silver steel', and I doubt that it ever produced more than the half-a-dozen bolts I needed for that engine. I just went into the workshop to see if I still had it, but it's disappeared somewhere in the intervening 20 years and 2 house-moves.
David Haythornthwaite18/12/2014 15:03:09
45 forum posts
7 photos
Thanks Bob,
An interesting way round the problem.
David
UJ Newton18/12/2014 15:46:20
23 forum posts
For a steady I use a knurling tool with the knurled rollers replaced..
David Haythornthwaite18/12/2014 20:14:35
45 forum posts
7 photos
What a good Idea. I would not be able to get the support quite as close to the cutting point on my setup, but I shall investigate. Thanks
David
Nobby18/12/2014 22:37:45
587 forum posts
113 photos
Hi David and guys
I know this is bigger than 8ba this is 5/32 whit thread i am useing a traveling steady I made for my S7
Nobby
s7 mk 1
David Haythornthwaite19/01/2015 19:30:37
45 forum posts
7 photos
Thanks to all who contributed to this thread.
I finished up turning lengths of silver steel down to 2.2mm diameter to cut into 8BA studs.
I used the rear tool post to hold a Phosphor Bronze bush round the rod, and set my topslide at right angles to the lathe bed (almost 90 deg - full right angles is impossible on a standard ML7 top slide.) The cutting tool (tangential) was adjusted by the top slide feed screw.
I attach a photo of my setup.
The finish was not as bad as it appears.
Thanks - David
Edited By David Haythornthwaite on 19/01/2015 19:32:13
Nick Hughes19/01/2015 19:44:25
307 forum posts
150 photos
Hemingway kits do a nice casting, that you machine and fit to the traveling steady mounting point on the Series 7 lathes:- **LINK**
