Eccentricity / Run-Out
on the Drum of our Miele Washing Machine ...
Neil Wyatt27/09/2017 21:00:00
19226 forum posts
749 photos
86 articles
Simple advice for buying washing machines:
1 Choose one that costs less than the three-year extended warranty
2 Don't buy the extended warranty
3 Ideally make it one of the badge engineered brands and choose a non-premium brand so you get all the same features with a different fascia.
4 Keep it running with parts from espares
When our machine eventually gave up (after three sets of brushes and a new controller board when the first set of brushes blew it out) this year it was because it kept cutting out (probably the out of balance detection had gone over-sensitive). I replaced it with an all-singing all dancing hi-capacity high spin-speed Swan with loads of easy eco-programs and a wonderful countdown timer for under £200.
Chris Evans 628/09/2017 09:01:13
2156 forum posts
Michael. I seem to remember looking at Miele machines last year when we replaced our machine, we where in a branch of John Lewis where we bought a Bosch machine. I will take a look next time we are there at the warranty it may have been a store enhanced thing as all electricals from them get minimum two years.
Howi28/09/2017 09:11:52
442 forum posts
19 photos
Samsung make washing machines too, they play a tune when the wash cycle has finished.surprise
You get an extended warranty free from Samsung.
Well made, reliable, but the picture quality is crap crook
Sandgrounder28/09/2017 10:34:00
256 forum posts
6 photos
Posted by Neil Wyatt on 27/09/2017 21:00:00:
I wondered about that when we bought our previous machine many years ago, the top of the range ones, Bosch, AEG etc were around £600 + with a 2 year guarantee while a Candy was about £150 with a 1 year guarantee, however for about an extra £100 - £150 you could buy a 5 year guarantee for the Candy, so if you just wanted a basic washing machine without any special features which is a better buy? £600 with a 2 year guarantee or £300 with a 5 year, I'm not quite sure.
Circlip28/09/2017 10:39:38
1723 forum posts
A bit off piste but highlighting the "Extended warranty". Recently, (last week) bought a double socket adaptor for the telephone wall socket for the princely sum of £1.27 on "The Site", BUT----- for an extra £8 odd I could have a three year extended electrical warranty on said item. Took a lot of soul searching to decline.
Regards Ian.
Edited By Circlip on 28/09/2017 10:40:17
martin perman28/09/2017 10:45:29
2095 forum posts
75 photos
Until our daughter moved out I've always bought the extended warranty for one reason only, I've spent most of my working life doing engineering service work and spending weeks away from home and the last thing was a problem at home that I couldn't sort out, by having the warranty meant that all my wife had to do was pick up the phone and having a small child meant she went to top of the list, it cost more obviously but I had piece of mind.
Martin P
Edited By martin perman on 28/09/2017 10:46:24
Martin Botting 228/09/2017 11:05:49
93 forum posts
20 photos
My washing machine also sounded like a bucket of rocks, thats because I use the rocks on the banks of the thames to wash my overalls.
I was amazed when I decided I could have a go at repair on an old Indesit I had and the lump of cast concrete on the top of the drum. needless to say it was 12 years old and beyond hope so I invested in one of the direct drive LG washers, which is so quiet and does not take a walk on the spin cycle.
The mention of concrete lump reminds me of the Citroen owner that filled the front "boot" with poured concrete to trim the car up after the rear suspension had given way and he was not going to fork out for the repair. So how about adding more weight to the drum, another 3 CWT should do the trick.
Chris Evans 628/09/2017 19:27:06
2156 forum posts
I went into a branch of John Lewis today and took a look at the Miele washing machines. For your £960 odd quid (cheaper version available) you get a two year warranty then you claim an extra eight years full parts and labour warranty in with the price.
Ady128/09/2017 19:40:50
6137 forum posts
893 photos
If a Miele is knackered then it really is knackered
They go well for 7-10 years(heavy use) then everything goes at once
Michael Gilligan28/09/2017 19:41:48
23121 forum posts
1360 photos
Posted by Chris Evans 6 on 28/09/2017 19:27:06:
Thanks for that, Chris
... Rather strangely, it appears to be only that one model that offers +8years warranty extension
https://www.johnlewis.com/miele-wdd030-freestanding-ecoplus-comfort-washing-machine-8kg-load-a-energy-rating-1400rpm-spin-white/p3176647?navAction=jump#tabinfo-spcl-off
If you hadn't seen it in-store, I might have assumed it was a typo.
Michael Gilligan28/09/2017 19:44:33
23121 forum posts
1360 photos
Posted by Ady1 on 28/09/2017 19:40:50:
I think you're probably right Ady
... I still haven't checked how old ours is; but it's somewhere in that region.
