_Paul_ | 05/05/2014 02:35:32 |
![]() 543 forum posts 31 photos | Gray, You do have me hooked, I must try and find the thing now. My replacement base will probably be around 3" x 2" x 1-1/2" and in steel so the mag table on my aged Norton T & C grinder has something to grab onto. Paul
Lynne | 05/05/2014 04:26:01 |
117 forum posts 32 photos | Hi , MEW 176 &177, drill sharpening jig, by John Shepherd; well worth a read. Lynne. |
Versaboss | 05/05/2014 10:43:45 |
512 forum posts 77 photos | To bring this thread back to on-topic: Graham, would it be possible for you to produce and present a drawing of that new part on the foot of the jig (visible in pictures 2 and 4 on the first page)? Although I have no problems with the wedge, I'm completely lost with this. Obviously I'm the only one - but that's no big news for me. I think it would be easier than waiting for the day when something shows up in MEW (Or the other one, unmentionable here...?) Greetings, HansR. |
John Stevenson | 05/05/2014 14:18:03 |
![]() 5068 forum posts 3 photos | No Graham, you have got fixated because I mentioned CNC.
Try doing a search for patents on the 1950's pre CNC [ if I dare mention that ] They are the virtual same machine as regards the mechanics of the grinding process.
I must admit that I didn't have any joy only finding the later patents hence the mention of [ no we wont mention that again ] |
Howard Lewis | 05/05/2014 16:28:59 |
7227 forum posts 21 photos | I have one of these grinding jigs, and gave up using it, because it was so imprecise. I am unhappy with locating the drill flute against a stop, as any axial movement changes the angular position. (Which is why I am not happy with the Hemingway Mk2 drill grinding accessory. Sorry Mr Jeffree, otherwise your design is excellent) Instead, I now four facet grind using an ER20 collet holder mounted on the Hemingway 31 degree base for the Worden Cutter Grinder, setting the drill edge vertical. Four facet grinding is good, but I find it slow to set up. The Worden has a tapped hole in the base ready to take this "Picador" type attachment, and I think that Tony Jeffree did design a base which allows precise advance of the device. So PLEASE Graham, do publish the drawings for your improvement. I am sure that your version improves the gadget to the point, where mounted on a base with graduated advance, it can sharpen drills accurately and consistently. Howard |
Tony Jeffree | 05/05/2014 17:38:49 |
![]() 569 forum posts 20 photos | Posted by Howard Lewis on 05/05/2014 16:28:59:
I have one of these grinding jigs, and gave up using it, because it was so imprecise. I am unhappy with locating the drill flute against a stop, as any axial movement changes the angular position. (Which is why I am not happy with the Hemingway Mk2 drill grinding accessory. Sorry Mr Jeffree, otherwise your design is excellent) Instead, I now four facet grind using an ER20 collet holder mounted on the Hemingway 31 degree base for the Worden Cutter Grinder, setting the drill edge vertical. Four facet grinding is good, but I find it slow to set up. The Worden has a tapped hole in the base ready to take this "Picador" type attachment, and I think that Tony Jeffree did design a base which allows precise advance of the device. So PLEASE Graham, do publish the drawings for your improvement. I am sure that your version improves the gadget to the point, where mounted on a base with graduated advance, it can sharpen drills accurately and consistently. Howard Howard - Not guilty I'm afraid - I have built a Worden from the Hemmingway kit, and I did buy their drill grinding kit at the same time (and have failed as yet to build it), but I had nothing to do with its design, or the adaptation for the Picador device, for that matter. Of course, if I had, it would work flawlessly Regards, Tony |
Versaboss | 05/05/2014 19:40:11 |
512 forum posts 77 photos | Posted by Graham Meek on 05/05/2014 13:09:28:
... The reason for the wedge is, ... I'm so sorry Graham, it seems I could not express clearly what I meant. I said I have no problems with the wedge - meaning I understand its purpose. What I really don't understand is the other part, which looks like a very substantial bearing for the small vertical stem of the jig. Maybe, instead of a drawing, you could try to tell in a few words how to make it? (length, thickness, the purpose of the tangential clamp(?) screw - which part is still movable when this really iy a clamp?). In the description you wrote something about 'dialling in the eccentricity...) Is there a scale somewhere? Oh, how difficult to express ones thoughts when one has nothing than a photo... Greetings, HansR. |
Neil Wyatt | 05/05/2014 20:31:12 |
![]() 19226 forum posts 749 photos 86 articles | Hi Howard, What angle do you use for the cutting and secondary clearance when you grind 4-facet drills? Sir J.That video is worth a thousand words! Neil Edited By Neil Wyatt on 05/05/2014 20:32:40 |
Michael Gilligan | 05/05/2014 22:01:51 |
![]() 23121 forum posts 1360 photos | For those with a penchant for Patents, this one from 1949 is definitely worth a look. ... Those with no interest, please just ignore it and accept my apologies for the intrusion. MichaelG. |
John Stevenson | 05/05/2014 22:02:08 |
![]() 5068 forum posts 3 photos | Posted by Neil Wyatt on 05/05/2014 20:31:12:
Sir J.That video is worth a thousand words! Neil .
