Clive Hartland | 14/06/2014 17:49:33 |
![]() 2929 forum posts 41 photos | How about a dog chasing a cat in wheel, should be fun. How many Hamsters to 1Hp?You could have overhead hamster cages, just give them a little prod now and then. Thinks, hamsters are nocturnal so you need some way to store the power. dammit, I will just plug it in the mains. Clive |
Sam Stones | 14/06/2014 22:49:33 |
![]() 922 forum posts 332 photos | Gentlemen, Around 1950 my father bought me a second hand treadle lathe. It was clearly for metal working, with top and cross slides, gears and a lead-screw. The flywheel was massive, but the flat belt either kept breaking or slipping off the pulleys. If you did manage to have your toe under the cast iron treadle, it was only the mass of the treadle which could clobber you. The linkage had been slotted for that very reason. Unfortunately, the lathe was already knackered. The one-piece casting had split over the front bearing, and the three-jaw chuck was virtually useless. Nevertheless, my school mate (a big lad who occasionally treadled for the headmaster), and I tried almost successfully to turn bits of wood in it. Now here’s where you might find some additional benefit Gordon, the treadle pedal was wide enough for two. For that extra tenth of a HP, you could invite a friend or SWAMBO to stamp on the pedal too. Good luck, Sam |
Raymond Sanderson 2 | 15/06/2014 02:04:24 |
![]() 450 forum posts 127 photos | You could always pinch the wife's old sewing machine treadle if she still has one ........mine does as well as 2 electric ones.
There used to be Treadleit.com but after bringing up my link I am getting errors and no page a search didn't do much better. It was I believe an NZ based site with a world of info etc. |
Ady1 | 15/06/2014 02:45:18 |
![]() 6137 forum posts 893 photos | It sounds like the sort of project where Constantinescues torque convertor could be useful You get lots of torque for less power The general principle seems to be... the faster you try and shove a weight back and forwards the more it resists the motion and the more energy you get transmitted to the secondary output shaft a. is slow speed b. is fast speed c. is medium speed Edited By Ady1 on 15/06/2014 03:05:56 |
AndyB | 15/06/2014 08:17:21 |
![]() 167 forum posts 7 photos | A subject close to my heart! I have just looked at a picture of your DB8 on Chester's website and I think that you will really struggle to convert your existing lathe. The problem is design; your Chester will need an access for the belt to the headstock and this will require a countershaft in the position where the electric motor is. Unless you get your gearing right you will stuggle to get speeds of any use. Why not keep that as it is and get an existing treadle lathe for when the power gets turned off? I have several Drummond lathes and I have three 3 1/2" flatbeds that are complete with treadles; a 1907, a 1914 B type and a 1927 longbed M type. Treadling is HARD work, especially if you are screwcutting, as you are driving so much resistance through the changewheel gearing. It can be done though, and was, by everybody who used small lathes (up to 6 inch centre height) throughout the 19th century and into the 20th, who had no lineshafting (my great grandfather who owned my 1914 B type which he got in 1916). Just look at how many lathes were sold with treadles. One of the tricks though is to have an apprentice...there were the ones who treadled while the master did the work! Have you got grandchildren? Everyone these days complains about kids not getting enough exercise. Incidentally, the 1907 flywheel weighs half that of the B and M types, and being a lighter lathe, may have been so designed to reduce the amount of hard that the operator may be tempted to try. The later B and M type beds weighed twice as much and the M headstock can take a phenominal cut for such a small lathe. I mainly use a motorised 1948 M that came from the de Havilland works (still has the works plates on) and, just for a one off experiment, cut 1/4" of cast iron in lowest backgear with a carbide tip on a facing cut. I don't know if any of you would dare try that on a modern lathe of the same size? There is a booklet, produced by Drummond in the early 20s, that demonstrates the work done by amateur craftsmen and has a 9 cylinder radial engine entirely produced on a treadle Roundbed, with some of the setups used. If they could do it, why can't we? My point is: get another lathe, one that was designed to be used with a treadle, rather than try to convert a modern shape lathe. Just another point; pitmans. I have both types, slotted and round. Both have merits. the 1907 has a round pitman with a bush, the 1914 has a slotted one and the 1927 goes back to a round one but with a ball bearing. I suppose that it comes down to the price of ball bearings, that the cost of manufacture was reduced significantly during the First World War. It is not my intention to inflame the ready (pointless) debate about the merits of this or that machine tool, I am just pointing out the old chestnut "horses for courses". Anyone can use whatever they want or can afford and I don't care; I am happy with what I have got. All the best, Andy |
Gordon W | 15/06/2014 10:09:59 |
2011 forum posts | Thanks for all the interest. My wife does not sew nor treadle, she earns money to buy me beer and tools. Ady, I'm reading up on the inertial torque converter, very clever man but I think I should stick to simple things, life's to short. My grandson is 23 yrs. old rugby player but only comes up about once a year and I have lots of things lined up for him to do. Andy I take your point and you are correct about the power needed, but can't afford another lathe. I have now got my proposed workshop, it's a back of a small furniture van, about 7 ft x 16 ft with a luton. all alloy just needs some second hand foam sheet and a few railway sleepers. My thinking is to sheet in the luton and use as a power house, with counter shaft and long flat belt drive. Also can house my old diesel petter and generater. Getting it home was fun, early sunday morning ,back roads on a borrowed car trailer. This is still no more than a thinking exercise. |
Ian S C | 16/06/2014 12:17:32 |
![]() 7468 forum posts 230 photos | Raymond, I Googled Treadleit .com, and there it was. It's based in Arazona USA. Ian S C |
Hopper | 16/06/2014 12:57:45 |
![]() 7881 forum posts 397 photos | Really, I think I would be looking at getting power on to this new workshop. Even a long extension cord will do the job if it is suitably heavy duty, such as those designed for small generators to be set up suitable distance from camp etc. What are you going to do for light? Holding a candle in one hand while treadling sounds pretty awkward. As does pumping up the old Tilly lamp every time it gets low. If you really cant get power on, a small four-stroke lawmower engine will give you your 1hp or more for the lathe, and many have a basic speed governer for varying loads. Have you thought about solar power and batteries and DC motor? |
Gordon W | 16/06/2014 14:14:02 |
2011 forum posts | Thanks to all for ideas. Hopper- I have gennies, oil lamps etc., we live in an isolated spot, thinking about the future. Solar panels and a small wind turbine will give enough for telly, LEDs etc. but will be pushed for lathe drive, biggest problem and expense will be batteries. Treadling will help with battery charging & LED's are good with low consumption. |
Bazyle | 16/06/2014 17:13:45 |
![]() 6956 forum posts 229 photos | What spec wood fuelled steam plant would be suitable for running a small lathe like a round bed Drummond? I've got the treadle but getting put off fitting it. Would direct drive be best or running something smaller to charge an accumulator to run a DC motor? Like the wartime Stuart sets. After the apocalypse should whale oil be used for lamps as in 19th century or reserved for running a generator? How many acres of rapeseed will I need to grow (harvested and crushed by hand) for the oil for say 8 hours of workshop time per week?
V8Eng | 16/06/2014 17:56:58 |
1826 forum posts 1 photos | I think a Horse Gin might be the answer to much of this problem. |
Neil Wyatt | 16/06/2014 18:39:24 |
![]() 19226 forum posts 749 photos 86 articles | With a rugby-player son, I see no problem. He just needs enough beer to keep the first XV happy and working in shifts. Neil |