Phil Whitley28/09/2017 19:50:17
1533 forum posts
147 photos
Useful description, thanks Phil yes
However; As I said in the opening post ... there is no evidence of bearing failure, or of looseness.
It is conceiveable that the shaft is bent; but it is not evident ... the drum appears simply to have been displaced radially.
The noise and vibration are apalling; and yes, the drum is intermittently contacting the door gasket.
I don't really understand what has happened, but I'm pretty sure something significant is amiss !!
[ forensic inspection to follow in due course ]
It won't be the shaft that has bent, it will have displaced the drum on the spider. When the spider is fitted to the drum, there is usually some small amount of adjustment to get the drum concentric with the shaft. I think this adjustment has moved, or the bolts holding the drum to the spider have bent slightly. |If the shaft itself had bent, you would know about it as soon as it went into spin!
Phil Whitley28/09/2017 19:56:04
1533 forum posts
147 photos
Edit that, if the noise and vibration are appaling, and it is touching the door gasket, time for serious strip down, or a new one. My cousin has an LG, and it has been faultless for several years, and Very quiet, In the same amount of time I have had a Bosch, which suffered spider failure, and now a Gorenje, which has had a new door (it has broken again) and a new tub complete with bearings, all under the five year warranty. Like most things today, unless you pay a lot, and select the models carefully, you get something that will last probably 2 to 3 years if you are lucky.
Phil Whitley28/09/2017 20:09:41
1533 forum posts
147 photos
Michael Gilligan28/09/2017 20:24:15
23121 forum posts
1360 photos
Phil,
Thanks for your updates ... I think we have reached the same diagnosis.
... either the drum has slipped [within its manufacturing adjustment range], or something in that mounting area is broken.
The LG direct drive machines do look very promising [low noise level, and good reviews]
Phil Whitley28/09/2017 20:28:10
1533 forum posts
147 photos
Yes, my cousins is the direct drive model , he is very pleased with it, but I think it was nearly £600!
Neil Wyatt28/09/2017 21:19:37
19226 forum posts
749 photos
86 articles
Posted by martin perman on 28/09/2017 10:45:29:
Martin P
Yes but... in my experience the extended warranty (bought at purchase) usually costs as much as new machine.
My assumption is that I'm unlikely to have two machines fail without getting three years out of them, bearing in mind that the standard failure curve for electronic equipment has most of the failures in the first few months or after several years.
martin perman28/09/2017 21:38:23
2095 forum posts
75 photos
In forty years, we've has four washing machines, the first was second hand and I maintained that until the casing disintegrated after six years, the next two had warranties and lasted about fifteen years each and the latest is approx four years old and has no warranty beyond the two years offered, they all ran at least once a day.
One of the machines had several parts replaced but the others have never missed a beat, the latest is a Bosch.
They are like our central heating, it has only ever had two pumps, the one fitted when we moved in 29 years ago and the current one, the boiler is 25 years old and still gets a good bill of health when serviced every year, the reason I think that they have all lasted is because they all work 365 days a year.
Martin P
Mike Poole28/09/2017 21:49:41
3676 forum posts
82 photos
8 years out of Miele so far, had to de gunge small pipes to get it to realise it had pumped out. Must do more high temp maintenance washes.
14 years out of Zanussi but although the drum bearings are easy to replace the seals were not so easy, at least the surface they run on is hard to repair. Called it a day when you couldn't hear the helicopters going into Benson.
Hotpoint and Indesit were total crap but cheap
Colin Whittaker29/09/2017 03:40:53
155 forum posts
18 photos
Not a washing machine but a cooker, bought in the January sales in Cambridge in the mid 1990's for around 500 GBP.
Did I want the extended warranty? No thank you.
What about failures? Is this an unreliable cooker? No. OK then no extended warranty.
But the halogen hobs are very expensive when they fail. And so on for 5 minutes or more.
My slighly exasperated final response, "Can I buy this cooker without an extended warranty?"
It's now 20+ years later. For the last 10 years the cooker has been operating in an open air house kitchen in Phuket with the sea air doing it's best to encourage lots of surface rust. Several years back the digital clock failed and I had to bypass it to get power to the main oven. One of the hob switches was threatening to go intermittent last year but the problem went away. Last month a lightning strike punched a hole through a wire's insulation and burnt out a connection (now spliced).
Extended warranties are to make money for the retailer. If you can afford to carry the risk then you'll normally make money out of the deal.
Please excuse the telling of this off topic tale; my traditional family audience now regards this story with ill disguised boredom.
Edited By Colin Whittaker on 29/09/2017 04:07:49
