Set screws or threaded rod
Eric Cox12/10/2014 09:40:32
557 forum posts
38 photos
When fastening a steam chest to a locomotive cylinder block would you use hex. hd. set screws or threaded rod and nuts.
roy entwistle12/10/2014 09:58:40
1716 forum posts
Eric Studs and nuts
Roy
Nick_G12/10/2014 10:06:04
1808 forum posts
744 photos
Posted by Eric Cox on 12/10/2014 09:40:32:
Wait until Jason sees this.! surprise
He will consider it nothing short of blasphemy that you should even consider hex screws let alone mention them over studs and nuts. And also the correct profile of nuts.! winkwinkwink
Nick
JasonB12/10/2014 10:12:41
Who Me? At least you were thinking of hex head not slotted or socketwink 2
As said the prefered method is to take some rod, thread the ends and then use nuts and washers. There is also a practical reason for doing it this way, when you come to set the valve timing you can leave the valve chest cover off to see whats going on while the chest is still supported by the studs, can't do that with screws.
J
John Baguley12/10/2014 10:42:11
517 forum posts
57 photos
Actually a lot of steam chests/covers on locos are held on with csk head slotted screws. Often there is not enough clearance between the valve chest cover and the running board to get nuts in. Sometimes the steam chest is also secured to the block by a couple of csk screws through the steam chest only and between the normal fixings. That way the chest is still secured when the cover is removed for valve timing etc. A chassis I'm working on at the moment has that feature.
As suggested though, studs and nuts are the best way really. I've had a few locos where someone has been a bit over enthusiastic tightening bolts and stripped the threads in the block sad
julian atkins12/10/2014 10:46:45
1285 forum posts
353 photos
would eric's Northumbrian loco have had square nuts originally in fullsize? (circa 1830)
cheers,
julian
Michael Gilligan12/10/2014 11:15:02
23121 forum posts
1360 photos
Posted by JasonB on 12/10/2014 10:12:41:
... the prefered method is to take some rod, thread the ends ...
Thus making proper studs. yes
I know little of Steam practice [either full-size, or miniature] but it seems that normal "good engineering" principles would apply.
julian atkins12/10/2014 11:23:17
1285 forum posts
353 photos
(i stand to be corrected but Stephenson's Rocket of 1829 vintage as preserved has no hex nuts - they are all square nuts)
Ian S C12/10/2014 12:08:19
7468 forum posts
230 photos
Julian beat me to it, if your prototype is old enough, square head bolts, and studs with square nuts. someone else can start the argument as to which way up the nut should be.(don't go there),
Ian S C
JA12/10/2014 12:29:25
1605 forum posts
83 photos
Posted by Ian S C on 12/10/2014 12:08:19:
Ian S C
Please go there! I am making a Bolton & Watt bell crank engine.
JA
Michael Gilligan12/10/2014 14:08:24
23121 forum posts
1360 photos
Posted by JA on 12/10/2014 12:29:25:
Ian S C
JA
JA ... For reference here is "there"
Enjoy
JA12/10/2014 16:59:44
1605 forum posts
83 photos
MichaelG
Many thanks.
JA
Eric Cox13/10/2014 08:55:05
557 forum posts
38 photos
Sorry folks (I can hear the cries of despair already) I'm not going for authenticity at the moment I just want a loco that works so hex nuts it will be and probably stainless. However, one of my future projects will be am Armstrong muzzle loaded gun and that WILL have square nuts.
john kennedy 113/10/2014 11:14:02
214 forum posts
24 photos
Are we talking stainless for the studs ? or doesn't it matter?
