Michael Gilligan | 02/02/2012 09:00:08 |
![]() 23121 forum posts 1360 photos | Ian, Yes indeed. ... I did see a good write-up for a simple Tacho, but failed to bookmark it ![]() Meanwhile ... This does the job, and More! http://sci-spot.com/Mechanical/dyno.htm Definitely worth exprimenting with this one. ![]() MichaelG. |
Michael Gilligan | 02/02/2012 09:09:56 |
![]() 23121 forum posts 1360 photos | Reminder ... "Optical Mouse" has become an ambiguous term. The ones that we are most likely to re-use have a Ball, driving Optical Shaft Encoders. The new fangled ones [as referenced earlier] have Video sensors. MichaelG. |
Ian S C | 02/02/2012 09:21:17 |
![]() 7468 forum posts 230 photos | MichaelG, the latter ones are the ones I'm thinking of, seems a similar technoligy to the non contact tachometers, I suppose a wireless one would be even better. Ian S C |
Michael Gilligan | 02/02/2012 09:31:53 |
![]() 23121 forum posts 1360 photos | Ian S C I may be wrong, but: To my mind, the video ones seem better suited to measuring Displacement than Speed. ... The Slotted Disk Encoders are already "non-contact". MichaelG. But it is certainly possible ... http://www.kronosrobotics.com/Anotes/Athena%20to%20Optical%20Mouse.pdf Edited By Michael Gilligan on 02/02/2012 09:41:54 |
Terryd | 02/02/2012 13:51:35 |
![]() 1946 forum posts 179 photos | Quadrature encoder which recognises direction of rotation using 'Ball' mouse T |
David Littlewood | 02/02/2012 16:12:07 |
533 forum posts | Graham,
I have read this thread with some bafflement. I understand you are an experienced machinist and may have good reasons for not wanting to rely on a DRO monitor some way away from the workpiece. If I understand you correctly, you simply want a method of "counting the 3 mms" for you, anf you will use the dial to get the finer divisions.
If so, I can't see why the scale rule on the FB2 will not do this for you. Before I fitted a DRO to my FB2, that's how I would have done it. As you have already acknowledged, but others less experienced may not know, all measuring scales which use the rotation of the leadscrew for measurement are at best approximate, and at worst downright dangerous; they all ignore backlash, and if not used correctly will cause grief.
For others (and maybe for you) it may be helpful to see the DRO I fitted to my FB2 4 years ago. Fitting was a job needing care but no special skills; the monitor can be swung into a place where it is easy to read, and when you learn to trust it you get into the habit of driving the thing on instruments, as it were.
The photos were taken before I got round to fitting the Z-axis scale. The only modification to the mill was a small stop block next to the column to stop the carriage crushing the X-axis scale against the column base. Where do you live Graham? If close by (SE London) you would be most welcome to come round and give it a try.
To others I would say, don't think you will get an improvement in accuracy if you fit a leadscrew-driven scale, go for the right solution. I know it's the biggest improvement I have made to my milling.
David |
Ian P | 02/02/2012 19:28:44 |
![]() 2747 forum posts 123 photos | Graham
I have followed this thread since the beginning and I do now have a better understanding of what you are trying to achieve. What I am unclear about though is why setting a handwheel index collar to a certain point is any different to turning the handwheel and stopping when a digital display reaches a certain value.
I am a total layman in regards to any medical matters and obviously do not know any details of your health problem but I do not see why you have to oscillate to and fro to get to a particular setting. With a normal graduated collar and leadscrew arrangement its usually preferable to approach the target stopping point slowly and in one direction (to account for backlash). There is no reason why the same technique cannot be used with a digital display.
I can envisage that the DRO on the Bridgeport you mention has far greater resolution than is required. Can I respectfully suggest that some of the least significant digits are obscured so that the display only shows increments of 0.01mm, I'm sure its worth a try.