Showed a profit for once then, - it was only 900 frames long............ |
Versaboss | 05/05/2014 22:31:52 |
512 forum posts 77 photos | Many thanks Graham, now all is clear! Well, maybe not - could it be that different species of these jigs exist? As I have other (better) means for drill grinding up to 13 mm, I don't use it often. Also the positioning lip was ground away long time ago, so setting up is more or less a matter of luck. However, I tried it again today with a 15 mm drill. Without a wedge under the foot, and with the jig on the 59 deg. mark, I measured a tip angle of 120 deg, +/- 2 deg maybe. Due to the eyeball setup the drill cut about 0.2 mm oversize (directly into Alu and steel, without using a center drill...) It seems what I really need is Mr. Hall's 180 deg. switchover gadget. Also a longer guide rod and something which prevents the different nuts from moving due to the vibrations. Now I think I have stressed your patience enough, Greetings, HansR. |
Clive Foster | 05/05/2014 22:58:54 |
3630 forum posts 128 photos | Nice one Micheal. Looks to be the original of the Picador version with vertical pivot post and 5 to 5 drill lip alignment. Clive |
"Bill Hancox" | 05/05/2014 23:14:47 |
![]() 257 forum posts 77 photos | I have a similar model jig made in the US by General Tools. It must be forty years old and still in the wrapper. I was told years ago by various metalworkers that they were an abomination to use, so I never did unpack it. Now I will definitely give it a go with Graham's mod. Mod! That word of brings back memories .... of paisley shirts, mini skirts and Meccano erections. |
John Stevenson | 06/05/2014 10:22:15 |
![]() 5068 forum posts 3 photos | If you look back far enough there were a load in 1908 and 1903 all based on the swing post method of operation.
Like many thing mechanical, nothing is new. it's only materials and electronics that are enhancing some of the old Victorian designs.
There is a thread going at the moment on the Eureka relieving tool. The basis of that was an advert from a magazine also from the 1900 era that Prof Chaddock and Ivan Law tried, and succeeded to reverse engineer from the sketch. |
Michael Gilligan | 06/05/2014 10:29:21 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 05/05/2014 20:31:12:
Sir J.That video is worth a thousand words! Neil . Neil and/or John, Am I right in thinking that this comment belongs in the Eureka thread ? ... I searched here last night, but couldn't find any video posted by John. MichaelG. |
John Stevenson | 06/05/2014 10:34:00 |
![]() 5068 forum posts 3 photos | I thing Neil was trying to save electrons by replying to two posts in the same reply.
Typical model engineer, tight arsed, moleskin trousers with deep pockets and drives a Reliant |
Michael Gilligan | 06/05/2014 10:40:22 |
![]() 23121 forum posts 1360 photos | Cheers, John MichaelG. |
WALLACE | 06/05/2014 11:37:12 |
304 forum posts 17 photos | Could not a similar variable offset be achieved with a set of spacers in a similar fashon to the one modified by Rik Shaw a few weeks ago ? Definitely worth replacing the awful flat steel 'bearing' with something better but spacers might be easier to turn up than the eccentric. Not sure I've thought through the geometry thoroughly so I could be wrong !! W. ! |
Michael Gilligan | 06/05/2014 12:10:04 |
![]() 23121 forum posts 1360 photos | Posted by John Stevenson on 06/05/2014 10:34:00:
Typical model engineer, tight arsed, moleskin trousers with deep pockets and drives a Reliant . ... forgot to mention; mine was a Scimitar Coupé with a nice "blueprinted" V6 and decent wheels & tyres. MichaelG. |
NJH | 06/05/2014 12:45:34 |
![]() 2314 forum posts 139 photos | Michael Well I don't think a Scimitar is too useful a vehicle for everyday use. On the other hand I suppose it might be useful to subdue JS comments! ( sorry John ) Norman
Edited By NJH on 06/05/2014 12:48:24 |