Ian P |
Ian S C | 03/02/2012 07:20:07 |
![]() 7468 forum posts 230 photos | MichaelG, I had a look on Google, was quite interested to see that the "mouses without a ball" actually have an 18 x18 camera, and it can be used as a scanner, or a rather crude web cam, and the ones building Robots find uses for them. Ian S C |
Michael Gilligan | 03/02/2012 08:29:49 |
![]() 23121 forum posts 1360 photos | Ian S C If I may be philosophical for a moment ... In the small hours of yesterday morning, you professed "I know nothing." Now; you have some real understanding of the workings of an astonishing piece of technology ... which, thanks to mass production, is available at very low prices, for us to experiment with. I rejoice that we have the means [through forums like this, and through the democratising power of the Internet], to share the little knowledge that each of us has acquired. Across the world, there are; creative minds, clever technicians, and people who need things ... Never in the history of our civilization has it been so easy to put them together! It feels a better day already. MichaelG. |
Ian S C | 03/02/2012 10:51:04 |
![]() 7468 forum posts 230 photos | MichaelG,If I "know nothing" one day, I try to at least know a little about it as soon as I can, but some of the stuff on the web should be taken with a grain of salt, you just have too filter out the rubbish, ie., the proponants of perpetual motion, or someone who thinks the motor designed by Carnot is the best way to go (actually it can't work).
The day you stop learning, is the day they put you in your wooden box (no ones come back to say they keep learning, maybe they learned enough to keep away). Ian S C Edited By Ian S C on 03/02/2012 10:55:25 |
Stub Mandrel | 03/02/2012 20:34:01 |
![]() 4318 forum posts 291 photos 1 articles | On Today this morning there was a discussion with an engineer of his company's liquid air energy storage system. They said so it's like a steam engine, he said well it's like a steam turbine in a power station. They kept saying it's like a steam engine and in the end he said it's actually a Rankine Cycle* and they shut up ![]() Neil * as we all know this menas a turbine in a closed loop of vapour and liquid between a boiler and a condenser. |
Michael Horner | 08/11/2012 07:55:08 |
229 forum posts 63 photos | Hi Gray I note from a different post that you have retired now, did you get your counter built?
This looks like a good idea for the cross slide of a minilathe. On big jobs I lose count of where I am upto then go oversize/undersize For the Z axis I have fitted a digital caliper and it works great because it's out of the way, to fit the same thing on the cross would get all the debris on it and it would get in the way. I envisage one of the cheap rotary encoders fitting on the end of the lead screw at the back of the cross slide. The one I am thinking of using has 24 pulse output which would give me a resolution of 0.0833333 mm which is close enough for me, I would then use the dial on the handle to finish off. I am at the moment writing the algorythem because I will be using a PicChip to pull the thing together. My head is hurting working out the how to work out the direction of travel but I suppose that's what keeps they grey matter alive! Cheers Michael |
Grizzly bear | 08/11/2012 13:23:46 |
337 forum posts 8 photos | May I just say, having put a PC mouse to to sleep, removed the encoder bits. Don't forget the steel ball, it's easily drilled and makes a useful knob. You all knew this of course. Regards Bear.. |
Les Jones 1 | 08/11/2012 14:53:04 |
2292 forum posts 159 photos |
Hi Michael, Les. |
Michael Horner | 11/11/2012 09:31:56 |
229 forum posts 63 photos | Hi Les Thanks for the copy of the code, it is well annotated. Just got to find the old rev counter I made so I can recode it for it's new purpose and hope I didn't use all of portb to drive the 7-segment displays! Cheers Michael |
Les Jones 1 | 11/11/2012 11:13:30 |
Hi Michael, Les. |
John Stevenson | 11/11/2012 11:48:25 |
![]() 5068 forum posts 3 photos | Gray, If this is something to just give you a guide as opposed to being a readout working to 18 decimal places. What about one of the ARC cross slide units with a pulley on it , pulled along by a Bowden cable. Adjustments could be made for travel by the size of the pulleys ?
This way the pitch of the screws doesn't matter.
John S. |
blowlamp | 11/11/2012 12:23:12 |
![]() 1885 forum posts 111 photos |
Posted by John Stevenson on 11/11/2012 11:48:25:
John S. These units work well enough, but I'm finding battery life to be abysmal - a couple of months at the most. Martin. |
John Stevenson | 11/11/2012 12:41:00 |
![]() 5068 forum posts 3 photos | Good heavens man, 2 months ?
That works out to sixpence a week, you need to take the old pop bottles back and use the refund money to get a new battery.
John S. |
Stub Mandrel | 11/11/2012 13:19:35 |
![]() 4318 forum posts 291 photos 1 articles | MichaelG, I had a look on Google, was quite interested to see that the "mouses without a ball" actually have an 18 x18 camera, and it can be used as a scanner, or a rather crude web cam, and the ones building Robots find uses for them. Ian S C Excellent! I've been on the lookout for something like that for years! Neil |
